Old 01-21-2013, 08:00 AM   #1
myreddevil
myreddevil's Avatar
Drives: Chevy Camaro SS
in need of assistance
I am trying to get a camshaft installed, when i took it in to get installed they called me and told me the valve springs (Compcam) were unreliable and they did not want to install them because they apparently break a lot. I have a L99 with a supercharger and full exhaust. I need to find new springs but i don't understand anything about valve springs. They came in a kit with the camshaft, they have a Seat load: 129lbs @ 1.835", Open: 470lbs @ 1.160", spring rate: 505ilb/in, and a coil bind of 1.100". Other than Compcams I cant find identical springs. what would be a good replacement set of springs and what would be acceptable numbers for the new springs?
myreddevil is offline   Reply With Quote
Old 01-21-2013, 08:29 AM   #2
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Those sound like Comp 926 springs. If they are than there is nothing wrong with them except they are overpriced. Brian Tooley springs are better value but if you already have those than use them.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 01-21-2013, 08:39 AM   #3
myreddevil
myreddevil's Avatar
The guys who were goin to install them had told me in the last month alone they have had 3 people come back with broken valve springs from compcam. They were so serious about not wanting to install them they wanted me to sign a form sayin its not their fault if my car blows up.
Old 01-21-2013, 08:44 AM   #4
realcanuk
realcanuk's Avatar
First of all, you need to check what model of spring they are. If they are the 926 they are good springs. There are some comp springs that I wouldnt use.
Secondly, you might consider a different shop if thats the case. It is possible they are installing them without properly checking heights and pressures which might explain the probems they have.
If you really dont want to use comps, than call Brian Tooley and ask him which of his springs are for you cam specs. He knows his stuff.
Old 01-21-2013, 01:06 PM   #5
quincy speeder
Drives: 2011 Camaro SS
Comp 918 single's have had alot of problems. Thought I heard you have to watch out on spring pressure's on L99 engines due to the AFM lifters.
2010 SS, 230 Cam, ARH headers,Airaid intake, 160 t-stat,3.90 gears 475hp/430tq. -old setup
added- Procharger F1-D, alky control,FIC 96lb,fuel system- 810hp/735tq- 10.3 at 136mph , 1.75 60'. see how long it lasts.
Thanks to Slowhawk Performance.
2008 C6, 427ci,YSI,mcleod clutch,Alky control, built tranny, custom fuel system. 985rwhp, best 1/4 -9.4 at 152mph. still trying to get the shifting down:(
quincy speeder is offline   Reply With Quote
Old 01-21-2013, 08:05 PM   #6
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
I ran comp cams 926 springs on one cam with .610/.617 lift. I have the same springs on my current valvetrain with .614/.624 lift. I'd say they have about 25,000 miles on them total. Several makers have had problems with single springs but when I replace my current set it will be with 926s from comp.
personally , I would be suspicious if a shop made a coment like the one you have described without providing some details to substantiate it. Such as, spring height, seat pressure, and max lift on the cams that were breaking these things. At least something. It just sounds flakey to me. My 2 cents worth.
UNRIVALED SS is offline   Reply With Quote
Old 01-23-2013, 02:01 PM   #7
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
You need to go pick up your car and find another installer.
We use Compcams Products exclusively without Issues.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
