Old 01-14-2013, 02:13 PM   #1
Cam8
Cam8's Avatar
Drives: 2014 Gray Camaro 2LT RS
Halo l.e.d.
Is there an easy way to swap the led in the halo and make them brighter? I have the gen5diy.com harness so that they are always on and just want something brighter
2014 Gray 2LT RS, 6M, Eibach Spings, Green Grill Light and Footwell Lighting
Cam8 is offline   Reply With Quote
Old 01-14-2013, 02:22 PM   #2
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
That would require you to remove the lights and open them up. not an easy task unfortunately. Most people just swap the Halo all together since they are opening the whole headlight anyway.
christianmotox is offline   Reply With Quote
Old 01-14-2013, 02:29 PM   #3
camaro_RS
Emerald Coast Camaros
camaro_RS's Avatar
Drives: A lot of show, not much go.
When you install JPD's colorshift halos you remove the factory LED and replace it with a multi-color LED. Don't see why you couldn't just put a brighter white LED in there if you could find one that is designed to fit in there.
Also, when you do that you do not have to bake open the headlights...which is nice.
-White Mary Jane....build thread [COTW 6/11/12] :
camaro_RS is offline   Reply With Quote
Old 01-14-2013, 02:34 PM   #4
christianmotox
Drives: ( . )( . )
Did you replace the Halo LED with out having to Pry open the housing?
Old 01-14-2013, 02:46 PM   #5
camaro_RS
camaro_RS's Avatar
Yeah. You unscrew the back part (there are 3 screws) and get to it from there. It's a small opening so you have to use a couple different tools but it wasn't too terrible.
Old 01-14-2013, 02:50 PM   #6
christianmotox
Drives: ( . )( . )
that's cool, i didn't knew that.
I changed the whole Halo on mine so i had to pry open them.
Old 01-14-2013, 04:11 PM   #7
CrzyGamr2
Mid-Florida Camaro Club
CrzyGamr2's Avatar
Drives: 2011 2LT/RS
I wanna do this too because my fog light halos are brighter than my RS ones. Does anybody know who sells a brighter replacement LED? And possibly a write up to swap them out?
CrzyGamr2 is offline   Reply With Quote
Old 01-14-2013, 05:36 PM   #8
CodyBanks
CodyBanks
Drives: 2011 Camaro
AAC sells them
http://www.automotivelightstore.com/...allcolors.aspx
You could pick what ever color you want. I guess in your case just white
CodyBanks is offline   Reply With Quote
Old 01-14-2013, 06:54 PM   #9
camaro_RS
camaro_RS's Avatar
Originally Posted by CodyBanks View Post
AAC sells them
But you still have to bake open the light and replace the halo.
Old 01-14-2013, 07:32 PM   #10
C586
Drives: 2011 Camaro LS
AAC sells them
He is probably looking for something with some sort of quality. He won't get that with a AAC product. I would replace the led with something from oznium or superbrightled.
C586 is offline   Reply With Quote
Old 01-14-2013, 07:38 PM   #11
CrzyGamr2
CrzyGamr2's Avatar
Drives: 2011 2LT/RS
I actually have quite a few AAC products installed on my car already and have nothing but positive things to say about them, so yea.
Thanks for the suggestions though, cause I really want to make the RS halos brighter.
From my Camaro covered iPhone.
Old 01-14-2013, 09:34 PM   #12
Gator6977
Gator6977's Avatar
Drives: 2011 2LT RS
You just need either a 3w or similar led. Search the diy section for pictures and details.
Gator6977 is offline   Reply With Quote
Old 01-14-2013, 10:01 PM   #13
C586
Your like 1 out of 4 or 5 that have had good luck with their crap. Your a lucky man. Good luck with the upgrades. Idk if you will need to get your own resistor or if the voltage is already regulated.
Old 01-14-2013, 10:19 PM   #14
CrzyGamr2
CrzyGamr2's Avatar
Drives: 2011 2LT/RS
Which is what I don't want to do. Rules those out.
