Old 01-18-2013, 11:03 AM   #1
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
Dyno Soon. Any tips?
I am going for a Dyno run in a couple of Days.
The only local shop has a "SUPERFLOW CHASSIS DYNO WITH LOAD CONTROL"
http://www.trickpro.net/ourservices/dyno-services
We have any reports of run with this setup?
I hear the Dyno's are hard to do on these V6's. What should I look for or get information on so the run is the most accurate we can get. Any special settings that need to be set correctly?
I am also going to datalog the run's and review on here with everyone. Going to check for knock and other stuff.
Thinking I should be Around 260hp or better.
BBk LT, Ported TB,Black Ice, Mrt v2, Trifecta, CAI intake
I also posted in wrong section
If anyone can move please do to "Camaro V6 LLT Engine, Exhaust, and Bolt-Ons"
KalCorp is offline   Reply With Quote
Old 01-18-2013, 12:10 PM   #2
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
My prediction is 258rwhp/253rwtq
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 01-18-2013, 12:19 PM   #3
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Since your stock you could pull off some pulls in 3rd. But do it in 4th just in case. Or do 2 in 4th and 1 in 3rd. That's what I do all the time just to see.
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
Old 01-18-2013, 12:32 PM   #4
KalCorp
Space Coast Camaros
KalCorp's Avatar
"BBk LT, Ported TB,Black Ice, Mrt v2, Trifecta, CAI intake" is considered stock?
Cool :-)
Old 01-18-2013, 12:48 PM   #5
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
The dyno is more friendly to your car than sticky tires.
Like Tracy said, it should be a 4th gear pull
Tampa Tuning is offline   Reply With Quote
Old 01-18-2013, 12:53 PM   #6
KMPrenger
KMPrenger's Avatar
Assuming the car was running optimally, and the dyno was what I'd consider spot on for drivetrain loss (which both of these almost never happen together lol) I'd consider 265ish rwhp for an auto, and 280ish for a manual to be about right.
Old 01-18-2013, 12:53 PM   #7
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
He probably didnt know what mods you had! Not in your profile that I could see!
csjcsj is offline   Reply With Quote
Old 01-18-2013, 01:45 PM   #8
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Some get dyno before any mods to see what you have stock then go from there,
Old 01-18-2013, 04:03 PM   #9
KMPrenger
KMPrenger's Avatar
Definitely the best way to do it.
Old 01-18-2013, 11:14 PM   #10
KalCorp
Space Coast Camaros
KalCorp's Avatar
Thanks everyone that give constructive information that i can use.
I will do a Datalog at same time and post it up with dyno so we can see if in fact there is any KR doing anything.
FYI this was the response i got back last week when i turned in my log for review.
"We've reviewed the log and it looks absolutely spot on. Infact, this is one of the strongest running LLT cars we've seen a log from. Whoever made those comments about the timing doesn't have any experience with tuning LLT Camaros. They have a "Ton of knock retard" even on the stock tune- this is due to the way GM calibrated how knock is reported."
Old 01-21-2013, 03:02 PM   #11
KalCorp
Space Coast Camaros
KalCorp's Avatar
2011 2LT/RS A6 Vert - 267.7 rwhp 264.6rwtq
MOD's
Cold Air Intake C.A.I
VMax Black Ice-olator
VMAX - CNC Ported Throttle Body - 2010-2011 Camaro V6 - VMAXV6TB
MRT Axle-Back Exhaust V2.0 (2010-12 Camaro V6 w/GFX)
BBK Long Tube Headers (Silver Ceramic Coated) and High Flow Cat's
Trifecta Tune
Got Extra 6wrhp with Cutouts open :-) Blue is Closed. Red is Open on Dyno
4 gear Pull's
Also you can see the Knock when doing the pulls going up to 7. Going by this is looks like the Knock is two times more then when i run the car WOT on the road! Only get 4 on WOT.
Old 01-21-2013, 03:19 PM   #12
KMPrenger
KMPrenger's Avatar
Nice Kalcorp. I'd say your HP numbers turned out just about right where I expected them, but in reality I'd think your making another 5 to 10 over that. As for TQ numbers, they are definitely high, but no big deal.
That extra timing being pulled on the dyno versus the road must make a difference, which is why I think your in the 270+ rwhp range.
Thanks for sharing!
Old 01-21-2013, 04:23 PM   #13
KalCorp
Space Coast Camaros
KalCorp's Avatar
Thanks!
Going buy 275 range and 22% loss from auto.
That about 353hp at crank
Old 01-21-2013, 06:52 PM   #14
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I can't believe some of these numbers, but it is what is unless you dyno in a wind tunnel
