Old 01-22-2013, 08:51 AM   #29
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
unless something was left inside of the hose?
Old 01-22-2013, 10:27 AM   #30
Det_Duke
Det_Duke's Avatar
Drives: 2010V6IPFSupercharger BBK's 480 HP
My Camaro V6 auto- A6 makes a typical power steering whine when it gets hot and it only has 9000 miles on it. It runs way too hot for me (200F), and no one makes a 160F thermostat.
Det_Duke is offline   Reply With Quote
Old 01-22-2013, 11:31 AM   #31
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Where do you read the temps on the power steering? yes any fluid will get hot, power steering is a high temp hydraulic blend oil. If it doesn't boil over that is really excessive.
Old 01-22-2013, 01:35 PM   #32
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Duke is referring to the coolant temperature, I believe.
The cooling system on my V-6 (2012) works differently, depending on whether the a/c is running. Mine does fans on at 180 and off at 170 when the a/c is engaged, but on/off at 220/210 when it is not. It is a high pressure cooling system and is designed to run that way. Do not drop in a 160 thermostat or you will probably confuse the computer as well as never reach designed operating temp.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 01-22-2013, 09:22 PM   #33
Macrackie
Macrackie's Avatar
Drives: 2011 Camaro LS Stripper model
Hose plug that got pushed in and forgotten about...thats a great thought right there.
Any up dates?
Macrackie is offline   Reply With Quote
Old 01-23-2013, 09:26 AM   #34
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
yesterday my coolant temps were at 208* normal, most highway driving and a 32 mile drive just to let you know
Old 01-23-2013, 09:54 AM   #35
dman3000
Drives: BLack LS '12
solved
dman3000 is offline   Reply With Quote
Old 01-23-2013, 12:10 PM   #36
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
The hose came with a coiled up wire inside to keep it from collapsing.
Old 01-23-2013, 02:24 PM   #37
IPF-Tuning
IPF-Tuning's Avatar
Drives: Camaro, CTS-V, Escalade, GMC Sierra
Siko,
We use a different hose now that does not need the spring inside. Please, if you guys need anything, hit me up on my cell.
Thanks,
Jesse!
IPF-Tuning is offline   Reply With Quote
Old 01-24-2013, 02:05 PM   #38
jessepang
jessepang's Avatar
Drives: 2012 LFX CAMARO
Sorry for the lag.. been busy with work.. but so far, no answer.
jessepang is offline   Reply With Quote
Old 01-24-2013, 02:14 PM   #39
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I won't log off until you find the problem.
Old 01-24-2013, 05:49 PM   #40
sycraft
COTW 5/06/2013
sycraft's Avatar
Still need pics, detailed pics, running too.
Old 01-26-2013, 02:24 PM   #41
jessepang
jessepang's Avatar
Again sorry for the lag and thank you all so much for helping . So as of right now, they did figure out that the steering wheel pump's pressure was low. so right now its getting replaced and hopefully that should be the end of that ^_^
Old 01-26-2013, 03:34 PM   #42
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Sorry to hear that the pump went south. Now it's time to break in your sc
