Old 06-12-2009, 07:46 AM   #1
pkurtziii
Drives: Camaro 2010 1LT - RS
What Mods void warranty?
Does anything other than the GM accessories exhaust/intake not void the warranty?
pkurtziii is offline   Reply With Quote
Old 06-12-2009, 07:53 AM   #2
canadianiroc
SUPPORT THE DETROIT 3
canadianiroc's Avatar
Drives: 1985 IROC-Z28
GM can only void warranty if the aftermarket part damages what you want warranty on . Lets say your radio breaks , well GM cant say sorry your warranty is void because you have an aftermarket exhaust. If you add NOS and you blow your motor then yes you have voided your warranty
http://uscode.house.gov/uscode-cgi/f...(2302))%3ACITE
Camaro IROC owner / enthusiast . Dodge worker and owner / enthusiast. I love American MUSCLE
canadianiroc is offline   Reply With Quote
Old 06-12-2009, 08:11 AM   #3
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
Shortcuts can slow you down...
Chevyrocker is offline   Reply With Quote
Old 06-29-2009, 10:08 AM   #4
cuspid
Drives: 04 z06 yellow
I heard a fellow that put in an aftermarket radio and they voided his warranty some dealers are anal.
cuspid is offline   Reply With Quote
Old 06-29-2009, 11:01 AM   #5
CamaroHutch
CamaroHutch's Avatar
Drives: 2010 Camaro 2SS RJT
Thats not anal, but illegal (Unless their was a fire, or something electrical caused by the aftermarket radio). Laws are in place to protect you from this situation
Ordered Jan 09
2SS RS RJT
Delivery?? 5/27/09 #10630
AFTERMARKET:
Hurst STS
Borla ATAK Catback
CamaroHutch is offline   Reply With Quote
Old 06-29-2009, 06:16 PM   #6
CTS
Drives: 2015 Sierra Denali 6.2L CC 4WD
fyi.................
Identifying Aftermarket Non-GM Calibrations
By Blog Admin on February 1, 2009 7:17 PM | No Comments
For more details, refer to bulletins 08-06-04-033 (Gasoline Engines) and 08-06-04-006A (Diesel Engines).
General Motors is identifying an increasing number of engine, transmission and catalytic converter part failures that are the result of non GM - aftermarket engine and transmission control calibrations being used.
When alteration to the GM released engine or transmission control calibrations occurs, it subjects powertrain and driveline components (engine, transmission, transfer case, driveshaft and rear axle) to stresses that were not tested by General Motors. It is because of these unknown stresses, and the potential to alter reliability, durability and emissions performance, that GM has adopted a policy to cancel any remaining warranty coverage to the powertrain and driveline components, whenever the presence of a non-GM / aftermarket calibration is confirmed -- even if the non-GM control module calibration is subsequently removed.
Warranty coverage is based on the equipment and calibrations that were released on the vehicle at time of sale, or subsequently updated by GM. That's because GM testing and validation matches the calibration to a host of criteria that are essential to assure reliability, durability and emissions performance over the life of the warranty coverage and beyond. Stresses resulting from calibrations different than those tested and released by GM can damage or weaken components, leading to poor performance and or shortened life.
Additionally; non-GM-issued aftermarket engine control modifications often do not meet the same emissions performance standards as GM-issued calibrations. Depending on state statutes, individuals who install engine control module calibrations that put the vehicle outside the parameters of emissions certification standards may be subject to fines and / or penalties.
GM service bulletins 08-06-04-033 and 08-06-04-006 outline procedures to identify the presence of non-GM / aftermarket calibrations. GM recommends performing this check whenever a hard part failure is seen on internal engine or transmission components, or before an engine assembly or transmission assembly is being replaced under warranty. It is also recommended that the engine calibration verification procedure be performed whenever diagnostics indicate that catalytic converter replacement is indicated.
In February 2009, PQC will begin piloting a process to confirm the ECM calibration is GM-issued. Beginning in February, PQC will require a picture of the engine calibration verification screen, as outlined in the bulletin, before authorizing any V8 engine replacement (both Gas and Diesel). (fig. 19)
If a non-GM calibration is detected by the dealership, follow the procedures outlined in the bulletin. Once documentation of the non-GM calibration has been received, and verification has taken place through GM, the remaining powertrain and driveline warranty will be cancelled and noted in VISS, and the dealership will receive the following notification:
Based on information that has been received, please inform the customer that the Powertrain portion of the New Vehicle Warranty is no longer in effect for the engine, transmission, driveline and rear axle on VIN XXXXXXXXXXXXXXXXX, due to the presence of non-GM calibrations and / or equipment. The stresses resulting from the non-GM calibrations and / or equipment were not validated by GM and therefore cannot be warranted on any components that are subject to those stresses. Repairs to powertrain or driveline components that may currently require repair should not be covered under the terms of the new vehicle warranty. The warranty group has been advised of this information and VISS will be updated accordingly.
- Thanks to Jay Dankovich
Mike
2015 GMC Sierra Denali 6.2L 1500 CC Standard Box 4x4
Synthoil Supply
CTS is offline   Reply With Quote
Old 06-29-2009, 06:26 PM   #7
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
What this essentially means (to me at least) is no tunes other than a piggy back, and be careful what other mods you do. A CAI is easily reverted to the OEM intake. Long Tube headers - not so much (though shorties you may be able to swap out without too many problems).
Basically - for mild modifications you should be alright. After that - proceed with caution. We should have it easier because they also seem to be targetting V8s for the most part, but...
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 06-29-2009, 06:30 PM   #8
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Very interesting... I know nothing about GM tuning... but in the Ford world if you put the computer back to stock Ford could only tell the computer had been reset (disconnecting the battery reset the computer too). Ford could not tell that you actually had a aftermarket tune in computer... Could GM still tell if you put the computer back to stock (assuming GM tuners have this ability). What's the typical cost of a "blank" GM computer?
scrming is offline   Reply With Quote
Old 06-29-2009, 06:32 PM   #9
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
I don't think any of our mods here can void the warranty on your car.....unless you are dumb enough to let them drive it!
patriotpa is offline   Reply With Quote
Old 06-29-2009, 06:42 PM   #10
Xanthos
PWA Relapse
Xanthos's Avatar
- X
Old 06-29-2009, 06:50 PM   #11
HaveBlue
HaveBlue's Avatar
Drives: CTS/CAMARO
If a dealer says your warranty is voided for a legal replacement aftermarket part, ask them to put it in writing. They tend to back right off. SEMA also has people that will help you out and contact the dealer. Usually works best to get a hold of the manufacturer and have them contact SEMA.
HaveBlue is offline   Reply With Quote
Mods and warranty E-wing Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 44 11-09-2011 11:36 PM
Will the V6 have DBW or a good old fashioned cable throttle? theholycow Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 41 08-02-2009 08:25 PM
will adding after market headers void warranty? lakersftbl69 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 05-26-2009 01:07 AM
Lifetime Powertrain Waranty....from Chrysler?!!? Mr. Wyndham General Automotive + Other Cars Discussion 22 08-16-2007 04:16 PM
GM Adds Used-Car Powertrain Warranty KILLER74Z28 General Automotive + Other Cars Discussion 3 02-06-2007 07:56 AM
