Old 01-21-2013, 08:11 AM   #1
drrm123
drrm123's Avatar
Drives: 2013 ZL1 Camaro A6
CoolerLogic or TORQ heat exchanger?
Finally made it it to the track this weekend. Best run was a 12.42 ET. Which was the second pass, some reason the first did record on equipment at track. But every one after that got slower, sure from heat soak. Which HX would you prefer CoolerLogic or TORQ? Any modifications necessary to install either? What about fans from TORQ being mounted on CoolerLogic HX? Thanks for any info.
Made
drrm123 is offline   Reply With Quote
Old 01-21-2013, 08:32 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28
Originally Posted by drrm123 View Post
Finally made it it to the track this weekend. Bet run was a 12.42 ET. Which was the second pass, some reason the first did record on equipment at track. But every one after that got slower, sure from heat soak. Which HX would you prefer CoolerLogic or TORQ? Any modifications necessary to install either? What about fans from TORQ being mounted on CoolerLogic HX? Thanks for any info.
Made
The torq unit looks nice. They require no modification to fit in the factory location as there is a lot of space there for extra thickness. My Cooler Logic unit fits great and helps considerably. The fans are a nice touch as more airflow across the fins has to help. I bet if the actual Torq fans won't fit that a similar electric fan could be found that would be fine for this application.
'15 Z/28 #325 black a/c & stereo. 2:10.5 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-21-2013, 08:41 AM   #3
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
I went with the Torq Heat exchanger awesome product and very well built
tpower is offline   Reply With Quote
Old 01-21-2013, 09:59 AM   #4
drrm123
drrm123's Avatar
tpower did you have to drill any hole to install HX and did you get with or without fans, and have you used it at drag strip yet? wondering how long of a cool down period before next pass. I waited about 30 minutes between passes and would still have engine temps around 200 to 217 by the time i got ready to leave the line.
Old 01-21-2013, 10:35 AM   #5
hognutz
hognutz's Avatar
Drives: 2013 ZL1
The 3 heat exchangers I have seen people use are
1. cooler logic
2. torq
3. KDI
I have yet to see data that compares them head to head.
Now if you are drag racing honestly the one chiller products is proabably going to be you best money spent though. no heat exchanger can go below ambient and there are days at the drag strip where ambient can be high.
I have seen video of iat2's in the 60's on 90 degree days. then maybe up to 100 degrees or so on the pass then right back down wile in the return lane.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 01-21-2013, 10:40 AM   #6
Stephen12ZL1
Drives: '15 Z/28
no drilling required on any of these heat exchangers mentioned. they bolt into the stock location.
Old 01-21-2013, 11:17 AM   #7
ace32x
Drives: 2013 ZL1
i ordered the kdi last week, it was dual pass and 4", i hadnt seen the torq unit but compared to the other ones the kdi one was a fair amount bigger
2013 victory red zl1, 2012 1500 silverado, 95 nissan 240sx 383 ls1 11:1 stroker dart 225 heads ms4 cam fast 102 manifold ;D
ace32x is offline   Reply With Quote
Old 01-21-2013, 01:18 PM   #8
EVLZL1
EVLZL1's Avatar
Drives: '13 Black ZL1,MN6,Suede pkg,
1. cooler logic
2. torq
3. KDI
I went with a Super Chiller and will be posting results when we hit our usual 115* here in AZ.
EVLZL1 is offline   Reply With Quote
Old 01-21-2013, 01:47 PM   #9
drrm123
drrm123's Avatar
I saw video of someone driving around with super chiller, didn't like the ideal of it being tapped from AC unit. Prefer to keep warranty intack for a while and thought that unit would be a problem to remove and reinstall if had any type of warranty work to be done. It's a good concept though.
Old 01-22-2013, 04:02 PM   #10
Flavorwrench
Flavorwrench's Avatar
Drives: 2012 ZL1 & 67 RS-SS TwinTurbo
Interesting... I was told Keith is no longer in business.
Flavorwrench is offline   Reply With Quote
Old 08-05-2013, 07:44 PM   #11
Nasdaq
Drives: 2013 ZL1
Correct me if I'm wrong but bigger doesnt always mean better...KDI is 4" thick..can't that be counter productive? Coolerlogic being 2.75" thick would this be sufficient?
Nasdaq is offline   Reply With Quote
Old 08-05-2013, 09:49 PM   #12
hognutz
hognutz's Avatar
Drives: 2013 ZL1
It workes well from the data he posted Dig up his build threads on his personal car there were datalogs in there.
his car was running 10.20's without pulling any timing by the end of the run if I remember right. I think his iat's were in the 120's and the car was making a ton of power.
it is more money though so I see why the coolerlogic is appealing people don't less extreme builds.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 08-05-2013, 11:33 PM   #13
casper73
casper73's Avatar
Drives: 12 ZL1 73 LT 67 RSSS
Who did your install and did it void your warranty? Was it hard to put in and did you have any leaks? I have heard stories of someone in the phenix area that was having issues
casper73 is offline   Reply With Quote
Old 08-05-2013, 11:49 PM   #14
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Has there been any testing to determine if these larger heat exchangers reduce the airflow and thus cooling to the engine coolant. I would imagine GM designed the stock HX to perform while not blocking airflow to the radiator. At some point you will be trading off better intercooler cooling for poorer engine cooling.
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
