Old 01-16-2013, 04:04 PM   #15
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
All the current FI kits make good power. Just have to decide what's your flavor.
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
Old 01-16-2013, 04:14 PM   #16
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
Not sure if the V6 cars have a keyway in the crankshaft, but if not hopefully all you guys going supercharged are pinning your cranks. If not the crank will spin on the crankshaft.
Chris
Chris-HPS is offline   Reply With Quote
Old 01-16-2013, 04:36 PM   #17
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Some more than others
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 01-16-2013, 04:49 PM   #18
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Indeed sir indeed lol. Cant wait for the new updates.
Old 01-16-2013, 04:50 PM   #19
GretchenGotGrowl
Soon, still dealing with that damned baffle on the valve cover. Aaron had to completely redesign the evac system to keep from pulling all the oil out of the engine through the valve cover.
Old 01-16-2013, 05:21 PM   #20
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
no pin. But I keep an eye on the pulley just incase. I think the belt will slip before the pulley spins
Old 01-16-2013, 10:27 PM   #21
simt3k
Drives: 2011 Camaro RS 2LT
Originally Posted by SC2150 View Post
We have customers install in their driveway in 1-2 days, but have some unreal installed specials going on right now....give us a call for details as you close.
Here is the latest with free install, and you get the tuning suite and cable to KEEP as well as the tune:
That is beautiful!!!!!!!!!!!!
Is that the roots blower for us V6'ers <3 ?
simt3k is offline   Reply With Quote
Old 01-17-2013, 07:37 AM   #22
Camaro V6 090692
Drives: 2010 chevrolet camaro v6
I might just wait for a blower system to come out for the LLT. Idk how power will match the turbo systems or the centrifugal supercharger kits though. I really would like to do twin turbo but everyone says they are a lot of maintenance but..... turbos can make a lot more power than a centrifugal supercharger and probably a blower from what
I've seen and read.
Camaro V6 090692 is offline   Reply With Quote
Old 01-17-2013, 08:11 AM   #23
GretchenGotGrowl
I've seen and read.
The problem you are going to run into is tuning the Bosch ECU. We pushed my old LLT to the ragged edge to get a consistent 450 RWHP; at 500 RWHP we started breaking stuff. That was no kit, it was custom built with a lot of stuff that wouldn't be in any kit. So, just because turbos can make more power doesn't mean you will actually see that power. Heck, with my LFX I'm probably at less than 70% of the turbo capacity but can't pump more fuel to it.
Basically, what I'm saying is if you are looking for a kit, don't let the potential power inform your decision. All of them will probably hit the same limit on the LLT. Instead, focus on when the power is made in the RPM range, reliability and price. If you want a beast, then don't buy a kit; have someone build you a custom solution.
Old 01-17-2013, 09:10 AM   #24
Camaro V6 090692
Is there not a way to put a different ECU on the car? I've seen it done with other cars. and say i went with a kit... what would be the best all around kit to buy?
And having someone build a a custom kit gets pretty costly... I've heard talks of 10K for custom and like 5-7K for a pre-built kit but that's another 3-5K more for maybe 50 HP more than what i can really pull out of this car.
Old 01-17-2013, 09:20 AM   #25
GretchenGotGrowl
We couldn't find a cost effective way to replace the ECU, which is why I traded for a 2012. Most of the wiring harness needs to be replaced, plus you have to sync it with all the other computers and get the VIN matching done. Not very pretty.
I'm not a good one to ask about the kits because I never had one. Mine was the first twin turbo LLT and some of what was learned then when into the RX kit. Never had a kit so I can't really tell you much about any of them except to say don't set your HP desires too high. They will make more power than the stock L99 and LS3, but you won't have the lowend torque on the superchargers.
Take a look at the FI List (sticky at the top of the V6 forced induction section) and look what people are running. Then PM them for details.
Old 01-17-2013, 09:26 AM   #26
Camaro V6 090692
Alright i will do that. Thanks and don't superchargers usually make more TQ than other FI setups?
Old 01-17-2013, 09:30 AM   #27
GretchenGotGrowl
Depends on the supercharger. Roots style superchargers can perform as well as turbo (better if the turbo isn't sized properly), but centri superchargers build boost linearly with RPM, so they don't provide enough air flow to give you the lowend torque to match a LS motor.
Old 01-17-2013, 10:05 AM   #28
Camaro V6 090692
Ah ok i see what your saying now. Btw What size turbo's are you using?
