Jason 98 TA
Old 01-24-2013, 10:15 PM   #15
zl1fun
Drives: 2013 ZL1 # 1029 black
Not far at all! I have only seen 2 other ZL1's in the Peoria Area. I was pulling out on to the main road one day turning left just as another ZL1 was turning right from the other direction...what are the odds of that? It was cool.
zl1fun is offline   Reply With Quote
Old 02-13-2013, 05:56 PM   #16
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
Very nice gains fellas!
2013 Red ZL1 Auto modded
2015 C7 ZO6 Luguna Blue stock
BeardWS6 is offline   Reply With Quote
Old 02-13-2013, 10:18 PM   #17
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Yep, the pullies work well don't they....
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 02-14-2013, 02:00 PM   #18
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
How much power you making?
Old 02-14-2013, 02:06 PM   #19
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
What all can we put on our cars and tune with a hand held programmer from a vendor? How much power can we make at the wheels auto and M6? Thanks guys!!
Old 02-23-2013, 11:26 AM   #20
Jay_ray23
Jay_ray23's Avatar
Drives: 2013 Black ZL1
How hard is it to change out the lower pulley yourself? I want to do it.
Jay_ray23 is offline   Reply With Quote
Old 02-23-2013, 11:34 AM   #21
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
its not that bad but you need the right puller and installer. I would suggest that if you are at all nervous about the process, get a veteran installer to help or trust a professional
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-23-2013, 11:47 AM   #22
Jay_ray23
Jay_ray23's Avatar
Thanks Stephen.
Old 02-23-2013, 02:40 PM   #23
Stephen12ZL1
Drives: '17 ZL1 A10
here are the pulley install potential issues that people encounter. Removing the stock balancer bolt can be difficult as it is torqued to approx 230ft/lbs (37ft/lbs + 140 degrees). If your car is an automatic, the engine will turn and you have to use a tool to lock the engine at the flywheel once the starter is removed. Otherwise, you can use an air impact tool to remove this bolt (24mm). Next, the lower balancer must be removed using a puller like the OTC 6667. The A/C belt is a "stretch fit" and it will come off with the stock balancer. To reinstall: don't forget the seal on the snout of the balancer. Use a proper install tool like a hawk tool or equivalent threaded rod and nut/washer. You could use a longer M16 bolt but it is not advised as some have pulled the threads out of the crank this way. Make sure the keyway is aligned properly before install which is obvious. Torque the new GM bolt to 37ft/lbs + 140degrees or 235ft/lbs for an ARP(preferred) bolt. You must use a large torque wrench for this duty. Use Red Loctite if you want on the new bolt...there are opinions on this. Reinstall the a/c belt by rotating the crank bolt and pressing the belt with your fingers or use an install tool(no need IMO). Reinstall the accessory belt and the correct length supercharger belt for the ring diameter you chose. Make sure belt alignment is correct.
Old 02-26-2013, 10:01 AM   #24
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Waiting for spring to get to the dyno. I hate to guess but it feels like about 10,000 hp..lol
2012 ZL1
Old 02-28-2013, 11:48 AM   #25
red67
red67's Avatar
Drives: 2013 ZL1 M6
guys question, with the 9.55 pulley doesnt it hit the lines that are right below the pulley? i was looking at a zl1 this morning with an ati balancer, and a 9.17 18% od lingenfelter pulley and it was damn close with that
red67 is offline   Reply With Quote
Old 02-28-2013, 12:18 PM   #26
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
A 10" fits, so 9.5 would. My 10 is very close, but clears.
2012 ZL1
Old 03-20-2013, 03:37 PM   #27
Stephen12ZL1
Drives: '17 ZL1 A10
My 9.55 clears only because I removed the lines from the black plastic holder and zip tied them to the electric power steering assembly. Now they have plenty of clearance. This is the same on both the 2012 and 2013 I have worked on...my 2012 auto and Smitty's 2013 manual have the same line setup which I was surprised to see.
Old 03-20-2013, 04:42 PM   #28
ace32x
ace32x's Avatar
Drives: 2013 ZL1
have you had yours on the dyno with the 10" lower and the 2.5 upper? im getting ready to do a similar set up but wasnt sure how the bottom end and the blower bearings would hold up to that
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
ace32x is offline   Reply With Quote
