Solo Performance
Old 01-21-2013, 02:11 PM   #1
Cruuzin LV
Cruuzin LV's Avatar
Drives: 2012 Camaro SS 45th Anniversary
tonneau cover modification **Pics**
Everyone seems to struggle with the tonneau cover wanting to fly off so either we modify them, take our chances with it, or don't use them at all...
I been thinking about this problem for awhile now. I have done some research and I have seen everything from velcro to sewing on custom made plastic clips to remedy this issue. I myself thought about this and I came up with a solution that literately costs less than 10 bucks and you can get the items needed from Walmart, Home Depot, or any craft store. Plus it actually looks pretty good and its very very easy!
So I used eyelets and some hairties. Here is what you need.
Cruuzin LV is offline   Reply With Quote
Old 01-21-2013, 02:14 PM   #2
Cruuzin LV
Cruuzin LV's Avatar
Next you need to put the holes in to keep the wind from taking hold of it.
Old 01-21-2013, 02:16 PM   #3
Cruuzin LV
Cruuzin LV's Avatar
Now use two hairties as mini bungie cords.
Old 01-21-2013, 02:19 PM   #4
Calikenn
Calikenn's Avatar
Drives: 2012 Corvette GS
The post that you secure the hair ties to are for the bungee straps from the tonneau cover. Are you replacing that or are you adding to it?
Calikenn is offline   Reply With Quote
Old 01-21-2013, 02:20 PM   #5
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
pretty slick..
my 2012 came with bungies already, but I might use this idea to add one to the center, not sure why GM failed to do so in the first place.
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 01-21-2013, 02:20 PM   #6
Cruuzin LV
Cruuzin LV's Avatar
That's it.. very simple. looks pretty good and solves the problem. Hope this helps everyone out who has this problem. If you have any questions let me know.
Old 01-21-2013, 02:23 PM   #7
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
I have yet to have a problem losing my tonneau cover. And I've had that sucker up to over 100. I have the elastic lanyard-type loops on it. Do you people that have issues have the two retainer bolts installed that go on the back of the rear seat?
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
One of 82 GF Ragtops built in '15 out of 811 Total
Member of SEPA5+
theragtopguy is offline   Reply With Quote
Old 01-21-2013, 02:23 PM   #8
Cruuzin LV
Cruuzin LV's Avatar
Originally Posted by Mr. iNCREDIBLE View Post
pretty slick..
Mine had the bungies also however I don't feel like they actually solve the issue so now I use what I made and the ones that came with it at the same time.
That's not a bad idea either. I'm sure others will take this idea and run with it and make similar mods. The spot I put the eyelets in holds really good and you dont need to drill in more posts or anything.
Old 01-21-2013, 02:24 PM   #9
Cruuzin LV
Cruuzin LV's Avatar
Originally Posted by Calikenn View Post
This is a good idea. Have you taken her out on a spin? How did it do? How does that piece connect to the car? Any pics of that?
Works great, no issues so far at high speeds.
If you look at the pictures there is one that has the hairtie connecting to the little posts where the stock bungies connect.
Old 01-21-2013, 02:29 PM   #10
Calikenn
Calikenn's Avatar
Looks great cruizin...necessity is the mother of invention...enjoy!
Old 01-21-2013, 02:32 PM   #11
Cruuzin LV
Cruuzin LV's Avatar
Indeed it is! It's unfortunate that "engineers" didn't already figure this out. Sometimes they just forget KISS.. Keep it simple stupid.
Old 01-21-2013, 02:40 PM   #12
Cruuzin LV
Cruuzin LV's Avatar
I do and mine still popped loose on the freeway. I was doing about 65mph and it was a windy day and the wind got under it and popped one of the side plastic pieces out so I had to pull over and take it off. Since that day I have done research and have tried to figure out the best way to fix this. So I have both the bungie I made and the one that comes with it attached.
Old 01-21-2013, 03:00 PM   #13
cam62
Drives: 2012 IBM Vert 2SS/rs
Ditto.. not to say it can't or won't happen though.
rx catch can;vmax ported throttle body;bowtie delete;SLP SS emblem;CAI cold air intake
cam62 is offline   Reply With Quote
Old 01-21-2013, 04:01 PM   #14
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
I thought by now the aftermarket or GM would of made a hard plastic one like the 4th gens. Alas, my 1SS will still be flapping in the wind
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
