Old 01-21-2013, 12:07 PM   #1
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
Dressing
I scuffed up the plastic on the outside by the side window with the buffer. What is the best dressing to put on it? Thanks in advance
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
Old 01-21-2013, 01:05 PM   #2
DefianceDan
VroomVroom
DefianceDan's Avatar
Drives: 2017 50th 2SS
Adams In & Out Detail Spray followed by SuperVRT
2017 H50 2SS MX8 F55 NPP CF5 RN2
DefianceDan is offline   Reply With Quote
Old 01-21-2013, 02:08 PM   #3
Cheveey57
Cheveey57's Avatar
Thanks for the info, after I posted I realized It was posted in the wrong place.
Old 01-21-2013, 02:22 PM   #4
Cheveey57
Cheveey57's Avatar
I just ordered one of each from the Adams site, thanks
Old 01-21-2013, 06:51 PM   #5
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
couldn't resist...sorry
btw it's great stuff you'll love your results
Laus Deo
charlietuna is offline   Reply With Quote
Old 01-21-2013, 08:38 PM   #6
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Looks like you're on the right road, post up some before/after results when you use them!
Also, be sure to either tape off or put a thin coat of SVRT on your trim next time before polishing.
Old 01-21-2013, 08:41 PM   #7
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Why would you use In & Out and SVRT? It's always been my understanding that In & Out is just a less durable dressing for hard to reach places?
[B]
Old 01-21-2013, 08:51 PM   #8
Adam's Polishes
You are correct. Not sure where the idea of "both" would've come into play.
Use SVRT on the bulk of the tires and trim, pretty much anything you can reach easily with an applicator. Once thats done go back and hit all the tight areas that couldn't be reached with In & Out Spray.
Old 01-21-2013, 09:38 PM   #9
iCamaro
iCamaro's Avatar
Drives: 2012 LT RS Camaro
Hey Dylan,
I need a really good deal on my shopping cart that I have had for awhile so ill pull the trigger!
iCamaro is offline   Reply With Quote
Old 01-21-2013, 09:45 PM   #10
Adam's Polishes
check the promos section... we put up an MLK day promo earlier thats good thru tomorrow.
