BORLA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 01-12-2013, 11:54 PM   #1
ZL12013
ZL12013's Avatar
Drives: 2013 ZL1 & 2005 F150
Tire air pressure, would like other opinions.
I know the tires are suppose to be at 32 psi cold but when I take the car out on a cold day the tires are usually around 29-30 psi. After driving a very short distance, 6-10 blocks they immediately climb to 32 psi, eventually as high as 33-34 psi as they warm up.
My question is if I inflate the tires to 32 psi at their coldest point after sitting for several days, once I start driving are they actually over inflated.
For example yesterday and today the temperature stayed in the 50's overnight and when I started the car this morning the tires were showing 32 psi cold, if I added air last week they would had been at 34-35 psi. I was just curious what other people thoughts about this was.
ZL12013 is offline   Reply With Quote
Old 01-13-2013, 12:53 AM   #2
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
Not really a big deal for me as I run 34 cold. "Who stated they were overinflated"? Tire pressures will vary, did you watch the video regarding the ZL1 and tire pressures during track useage? Are you feeling a difference while driving with more tire pressure?
ZL1-V is offline   Reply With Quote
Old 01-13-2013, 01:41 AM   #3
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
I am 28-29psi cold at track. After one session, im close to 40psi. There gonna fluctuate with cold/heat....no biggie.
69NMYSS is offline   Reply With Quote
Old 01-13-2013, 01:45 AM   #4
ex-SS-ve
ex-SS-ve's Avatar
I find that 36 psi on mine is just perfect.
ex-SS-ve is offline   Reply With Quote
Old 01-13-2013, 09:26 AM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I run at 34 cold, I like the feel better and don't get all that scruffing noise when I back out of the drive.
Old 01-13-2013, 10:14 AM   #6
AKA-51
Drives: Ellie
i was told to run @ 36 psi cold
AKA-51 is offline   Reply With Quote
Old 01-13-2013, 11:17 AM   #7
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
32 cold would be ideal for me for street use. On a road course 38-40 max for steet tires.
sammyv is offline   Reply With Quote
Old 01-13-2013, 11:19 AM   #8
sammyv
sammyv's Avatar
Just looked at my rear tire it say 51 psi max.
Old 01-13-2013, 12:08 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
The SS 20" wheels (P Zero tires) are recommended to run 36 PSI when cold.
The ZL1 and 1LE tires (Goodyears) are recommended at 32 PSI when cold.
Click to view my build thread
Old 01-13-2013, 12:15 PM   #10
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Better gas mileage and they will last longer over inflated
Skylane765 is offline   Reply With Quote
Old 01-13-2013, 12:28 PM   #11
Les7311
Les7311's Avatar
Drives: 45th Anniv, 2SS, LS3, '07 M109
Send a message via Yahoo to Les7311
Adding to this thread........
I will get a "thump" "thump" roll noise in tire when i drive, after sitting for at least 2 weeks......
Is this normal? Any remedy? Car is now in winter mode until March.....
..eventually the noise goes within a mile or so.....
Les7311 is offline   Reply With Quote
Old 01-13-2013, 12:41 PM   #12
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
I run 34lbs PSI cold. Cold being 50° outside, with the cement driveway at 41° (checked it with my laser thermometer)..
@ 34lbs PSI the tires will get to 38lbs PSI at highway speeds.. @ 38 lbs PSI I am getting what I consider to be the best performance from the tires, both in terms of grip and MPG.
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 01-13-2013, 01:04 PM   #13
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
Yes...P Zeros tend to get a flat spot when sitting for a while and cold. It does go away after driving a bit and the tire warms up some. Not sure of a remedy, I chose not to store it.
MYDLIFECRISIS is offline   Reply With Quote
Old 01-13-2013, 01:29 PM   #14
Les7311
Les7311's Avatar
Thanks MYDLIFE......
