Jason 98 TA
Old 01-19-2013, 09:31 PM   #1
zcorvette04
zcorvette04's Avatar
Drives: 2012 Chevrolet Camaro 2SS/RS
Fog lights for a NON RS
I have the lights need the bezels and a wiring harness to hook them up? I would love if I could turn them off and on with out using an added switch.I would prefer not to put any holes in my car that I do not have too. Any ideas is this possible?
zcorvette04 is offline   Reply With Quote
Old 01-19-2013, 09:47 PM   #2
RoadieWingZ
RoadieWingZ's Avatar
Drives: 2013 Black Camaro 1LS
Not sure about factory harnesses, but there is an aftermarket kit that uses low wattage bulbs so they can tap into side running light. Stock bulb wattage will overload side light circuits. Saw that someone else was selling just low wattage bilbs for $39/pr if you already have housing. Have also heard the bezels on the LS can be used by cutting out the center blank area if you have mechanical aptitude and correct tools.
2013 Camaro LS
RoadieWingZ is offline   Reply With Quote
Old 01-19-2013, 10:03 PM   #3
zcorvette04
yeah I have thought about doing that as well I would really love to find a way to hook them up so they were not always on with my lights you know
Old 01-19-2013, 10:32 PM   #4
zcorvette04
I know it seems ridiculous but I was hoping some one out there might have an idea other than upgrading out of my LS which I love, Thanks
Old 01-19-2013, 11:31 PM   #5
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
If you have led bulbs, just tap into the sidemarker wiring. Thats what I did with mine
Old 01-20-2013, 12:14 AM   #6
intensifi
Drives: '12 2LT Convertible
The non-RS light switch has a push able center button which can be used to control fog lights.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 01-20-2013, 12:16 AM   #7
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
Unfortunately the LS has the switch from RS cars. No button in the middle.
OP, there is no way to wire them with out a switch UNLESS you want them to run just day, just night, or all the time. If that's what you want, contact 2SSRS or GEN5DIY.com for a harness.
You don't necessarily have to mount a switch by drilling a hole. Just hide it up under the dash. There is a pass through hole in tr fire wall on the drivers side. Bezels are not that expensive from your dealer.
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 01-20-2013, 01:52 PM   #8
zcorvette04
yeah well I will figure something I guess cause I really do not want them on all the time
Old 01-20-2013, 01:53 PM   #9
zcorvette04
Before o forget can I buy the headlight switch with the button and wire them that way?
Old 01-20-2013, 03:26 PM   #10
My Caroline
2SSRS was working on something for RS cars that required a relay. Maybe be can hook you up with the parts to make it work? The problem is not the button, it's the signal from the BCM. The BCM doesn't know you have fogs. There is also no wire in the harness to just push the button on and off.
Old 01-20-2013, 03:27 PM   #11
sycraft
COTW 5/06/2013
sycraft's Avatar
Onky if your dealer can get a new VCI number to reprogram your car, ask him first, they will have to call and see if it is available yet.
Old 01-20-2013, 03:29 PM   #12
Hamilton2400
Hamilton2400's Avatar
Drives: 2014 GMC Sierra/2015 GMC Acadia
I wired my fogs to my parking lights on my ls so all I have to do is turn that on for the fogs.
Hamilton2400 is offline   Reply With Quote
Old 01-20-2013, 05:53 PM   #13
zcorvette04
Thanks guys
