Old 01-11-2013, 10:51 AM   #1
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
Question Intake, Midpipes with cats and 90mm Throttle Body w/o Tune
Ok everyone, I'm wondering if this combo will work without a tune. I originally had bigger plans for my ZL1 but decided to just go with some basic bold on's for now and keep the factory tune. I was looking at a Roto-Fab intake, JBA Catted midpipes and a stock LS3 (90mm) throttle body. Would this setup work without a tune or would it be too much. Thanks in advance for the help.
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 01-11-2013, 11:10 AM   #2
2010 4 DW
Drives: White 2010 RS/SS
Just check your AFR on the dyno and I think you will need to tune the TB..
2010 4 DW is offline   Reply With Quote
Old 01-11-2013, 11:39 AM   #3
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I think the cai and midpipe might be fine.
I have been told you must tune for the 90MM TB. I am not sure if that had to do with AFR or just the response of the TB.
this is exactly what I am considering to start with as well. I am also considering STainless power longtubes as even though without pulley your net hp might only be 20-25hp less boost will also help minimize heat issue.
I have decieded to tune. this car runs real rich from the factory.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 01-11-2013, 12:07 PM   #4
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
As a general rule of thumb. Anything changed behind the MAF should be tuned. So a throttle body or intake manifold etc.., Or, anything that changes the location of the O2 sensor or removes the factory cats. So long tubes or off road pipes will generally need a tune.
So everyone here is pretty much right on. The intake and high flow cats should be fine. You might catch an insufficient catalytic converter code on the cats every now and again but other then an eye sore it's not a big deal. The throttle body change might cause some issues.
Get more power for your dollar! We have the best prices on the hottest parts and we price match!
JUICEDMOTORSPORTS.COM
224-63-JUICE 224-635-8423
Juiced1 is offline   Reply With Quote
Old 01-11-2013, 01:01 PM   #5
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Thank you all for the help.
Old 01-11-2013, 03:00 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28
90mm TB will not work well but the mid pipe and CAI should be fine according to the gurus here.
'15 Z/28 #325 black a/c & stereo. 2:10.9 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-11-2013, 04:00 PM   #7
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Thanks Stephen, your thread inspired me to get those midpipes!
Old 01-11-2013, 08:45 PM   #8
Enough
Drives: 2013ZL1
You would be pleasantly surprised how well the 90mm throttle works without a tune. Try it before tuning.
Enough is offline   Reply With Quote
Old 01-11-2013, 09:13 PM   #9
Stephen12ZL1
Drives: '15 Z/28
I tried it as my first mod with everything else stock and it felt like the car was not happy at higher rpms. At low throttle input and quick jabs it felt crisper with more torque. On a long pull to redline the car was fine until 5000 rpm. Maybe I was premature removing it until I added the other parts as I did not give the ECM time to learn.
Old 01-12-2013, 01:28 AM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Auto's and manuals respond different as well from what I have read. manuals addapting easier.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 01-14-2013, 03:10 PM   #11
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
I'll give the 90mm tb a shot. Buddy of mine is giving me one so no worries if it doesn't work with this setup.
Old 01-31-2013, 01:34 PM   #12
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
