Jason 98 TA
Old 01-21-2013, 11:56 AM   #15
IPF-Tuning
IPF-Tuning's Avatar
Drives: Camaro, CTS-V, Escalade, GMC Sierra
Jesse,
Yeah call Mike at Hillbank and he will be glad to look it over for you. He's a great guy!
Thanks,
Jesse!
IPF-Tuning is offline   Reply With Quote
Old 01-21-2013, 01:40 PM   #16
jessepang
jessepang's Avatar
Drives: 2012 LFX CAMARO
I'm on my way to orange where they installed it. I hope he can fix it!
Thanks,
Jesse
jessepang is offline   Reply With Quote
Old 01-21-2013, 03:00 PM   #17
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Hope it's just a simple fix. or fluid level,
Old 01-21-2013, 04:19 PM   #18
jessepang
jessepang's Avatar
Just got back and unfortunately he sees nothing wrong with it and has no idea what the problem is! :(
Old 01-21-2013, 04:40 PM   #19
sycraft
COTW 5/06/2013
sycraft's Avatar
We need pictures of the install, especially where the resovoir is and the line from the pump to the resovoir...
Old 01-21-2013, 04:49 PM   #20
blackTT600
Drives: 2011 2LT M6 SC
Did he check the pressure it was producing? maybe there is a blockage some where in there.
blackTT600 is offline   Reply With Quote
Old 01-21-2013, 04:51 PM   #21
sycraft
COTW 5/06/2013
sycraft's Avatar
Its gotta be something simple..... Pics can hopefully tell all....
Old 01-21-2013, 04:52 PM   #22
sycraft
COTW 5/06/2013
sycraft's Avatar
Check the belt routing, make sure the belt is correct over the p/s pump pully, not reversed.
Old 01-21-2013, 05:02 PM   #23
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
What kind of low rent outfit is this? They took an eyeball and sent you on your way? Idiots.
"My steering is not working"?
"Hmmmmm, dunno. Bye Bye". "Hope you don't crash".
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 01-21-2013, 06:15 PM   #24
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
If you turn your wheels lock to lock you should hear the power steering pump squeeling? or at least some kind of noise. Is this steering unit the same as the V8 having wire issues. mine is a little tight but not a complete failure.
Old 01-21-2013, 06:23 PM   #25
jessepang
jessepang's Avatar
I will be putting pics up soon...hopefully that will help you guys notice a problem if any. But he did check the belt, checked the hoses and everything. He's stumped.
Old 01-21-2013, 06:38 PM   #26
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
That hose does come close to the back plate of the vortech housing, they had to keep it loose until you were ready to slip on the reservior. I had the power steering res. zipped tied to the fan shroud until i was ready to complete the install.
Old 01-21-2013, 08:42 PM   #27
Macrackie
Macrackie's Avatar
Drives: 2011 Camaro LS Stripper model
I would maybe drain the unit and inspect the hoses where they push on to the fittings.
Years ago mercury outboards came out with a double wall fuel line. If you slipped it over a hose barb with a really sharp end you could cut the inner liner and creat a valve type flap inside the hose. Removal of the hose and everything would be perfect until you would poke at it with a pick. Catch the flap just right and you could fold it over. Heard lots of horor storys bout the fuel line when they came out. Damn near bought a freshly built 260hp power head by doing it myself. Didnt have ten minutes on it when I shut it down. Thank god for good ears would have cost our shop a forture.
Always seemed the 2 dollar part would cost me the trouble.
Not sure what the power steering hoses look like so just a thought.
Macrackie is offline   Reply With Quote
Old 01-21-2013, 10:03 PM   #28
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
There have been issues with the pumps on the LLTs but most have failed in the really cold weather. The only other thing it sounds like is a pinched hose but you should see that.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
