HeadlightArmor
Old 01-09-2013, 08:44 PM   #1
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
*Pics* Eye Candy.. First DSS V6 Trans to V8 Rearend 3.5" Aluminum Shaft
Thank you once again to BaylorCamaro for coming down while I was in Houston so we could properly measure out a driveshaft for his vehicle. This Driveshaft Shop 3.5" Aluminum Driveshaft is for V6 transmission (Manual OR Auto Flanges are available) to the V8 rearend, proper lengths and all. No more using the stock driveshaft to fool the measurements with the slip couplers!
Now it is on it's way to BaylorCamaro!
Matt @ FSP is offline   Reply With Quote
Old 01-09-2013, 09:30 PM   #2
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Lookin good Matt!!! Damn - something else to add to the to do list!
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 01-09-2013, 09:34 PM   #3
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 01-09-2013, 10:13 PM   #4
KMPrenger
KMPrenger's Avatar
Awesome!
Old 01-09-2013, 10:20 PM   #5
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Very nice breakthrough here.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 01-09-2013, 10:27 PM   #6
Matt @ FSP
Matt @ FSP's Avatar
Haha YG the list never stops.
Yes this was a great combination of some good minds put together and an excellent fabricator.
SIX: Just like you said, day by day these cars are still gaining great parts. I know you are testing out some clutches over there, and a few months ago there was no options.
Here is just another one to add to the V6 mod lists.
Old 01-10-2013, 10:45 AM   #7
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Baylor has one impressive shaft. Think this will work with a 1LE differential?
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 01-10-2013, 12:43 PM   #8
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Looks good, may have to swap this in when I do my clutch.
Can't_C_Me is offline   Reply With Quote
Old 01-10-2013, 12:48 PM   #9
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Btw guys I'm ignorant to this mod, why do I want it?
DarkneSS is offline   Reply With Quote
Old 01-10-2013, 01:44 PM   #10
Matt @ FSP
Matt @ FSP's Avatar
If you have a V8 rearend in there, you have taken the front half of the propeller shaft from your V6 and then taken the back half of the prop shaft from a V8.. The reason why it works as far as distance is because there is a slip joint in the middle of the prop shaft. If you want the proper length shaft, along with the reliability this is the way to go. The other way does work...
Old 01-10-2013, 01:56 PM   #11
Matt @ FSP
Matt @ FSP's Avatar
Yep.
Old 01-10-2013, 02:34 PM   #12
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
This would work with M6 V6's and V6's with any variant of the V8's rearend . Correct me if I'm wrong Matt.
Sent from my Samsung Galaxy S III
Old 01-10-2013, 02:56 PM   #13
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Oh, thanks for noticing
All of that, plus I am not a fan of 2 piece shafts. There is more inefficienc, and I save a little bit of weight with this.
BaylorCamaro is offline   Reply With Quote
Old 01-10-2013, 04:13 PM   #14
Matt @ FSP
Matt @ FSP's Avatar
Yes you just need to tell me if it is a manual or automatic V6 transmission and let us know if you have the 1LE or Std V8 rearend (Doesnt matter 3.27 or 3.45) vs. the ZL1 .. The only variance would be if you put the ZL1 rear in the back, then the measurement would change. However, these measurements would work fine for any V8 rearend (Minus the ZL1)
- Matt
