SDTW Custom Wheels & Tires
Old 01-14-2013, 05:01 PM   #1
Rainman1
Drives: 2013 ZL1
Corsa Exhaust
Anyone know the weight of the Corsa exhaust vs the stock ZL1 exhaust. Also interested in fit, finish, installation issues, etc.
Thanks
Rainman1 is offline   Reply With Quote
Old 01-25-2013, 02:29 PM   #2
lsaterz28
the vetteman
lsaterz28's Avatar
Drives: 68Z/28,09G8/GT,11RS/SS VT,13GMC PU
we do not own ZL1, we have 2011 RS/SS Convert with factory ground effects, Corsa # 14963 sport cat-back with XD-Crossover, 3.5" pro-series tips (auto trans) for use with factory ground effects. this looks great easy install with all cross brace under the Vert. Not sure of Wt. but can't be more then stock unit. Maybe Corsa can give you info for your ZL1.
Good luck with your car. Maybe we will see you in INDY.
We can install any mods you want at www.raymondspreformance.com
lsaterz28 is offline   Reply With Quote
Old 01-26-2013, 02:22 PM   #3
Rainman1
Drives: 2013 ZL1
Thanks for the info. Sounds like the quality, fit and finish of the Corsa is good. Hoping to get some feedback on the weight of a stock ZL1 exhaust vs a Corsa full 3 inch cat back exhaust. A HP and Torque increase would also be great even if it were small. As long as there was a weight savings.
Old 02-09-2013, 08:59 PM   #4
Catfish
Catfish
Catfish's Avatar
Drives: 2012 Camaro ZL1 #361
Installed my CORSA Cat-Back today. Didn't weigh either the stock or new pipes but the CORSA seems lighter. It's kinda hard to tell since the stock pipes are full one piece and the CORSA comes in 6 pieces plus the two mufflers. The quality is outstanding! Fit was perfect, installation was pretty easy, could have done it by myself but my brother helped out some. I love the sound. No louder than stock at normal speeds (I had the fuse out) but really bellows at WOT!!
2012 ZL1 VIN# : 361
DELIVERED ON 4-12-12
Victory Red, Alum Wheels, Manual, Carbon Fiber Mohawk
Performance Mods to Date:
Rotofab cold air intake, Kooks 1 7/8" LT headers w/ Calico KoolBlack ceramic coating, Kooks high flow cats, Corsa 3" X-pipe cat-back exhaust, 160 degree thermostat, 2.50" Supercharger Pulley, PCM Catch Can, Rotofab Supercharger Reservoir, 1000cc Injectors, MSD Boost-a-Pump,Tuned by PCM of NC
604 RWHP & 622 RWT !!
Also, 2001 Silverado Z71, Pewter w/ Extended Cab & 2013 Chevy Cruise LTZ/RS White
Catfish is offline   Reply With Quote
Old 02-09-2013, 09:22 PM   #5
Rainman1
Drives: 2013 ZL1
Thanks for the info. How was the clearance around the diff cooler lines? If its easy for you to weigh the stock system, the info would be much appreciated. If its hassle don't sweat it.
Old 02-09-2013, 09:52 PM   #6
Catfish
Catfish
Catfish's Avatar
Clearance was OK. At least a 1/2 inch. Put my old pipes in the attic of my shop (rafters) with great difficulty. Sorry but I can't weigh them from there.
2012 ZL1 VIN# : 361
Old 02-09-2013, 10:03 PM   #7
Rainman1
Drives: 2013 ZL1
No prob. Thanks again for the info on the diff lines. 1/2 inch should be good.
