Solo Performance
Old 01-12-2013, 01:12 PM   #1
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
TT in bay
We seen and talked about this before right?
KalCorp is offline   Reply With Quote
Old 01-12-2013, 01:40 PM   #2
blackTT600
Drives: 2011 2LT M6 SC
this is the one from SEMA 09 I believe, never ran from my understanding of it.
blackTT600 is offline   Reply With Quote
Old 01-12-2013, 02:54 PM   #3
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Yes we've seen and talked about that build before. it's still a cool looking concept.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 01-12-2013, 03:04 PM   #4
KalCorp
Space Coast Camaros
KalCorp's Avatar
Okay I wasn't sure if this is the same one or not. Thanks
Old 01-12-2013, 03:13 PM   #5
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
I want to see this car running already. But I see them turbos causing a lot of damage because of location.
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
Old 01-12-2013, 03:35 PM   #6
SC2150
The heat on any underhood mount is horrendous. Looks cool, but man is it hard on everything.
We do both mid mounts and underhood mounts for most any application if anyone wants this.
Old 01-12-2013, 05:30 PM   #7
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Right near the engine and radiator? Ehhh not the best design imo...lol
DarkneSS is offline   Reply With Quote
Old 01-12-2013, 06:31 PM   #8
Macrackie
Macrackie's Avatar
Drives: 2011 Camaro LS Stripper model
Love the look. Kinda like the IN YOUR FACE TT when you pop the hood. Enough heat to blister the hood? Now that gretchen has made big numbers with the lfx someone might build one like this that runs.
Are there water cooled turbos?
Macrackie is offline   Reply With Quote
Old 01-12-2013, 11:03 PM   #9
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
There are air, oil, and water cooled turbos. But that doesn't matter, the hot side of the turbos are meant to run extremely hot. This is because of the exhaust that powers the turbo.
Old 01-13-2013, 01:16 AM   #10
Macrackie
Macrackie's Avatar
Yeah I never really learned much about turbos. On the water cooled turbos would the only super hot part be the exhaust piping? Or would the body still be smoking hot?
Old 01-13-2013, 01:26 PM   #11
OKCwhiteKnight
OKCwhiteKnight's Avatar
Drives: 2010 2LT RS Camaro 2015 Colorado
ZL1 style vents would be right above or pretty close,to those turbo's. They look like they are mounted awfully high,maybe they can go lower and not so close to hood and eng. cover,but then again the ZL1 vents direct water to where the turbos are located.
OKCwhiteKnight is offline   Reply With Quote
Old 01-13-2013, 01:28 PM   #12
SC2150
No, the hot side that the exhaust gasses run through to spool the turbos gets red hot under boost and yes, it can and does blister or discolor hood paint as well as cooks power steering fluid, etc. It is for looks alone and the only advantage is the oil return does not need a scavenge pump.
For any that want, we do ANY configusration of turbo for most any vehicle on the road, so if someone wants this call and schedula....but be aware of the heat issues. Power will be excellent and a turbo blanket and ceramic coated hot side pipes will help a tone as well as a good head extractor hood.
