Old 01-14-2013, 12:03 PM   #15
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
Thanks for the wright up. It would be great to see the schematic
IOM Black Diamond is offline   Reply With Quote
Old 01-14-2013, 02:10 PM   #16
dkp2LT
dkp2LT's Avatar
Drives: '10 2LT/RS, '13 GT/CS, '10 Flex
Excellent job.
dkp2LT is offline   Reply With Quote
Old 01-14-2013, 06:37 PM   #17
whitedemon
whitedemon's Avatar
Drives: 2010 Camaro SS
Here is the schematic and parts list off to the side, enjoy 😏Name:  ImageUploadedByTapatalk1358210218.535672.jpg
2010 Camaro 2SS/RS, L99, OBX Longtube Headers, Magnaflow 3in Comp Cat Back w/ added Dynomax Bullet Race Mufflers, SCT Tuner w/ JRE Tune, CAI Black Intake w/ JRE Race Scoop, Eibach Pro Springs, Custom Sequential Tailights
whitedemon is offline   Reply With Quote
Old 01-14-2013, 08:57 PM   #18
IOM Black Diamond
HT5 COTW 1/21/13
Thank you for posting the schematic now I have to go shopping
Old 01-14-2013, 11:04 PM   #19
SimpleGreen
Drives: 2013 1SS/1LE IOM
That is freakin cool. Totally visiting Radio Shack this week.
2016 Jeep Wrangler Willys 2DR
2013 Camaro SS/1LE SOLD 4/27/16
SimpleGreen is offline   Reply With Quote
Old 01-15-2013, 07:21 AM   #20
whitedemon
whitedemon's Avatar
as a note to anyone tryin to build this, use a chip socket for the 555 timer. Those little timers are very heat sensitive and the soldering iron will melt the inside of it very fast. The first one i built was ok but the second would only work intermittently, after messing with it a few min we realized what went wrong. the shack sells a 2 pack of the chip sockets for 99 cents. well worth it! Also the variable resistor is set in the middle when you buy it and that is a little much delay so the lights wont work at all, after you wire it in turn the resistor all the way to the left which should be zero delay and start from there turning to the right until you get the desired delay.
Old 01-15-2013, 09:36 AM   #21
Jason@Phastek Performance
Jason@Phastek Performance's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek Performance
That is really awesome. Good Job on the post. Going to Radio Shack myself and trying this.
Jason@Phastek Performance is offline   Reply With Quote
Old 01-15-2013, 02:50 PM   #22
a.morblu
a.morblu's Avatar
Drives: 2011 Sinister SS
This is great! And to think there is a 500% mark up on assemblies that do this exact thing... Crooks.
a.morblu is offline   Reply With Quote
Old 01-16-2013, 01:01 PM   #23
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
that is a sweet setup, and great idea btw...looks good.
does anybody know the current draw of the lights? working on using a transistor (mosfet) as the switching portion vs the relay. i could go out and measure it, but its a little wet out right now.
thanks.
hapisok is offline   Reply With Quote
Old 01-16-2013, 01:28 PM   #24
MGD
MGD's Avatar
Drives: 16 Camaro SS
Ohms Law comes in handy sometimes.
I=P/V
25 Watt bulb/12 Volts =2.08 A
5 Watt bulb/12 Volts = 0.41 A
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 01-16-2013, 02:00 PM   #25
hapisok
hapisok's Avatar
so what your saying is...
i kid i kid.
thanks, i've got a mosfet that should work with the max being 4A. i'll check it out.
Old 01-16-2013, 03:12 PM   #26
LowFlyer
LowFlyer's Avatar
Drives: 2013 2SS/RS Hurst G/FX AGM
Originally Posted by whitedemon View Post
My timers have 3 wires, ground, input and output. So i tapped in the outer light bulb ground for the ground wire and then cut the blinker bulb wire which was the yellow for left side and green for right side and installed the input-output wires to the bulb harness, all with solder and heat shrink joints of course. Then i turned on the hazard lights and used a pocket screwdriver to adjust the varable resistor until the delay was right where I wanted it. I was very pleased with the outcome of the project and I saved 80 bucks also
You stated and I see that there are three wires, but your schematic looks like there should be 4. Positive and negative (directly below the positive, I presume) and there looks like two connections from the normally open contacts from the relay. Am I missing something?
Thanks.
C.R.
(the Invisible Poster)
LowFlyer is offline   Reply With Quote
Old 01-16-2013, 03:38 PM   #27
hapisok
hapisok's Avatar
Thanks.
C.R.
share the common ground and switch the positive side of the circuit (tail light) through the relay.
Old 01-16-2013, 03:49 PM   #28
whitedemon
whitedemon's Avatar
thanks.
yeah if i was to build again i would use a transistor instead of the relay, would make it a little bit smaller and less app to go out i would think. But the relays was free and i knew they wouldnt have a problem with the current
