Solo Performance
Old 01-19-2013, 01:12 PM   #1
2012REDSS
Drives: 2012 Camaro SS
How much boost?
If I data log using my SCT and LiveLink II it says the max MAP I hit was 57 which using a kpa to psi calculator was over 8 lbs of boost. Is this right? I have a vortech v3 stock pulley 3.8in but I have LTs and 3in exhaust. I think I should be closer to the 5.5-6 lbs of boost range. Opinions? Someone want to take a peek at the data log and tell me how much boost its showing?
2012REDSS is offline   Reply With Quote
Old 01-19-2013, 01:22 PM   #2
Blueclyde
Blueclyde's Avatar
Drives: 2016 2SS
Not exactly sure how your data logger processes this data. MAP is manifold Absolute pressure so depending on your Baro you should expect to see somewhere north of 100 KPA before you see boost. It is possible that your data logger is calculating and displaying boost directly. Just not familiar with your logger. Boost is pressure in the intake system above atmospheric pressure.
Blueclyde is offline   Reply With Quote
Old 01-19-2013, 06:16 PM   #3
blake-b
blake-b's Avatar
Drives: Black 2010
Zero boost is ~100 kpa. Google for a kpa to boost psi chart not straight psi. I did a conversion to psi and it was high. Imade the same mistake and realized quickly my car wasnt making 27# of boost when it showed 195kpa.
http://ls1tech.com/forums/showthread.php?t=1469526
Old 01-19-2013, 07:57 PM   #4
2012REDSS
ok so livelink is not measuring in kpa. my readings were -87 all the way up to 57. if 100 kpa is zero boost livelink is using some other unit of measure.
here is a pic of the log showing the map (light line) and rpm (heavy Line)
Old 01-19-2013, 09:05 PM   #5
Blueclyde
Blueclyde's Avatar
Drives: 2016 2SS
What were you doing when this log was taken?
Old 01-19-2013, 10:55 PM   #6
2012REDSS
WOT 1st 2nd and 3rd gear
Old 01-23-2013, 02:09 PM   #7
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Add Atmopheric pressure about 105 at sea level to those readings and use this chart to convert to PSI.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 01-24-2013, 02:09 PM   #8
2012REDSS
Thanks Ted
