HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 01-17-2013, 12:07 AM   #1
nick5210
Drives: '67 camaro
Converting from points dissy to a H.E.i
Hey guys I have a 67 camaro with a old point style distributor in it. How easy would it be to convert to a H E I? What all steps are involved in this switch? I've always wanted to do this switch but I'm not sure what it requires? Thanks for the input!
nick5210 is offline   Reply With Quote
Old 01-17-2013, 12:51 AM   #2
flyingskibiker
flyingskibiker's Avatar
Drives: Cars, Trucks, Bikes, ORVs, Planes
Send a message via Yahoo to flyingskibiker
One can buy the "breakerless" kits that convert from points to electronic. Or do you really want to go HEI? If so, I have no idea (and don't personally like those monsters). If not, the Mallory breakerless kits drop right in to your points distributor easily. Pertroniks(sp) make them, too.
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it...
Drooling over the ZL1s. It will be my next car if I can manage to pull it off...
flyingskibiker is offline   Reply With Quote
Old 01-17-2013, 07:57 AM   #3
chvyman
chvyman's Avatar
Drives: 2SS 45TH,gfx,blade spoiler,h grille
basicly you have to bypass the resistor wire that feeds the stock dist. and supply a 12 volt feed from you ignition switch to the H.E.I. unit. the stock set-up starts with 12 volts but once the start procedure is complete it goes down to 9.5 volts to run. electronic ignition needs a full 12 volts.
chvyman is offline   Reply With Quote
Old 01-19-2013, 05:27 PM   #4
MLL67RSSS
Drives: car
The Pertronix is pretty easy to install. Just remove the points and mount it where they were. There is 2nd wire that, as stated above you have to hook to a 12V source and NOT the resistor wire already there. Also have to have the Pertronix low resistance coil for it to work properly. That was the first thing I did to my car when I got it. Woke it up a little too!
http://www.pertronix.com/prod/ig/ignitor3/default.aspx
http://www.pertronix.com/prod/ig/fla..._volt_ft3.aspx
MLL67RSSS is offline   Reply With Quote
Old 01-22-2013, 10:49 PM   #5
flyingskibiker
I'm pretty sure the Mallory uses the stock resistor wire and coil.?.? I know the Unilite distributor does...
Old 02-01-2013, 08:38 AM   #6
ZL1 TIBS
ZL1 TIBS's Avatar
Drives: 1968 Camaro, 2012 ZL1
What Chvyman said about the resistor wire. After that, if you want to spring for an MSD 6A/AL ignition, it basically removes all the electronic guts from the HEI removing most of the shortcomings of that system. I had this on my 68 Camaro and it was flawless. Another point to consider is you may need to clearance the firewall to fit the cap. I used a 2X4 and sledge to move the firewall back about 1/4".
Alan Tibbetts
Aston, PA
1968 Chevrolet Camaro LS-1/T56 transplant
2012 CRT 6 SP ZL-1
ZL1 TIBS is offline   Reply With Quote
Old 02-02-2013, 10:25 AM   #7
Learjetguru
Learjetguru's Avatar
Drives: 2011 2SS LS3
I did this back in 1979 when the HEI came out. Easy mod.
1. Remove the resistor( or resister wire) and replace with standard gauge wire.
2. Install the HEI. Power wire to the BAT terminal. Install a ground wire to negative side of coil and ground.
Done.
Learjetguru is offline   Reply With Quote
Old 02-04-2013, 09:21 PM   #8
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
The resistance wire, if I remember right, had a cloth covering on it? It's been awhile since I did it.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 03-13-2013, 06:42 PM   #9
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
Yes. White cloth cover with orange and purple stripes.
Currently in the fleet... 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
