Emblempros
Old 01-30-2013, 12:19 AM   #15
mlee
Moderator
mlee's Avatar
Drives: 2016 Silverado
Originally Posted by Modern07 View Post
Added 2 Aeroforce Interceptors with ZL1 faceplates to the A Pillar today - hooked up to the OBDII Port - these things are awesome and can scan absolutely loads - I have also programmed in the shift lights
Very nice... I've had this one on the back burner for a while. Glad you're happy with it.
Old 01-30-2013, 12:35 AM   #16
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
Thanks - I'd seen them a while back after somebody had installed but never followed through, and then there was a thread a few weeks ago posted that brought them back into my thinking again.. it makes it a lot easier to see the Boost now that's for sure!
And I will add the input for AFR eventually too once I start adding more power and need to keep a closer eye on it.
Got some more Engine Bay Stuff on the way too - it's an expensive habit this mod thing!!
Modern07 is offline   Reply With Quote
Old 01-30-2013, 12:08 PM   #17
Behic2320
SoCal HT5 COTW 4/21/13
Behic2320's Avatar
This is one bad ass camaro my man, you are one lucky guy
Old 01-30-2013, 01:33 PM   #18
Modern07
Modern07's Avatar
Thanks - and I am indeed!
Old 01-30-2013, 01:56 PM   #19
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Have you thought of maybe painting the zl1 badges like you did the one on the strut tower brace? I think it would look amazing!
Old 01-30-2013, 02:05 PM   #20
Chevyman2
Chevyman2's Avatar
Drives: 2014 C7(awaiting delivery)
I have to agree sweet ride...." That's the car I want when I grow up"
Chevyman2 is offline   Reply With Quote
Old 01-30-2013, 02:09 PM   #21
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
Badass ride! Exactly how I would order a ZL1 if I ever did!!! And excellent mods you've picked as well!
Engine bay looks 2039840984029845098594308593858340589 times better!!!
hightower is offline   Reply With Quote
Old 01-30-2013, 09:57 PM   #22
Modern07
Modern07's Avatar
Thanks All
I'm not finished with the cosmetic mods yet, still got a few ideas I'm playing around with
Also installed a Mild to Wild switch and have it programmed into the homelink buttons.
As for the ZL1 badges and the Camaro Badges - I'm still thinking about what to do with those - depending on which direction I go will determine how I change them out - but they will be changed eventually
Old 01-31-2013, 12:46 AM   #23
SSmokinSS
Get Some
SSmokinSS's Avatar
Drives: 2014 ZL1 6Speed
Looking sweet! No doubt what trim level it is!
SSmokinSS is offline   Reply With Quote
Old 02-16-2013, 12:47 PM   #24
Modern07
Modern07's Avatar
So I had it on the Dyno today - 526rwhp and 510ft/lbs Torque
Old 03-09-2013, 08:40 PM   #25
Modern07
Modern07's Avatar
Added a few bits and pieces over the last few weeks.
Some Showstopper items which I love:
Also had Lupe paint me some Strut Brace Bolts white as the silver ones just didn't look right with the black and white theme I have going on
Then I bought a wire harness cover from Billet Custom:
Also added some Ceramic Brake Pads to try to cut down on the level of Dust:
After that decided I wanted to add a little bit of light under the hood for whenever I have the car at a show after dark - nothing too much just a strip under the strut brace.
This is wired to a switch mounted to the back of the fuse box so very hidden:
Old 03-19-2013, 09:41 PM   #26
Jferrell88
Jferrell88's Avatar
Drives: black 2ss/rs
your car is sick you just became my inspiration
Jferrell88 is offline   Reply With Quote
Old 03-19-2013, 10:01 PM   #27
Modern07
Modern07's Avatar
Thanks!!
That means a lot to me
If you have any questions on anything just let me know and I'll be happy to help
Old 03-22-2013, 09:23 PM   #28
Modern07
Modern07's Avatar
So - followed the lead of loads of others on here and Flocked my A Pillar Pod.
Once flocked sprayed it with some Black Fabric spray to make it darker to match the interior a little better (It was much lighter originally)
Very happy with the result - way better than the black plastic look.
Also flocked my passenger side A Pillar
