BeckyD @ James Martin Chevy
Old 01-22-2013, 04:50 PM   #1
Tweiten
Tweety
Tweiten's Avatar
Drives: 2010 Camaro 1LT RS
Question Window Tint?! HELP!
Okay, I own a 2010 Camaro 1LT RS. I would like to get the windows tinted. I don't really want to go anything less that 30% becuase it is suppose to be 50% legally. But anyway, I looked at the window of my Camaro and it says 70% Transparency STOCK. Does that mean it's already tinted at 70%?
Also, if the Windows are already tinted at 70% what percent should I put on to equal 30%-35%.
If anyone owns a Red Camaro could you please post pictures of your tint with the % Number? Thanks!
P.S. I am still a noob to Camaro5.com so forgive me if this is posted in the wrong spot.
Tweiten is offline   Reply With Quote
Old 01-22-2013, 04:53 PM   #2
Dznts
Anabolic Connoisseur
Dznts's Avatar
http://www.camaro5.com/forums/showthread.php?t=113598 hope this helps..
Old 01-22-2013, 04:59 PM   #3
ec1990
Drives: 2012 AGM SS
If you put on 35% tint, it'll be around 32% if a cop does test it. The windows are tinted roughly 70% from the factory. Talk to your tint guy/gal an they should explain this in more detail, if they can't, go somewhere else.
ec1990 is offline   Reply With Quote
Old 01-22-2013, 06:04 PM   #4
Caspers2SSRS
Caspers2SSRS
Caspers2SSRS's Avatar
Drives: Summit White 2010 2SS/RS Camaro
The answer to your question is NO.
The factory glass allows 70% of the light to enter.........................it does not block 70% of the light from entering....it actually blocks out 30%.
The misnomer is that you believe transparency means the same thing as tint..............................it is actually the opposite in that context. Simply put...................if the glass were 100 % clear and you put 35% tint on it. The tint would be allowing 35% of the light into the car or the opposite................... keeping 65% of the light out.
The passenger and drivers side windows in ND can be tinted to block out 50% of the light maximum, this is also allowing 50% transparency..........aka 50% of the light in.......so using 35% is automatically illegal.
The little windows behind the doors from which rear seat passengers view out, may be tinted as dark as you'd like................meaning 100%.
The rear window may be tinted as dark as you'd like...............meaning 100%.
No mirror or metallic reflective tints are allowed anywhere on the car in ND.
The windshield may not be tinted below the factory supplied tint threshold of 70%. Do not add any tint to the windshield.
Once again if you install 35% tint on clear glass, the tint will block out 65 % of the light.
If you install 35% tint on glass with a 70% Transparency and 30% of the light is already being blocked.......................(35%+30%) divided by 2 = 32.5% Transparency.....MEANING............you'd be far under 50% on the drivers & passenger windows and thus in violation ..................because the legal threshold is 50% as mentioned above.
I'm not paranoid, they're following me !
Caspers2SSRS is offline   Reply With Quote
Old 01-22-2013, 06:14 PM   #5
skibik
Guest
Drives: bbbbbb
I just learned this the other day. The lower the number when it comes to tint the darker it is. Below is a link for each states laws. In MN the law states the windshield nothing can be added. The side and rear windows have to be less than 50% tint meaning it has to be more than 50% transparent with a +/- of 3%. There is also a limit to the amount of reflectivity. With the windows already being 70% transparent that only leaves us with less than 20% left. I did a search for tint products and would prefer pre-cut and 3M but the lightest I could find is 70% tint and that to me would exceed the MN laws for tint.
http://www.iwfa.com/Portals/0/PDFDoc...aw%20Chart.pdf
Dean.
skibik is offline   Reply With Quote
Old 01-22-2013, 06:31 PM   #6
skibik
Guest
Drives: bbbbbb
Also to answer your question, technically the answer is yes. By tint reference the stock windshield is 70% tint from the tint ratings I have found.
Check this guys build thread out, his car is orange but would give you an idea of the tint on a color that is close. His windshield and Fr. side windows would not be legal in ND.
http://www.camaro5.com/forums/showthread.php?t=267048
Old 01-22-2013, 08:04 PM   #7
MBS
MBS's Avatar
Drives: 2010 rs 2lt
http://www.camaro5.com/forums/albumt...?dl=1358029447 .
Here is a link for you just had mine done 3 weeks ago,2010 Victory Red 2LT , I said screw it , State Law here is 70% , Pretty much a waste of time and looks . So i went 17% . haha Looks really good, Take a look at my pics above.
MBS is offline   Reply With Quote
Old 01-22-2013, 08:05 PM   #8
KSX
KSX's Avatar
Drives: 2010 Camaro 2SS/RS
I have 15% on the sides and 5% on the back.. Anything on the back in NYS is legal and whenever I pass a cop I just roll down the windows!
2010 Camaro 2SS/RS IOM 6 SPD LS3
KSX is offline   Reply With Quote
Old 01-22-2013, 08:16 PM   #9
yellowrs
Drives: 2010 SS 426 V8 M/T
How can I tell if my windows are tinted??
yellowrs is offline   Reply With Quote
Old 01-22-2013, 08:22 PM   #10
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
give the finger to the car next to you and if he reacts, no you don't have tinted windows.
Jalberdi99 is offline   Reply With Quote
Old 01-22-2013, 08:54 PM   #11
yellowrs
I will give that a try
Old 01-22-2013, 09:40 PM   #12
Camaro2SS2012
Drives: Land Rover LR4
First of all, 50% tint is VERY light. For you to attain a 50% level of tint (taking into account the factory 70%), you would have to go with a 70-80% film. For your windows to meter out at 35%, you would need to put on a 50% film. You can calculate this (roughly) by turning the percentages into decimals and multiplying them by each other. For example, 0.5 x 0.7 = 0.35... or 35%
If I were you, I would just put on a 35% film and not worry about it. 35% film will typically meter out anywhere between 27-32% depending on the manufacturer, color, material, etc.
Good luck! Tint is one of the cheapest mods, and makes ANY car look better.
Camaro2SS2012 is offline   Reply With Quote
Old 01-23-2013, 05:24 AM   #13
Caspers2SSRS
Caspers2SSRS
It seems the OP wishes to keep his cars tint...................legal, and thus 35% would be really illegal and something he'd worry about.
Old 01-23-2013, 06:07 AM   #14
Agent orange
socal ht5
Agent orange's Avatar
Drives: 2010 Camaro ss
Just do 35%. On all windows. You'll be alright. And drive safe dont get too much attention on the cops.
Agent orange is offline   Reply With Quote
5th gen camaro window tint, camaro window tint, window tint
