SDTW Custom Wheels & Tires
Old 01-16-2013, 03:43 PM   #1
jfayardiii
Drives: 2011 Silver 2SS/RS L99
Torque Converter Question
I have a Yank converter rated at 3200rpm. When the car is at WOT, the 2-3 shift feels like it has a hesitation in fully engaging. Its like it engages and then slacks off ever so slightly then fully engages.
Is this normal? It may be doing it in other gears but I dont feel it as much as I do in the 2-3
2011 2SS/RS L99
10.76@130.5 1.67 60'
LG headers and exhaust, 3200 Yank, EPS Cam, D1SC Procharger, all work performed by Blanchard Performance
jfayardiii is offline   Reply With Quote
Old 01-16-2013, 07:13 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Could be tuning, could be low fluid.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 01-16-2013, 07:30 PM   #3
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Could be as simple as the shift point is set to high and its dragging while holding onto the power, or could be in the tune.
If your using HP Tuners,
Make sure your TCC desired tables are Zero'd out and you added TCC pressure............and bring down the shift point 200 RPMs just in case.
Tampa Tuning is offline   Reply With Quote
Old 01-18-2013, 09:54 AM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
I'd huddle up with your tuner and then make a few hits on the street. It's okay to have to change or adjust a parameter once in a while if you've made more changes.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
