B&M Racing
Old 01-18-2013, 12:33 PM   #1
12camlt
Drives: 1LT 2012
which transmission fluid now???
Ok, so I have done numerous searches and really can't find a straight forward answer.
I have a 2012 lfx motor M6 transmission. I have about 10,000 miles and I would like to do a transmission fluid change out.
GM manual says to use the GM SAE 75w90 gear oil and use 1.9 qt.
Others have said to use Royal Purple, Redline, Mobile 1 synthetic transmission fluids. - but most I have seen on here is those recommendations for either a v8 or auto transmissions.
What have others with my set up used? Happy?
Thanks!
12camlt is offline   Reply With Quote
Old 01-18-2013, 12:49 PM   #2
Markwrench
Drives: 2011 2SS/RS ord 7-7-10 home8-24-10
The factory requires a GL5 rating. If you want to stay in GM land the part number for their lube is 88862475. We use AMSOIL Severe Gear 75W-90 as it has some pretty hefty extreme pressure additives and I've had nothing but positive feedback about smoth shifts and better cold temp operation.
Markwrench is offline   Reply With Quote
Old 01-18-2013, 01:28 PM   #3
ripcard
INJACC
ripcard's Avatar
Drives: 2010 Camaro 2SS/RS CGM/IO 6M
The V6 uses an Aisin AY6 and the V8 uses a Tremec 6060.
GM specs very different fluid for each.
For the Aisin the manual says 1.9 qts of 75W-90.
For the Tremec GM calls for 3.65 qts of "Manual Transmission Fluid GM P/N 88861800" which looks exactly like regular old (non-synthetic) automatic transmission fluid.
I think where you heard people using Amsoil, Deep Purple etc. auto fluid is for the Tremec (V8).
I'm sure a quality synthetic 75W-90 would work great in the Aisin. Probably improve the shift feel in cold weather too. Dinosaur gear oil gets pretty thick in cold weather.
Pedders Xa Coilovers & Sways w/Fe4, Pfadt Rear Trailing Arms & Tie Rods, Forgestar CF5s, ZL1 Brakes, 1LE 3.91 Diff, Pedders Cradle Bushings, MGW STS, BTR Stage II Cam, Fluidampr U/D Pulley, Performance Redline Dyno Tune, CAI & Apex Scoop, Pfadt Tri-Y Headers w/HF Cats, Magnaflow 3" Cat Back, RX Catch Can, VMax TB, Billet Tunnel Brace, SRP Pedals, Skip Shift, Seibon CF Hood & ST Trunk, 1LE Splitter, ZL1 Rockers & Diffuser, Heritage Grill, F & R Sparks "SS" badges, Billet Door Handles, Tint, Technostalgia Tail Lights, AAC Side Markers, BlackVue dash cam and my favourite accessory...Litho #163.
ripcard is offline   Reply With Quote
Old 01-19-2013, 03:31 PM   #4
12camlt
Drives: 1LT 2012
Just drained and filled the tranny and the rear differential. Used mobile 1 ls for both. I had a friend who owns a shop put it on his lift to do. Way easy with the lift. I also added the slip additive to the rear diff. The fluid that came outa there after only 10000 miles was sick. Tons of metal on the magnet and in the oil. The transmission oil looked ok but still was glad to change out. Overall the fluids cost me $35 and my buddy $20 for labor. WAY better than the stealership. Going to record the service in my manual and take the rest of the day off !
Old 01-19-2013, 05:06 PM   #5
VQ35DE
Drives: 2013 / 2SS / RS / L99
Dexron LS 75W-90 is what I put in at 80 miles and glad I did.
VQ35DE is offline   Reply With Quote
Old 01-20-2013, 05:44 PM   #6
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Much of what we see on the magnetic drain plug in the rear differential is from the clutches in the M6 (V-6) and the V-8 car's limited slip unit. Still good to get it out of there, though.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 01-20-2013, 07:03 PM   #7
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Im assuming there isn't a slip additive in the Mobil 1 oil for the Diff?... Im about to change mine (2010 v6 M6) and was just curious...If its not in the Mobil 1, what slip additive did you use?
Lil' Nasty is offline   Reply With Quote
Old 01-20-2013, 08:21 PM   #8
12camlt
Drives: 1LT 2012
No, I looked and didn't find anything. I used the GM slip additive. The part number is in your manual in the fluids section. I read a lot where people said if you use the mobile 1 ls, you don't need the additive, but I wanted to follow the directions.
Old 01-21-2013, 03:34 PM   #9
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Oh okay, thanks. Now idk whether to get the mobil 1 use what came in the car?
On a sidenote i use Mobil 1 for the engine, guess i just want to use the same brand for everything...
Old 04-28-2013, 07:16 PM   #10
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Stealership
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 04-28-2013, 08:18 PM   #11
sycraft
COTW 5/06/2013
sycraft's Avatar
I used syncromesh for my trans, it saved it on a track day where my temps in the trans rose to 300 degrees. Not enough fluid in the Aisen Trans, may look at adding a cooler and additional tank down the line to keep it cool.
Old 06-13-2013, 12:36 AM   #12
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
Im planning on using ams oil.Which fluid do i need for a 2011 v6 m6 for the transmission and the rear diff? I want to switch out both to ams oil.
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
Vader2011v6 is offline   Reply With Quote
Old 06-13-2013, 05:00 AM   #13
Mouse6.2
Mouse6.2's Avatar
Drives: 2013 2SS/RS M6 NPP
This is from AMSOIL's site.
Manual Transmission,AY6 (6-SPD)......GL-5
All TEMPS......75W-90 [2]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Limited Slip Differential, Rear W/ MT......GL-5*
All TEMPS......75W-90 [3] [4]
[2] GM recommends part no. 88862475 (Canada 88862476)
[3] Synthetic axle lubricant GM Part no. 89021677 / Canada
89021678 formulated to meet GM Specification 9986115.
[4] Add 2.5 oz of friction modifier part no. 1052358 or
equivalent.
Manual Transmission, AY6 (6-SPD)..........3.8 pints
Differential, With AT Rear..........1.9 pints
Differential, With MT Rear..........2.1 pints [2]
[1] After refill check oil level.
[2] Add 2.5 oz of friction modifier part no. 1052358 or
equivalent.
Mouse6.2 is offline   Reply With Quote
