ADM PERFORMANCE
Old 01-12-2013, 01:34 AM   #1
Wuiquen
Wuiquen's Avatar
Drives: 2011 Summit White 2LT/RS
rear speaker replacement
I have a BA amp system. Want to change the rear speaker. Can someone who did this advise me on how to? Do i need a special wire connector? I have the thread.to get to them. All i need is help with the wires. The connectors that the factory speakers have wont work with aftermarket, will they?
Wuiquen is offline   Reply With Quote
Old 01-12-2013, 05:56 AM   #2
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
na wont work with aftermarket... I do all kinds of wiring.. I am in maintenance for a living.. let me save you a headach. ********.. I spent 4 hours on this the first go around then wound up running new wire to the rear speakers from my amp... dech rear speaker has a 4 pin connector.... they are 2 ohm.. the wiring digrams are at the top of the page in a sticky
mgoodbar is offline   Reply With Quote
Old 01-12-2013, 06:47 AM   #3
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
http://www.camaro5.com/forums/showth...=rear+speakers
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 01-12-2013, 09:58 PM   #4
Wuiquen
Wuiquen's Avatar
saw that but they dont really talk about how to wire the rear speakers if you have a BA system.. Does ******** have a adapter to go on the factory connections??
Old 01-13-2013, 02:36 PM   #5
mgoodbar
Drives: 2010 L99
yea he has some. get his mounts too
Old 01-14-2013, 07:13 PM   #6
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
I'm working on replacing my rear speakers as well and was thinking about just running wires straight from my amp to the speakers. Did you have any issues with leaving the factory clip off?
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust
Whos_Drivin is offline   Reply With Quote
Old 01-14-2013, 11:36 PM   #7
Wuiquen
Wuiquen's Avatar
Im pretty sure no issues. I just want to retain bakup sensor.. are u using FARK or running the amp from the HU?
Old 01-15-2013, 06:18 AM   #8
Whos_Drivin
I'm using the ******** fark. I have the odoor speaker harness, but I didn't get the rear 6x9 harness because my amp will be right there and I could just run speaker wire. Now I'm second guessing my decision...maybe I should have just got the rear harness too...
Old 01-16-2013, 06:55 PM   #9
Wuiquen
Wuiquen's Avatar
Why??
Old 01-16-2013, 07:04 PM   #10
Shu71
Drives: 2011 Camaro RS M6
Wuiquen, Are you wanting to keep the factory amp and only replace the rear speakers?
Shu71 is offline   Reply With Quote
Old 01-16-2013, 07:05 PM   #11
Steve@Subthump
Drives: 2011 2SS IOM Vert
I would not recommend changing any speakers while keeping the stock amp.
If you swap out the amp using our fark kit, it comes standard with two x2A rear speaker harnesses; that normally go in-line of the factory 6x9 speaker. But if you change the speakers, just cut the end off each x2a and wire to the aftermarket speaker.
Steve@Subthump is offline   Reply With Quote
Old 01-17-2013, 12:06 AM   #12
Wuiquen
Wuiquen's Avatar
Not really.. i want to change amp and speaker.. u see i have two amps sittinv in a box and like three sets of 6x9 5 way speakers. So if i am gonna do the speaker i want new amp too.
Old 01-17-2013, 12:08 AM   #13
Wuiquen
Wuiquen's Avatar
Steve, would i be ok using a 5 way speaker with an aftermarket amp? I would figure those rear speaker once i swap the HU and amp wont be biamped no more.. honestly i want to just have high from them.. planning on setting the amp to not have any lows whatsoever.. i will be addinv two subs with steves new ported box.
