HeadlightArmor
Old 01-18-2013, 01:59 PM   #1
416Camaro
416Camaro's Avatar
Drives: 2011 Camaro LS
My coolant gauge is not working??
Got a message on my dash panel. After driving around a bit I noticed the gauge on the left (temperature) is not working. It hasn't moved all day. What could this be???
M6 MODS: OBX LT headers, Magnaflow Resonated Xpipe, MRT V2 Axle back, K&N intake, Trifecta Tune,Sidemarker & Tail Light Blackout, Black Vinyl Emblems, CCFL Angel Eye Projectors, 35% & 5% Tint, Plasti Dip Rocker Stripes/Gas Cap, Blacked Out Tail Light Bezels....More to come.
416Camaro is offline   Reply With Quote
Old 01-18-2013, 02:29 PM   #2
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Drives: 2010 Camaro LT/RS M6
Time to trade it in
Sent from my DROID RAZR using Tapatalk 2
CamaroC-17 is offline   Reply With Quote
Old 01-18-2013, 02:41 PM   #3
Strydes
Strydes's Avatar
Drives: 2010 inferno orange 2SS 6spd
happened to me twice. First time I replaced coolant sensor. Second time I left battery off for 10 minutes and message went away.
Strydes is offline   Reply With Quote
Old 01-18-2013, 02:42 PM   #4
416Camaro
416Camaro's Avatar
Old 01-18-2013, 02:44 PM   #5
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Best help I can provide is take it to the dealer and see what they say/can do. Still under warranty right?
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 01-18-2013, 02:47 PM   #6
416Camaro
416Camaro's Avatar
Yes it is. Will do.
Old 01-18-2013, 02:49 PM   #7
Ject
aka Patrick
Ject's Avatar
Most likely (well hopefully) it is just a sensor that needs to be replaced. I can't imagine anything more then that causing it.
Old 01-18-2013, 03:50 PM   #8
416Camaro
416Camaro's Avatar
Am hoping that is it, I was just at gm gotta wait Til Monday have someone look at it. Gotta work tonight don't think I want to drive the car right now with that msg on.
Old 01-18-2013, 04:28 PM   #9
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Looks like the temperature sensor stopped working. It's probably in some kind of safe-mode, where it won't let you run the A/C. I'd guess the radiator fans are running constantly as well. It is probably also running very rich (as if the engine where extremely cold), so you'll want to take care of this as soon as possible.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 01-19-2013, 03:30 AM   #10
416Camaro
416Camaro's Avatar
Yea hopefully it's a quick fix, and on warranty.
Old 01-19-2013, 08:47 AM   #11
motley1987
motley1987's Avatar
Drives: 2011 Camaro 1LT
Keep us posted. I get that message maybe once a week. Someone here suggested it might be related to my trifecta tune but Vince said that isn't it. I hooked up my scangauge and checked the temp and it doesn't run hot so I cleared it. Problem is sometimes the error comes up without the check engine light. I took mine to the dealer and they said they couldn't find anything wrong and just cleared it themselves. If you have a tune, redownloading the tune will get rid of it too. The sound of the fan running constantly is really annoying so I hope you can get a definitive answer so I can get rid of mine for good too.
Ben
2011 IOM 1LT RS. K&N Typhoon CAI; Sequential taillights, SLP faded gill overlays, VMAX CNC ported TB, RX Ported IM, RX breather, 3/8" Black Ice-olator, OEM STB, 4 gauge pack, Alpine amp and sub, convertible spoiler, IOM painted rear diffuser, SS front and rear sways, SS front and rear struts and springs, Street Scene front splitter, IOM hideaway headlight covers, 5% window tint.
motley1987 is offline   Reply With Quote
Old 01-19-2013, 08:49 AM   #12
motley1987
motley1987's Avatar
Also if you do a search with "ac off" or "engine temperature" (or something similar), there are a few threads about it but I don't think anyone has completely figured it out.
Old 01-19-2013, 08:58 AM   #13
habunow1
habunow1's Avatar
Drives: 2010 Yellow 2SS, 2011 CG 1LT IPF SC
Just happen to me, Coolant was low and had to refill some make sure you use the correct one. To fix the gauge disconnect the harness from the computer next to the fuse box for about 5 min the reconnect. This should get guages working again. If not take it to the dealer and have them look at the sensor. The car goes in to this mode if temp reaches a certain degree which is in a very small tolerance. Hope this help.
habunow1 is offline   Reply With Quote
Old 01-19-2013, 09:02 AM   #14
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Since you just did a headers install, maybe the installer bumped the sensor or plug?
