Flowmaster Exhaust
Old 01-22-2013, 09:08 PM   #1
quickdrraw
quickdrraw's Avatar
Drives: 2010 Camaro 2SS/RS Rally Yellow
Problem shifting into 3rd...
I only have 9500 miles on my 2010 2SS 6M and every once in a while when shifting into third there is an unusually loud clunk. At first I thought it was me miss shifting, but after it reaccuringly happened I thought otherwise. I am wondering if the clutch is having trouble gripping 3rd for some reason. I have done my fair share of work around cars, but transmissions are a whole other beast. Just need something to go to the dealer with to get them to fix it.
quickdrraw is offline   Reply With Quote
Old 01-28-2013, 01:26 PM   #2
quickdrraw
quickdrraw's Avatar
Thanks guys, glad this forum is so helpful!
Old 01-28-2013, 04:26 PM   #3
Beaukz28
Drives: 2010 2SS M6
Could be several things causing the issue. Hard to say without hearing it. I would probably rule out the clutch and related parts, as the clutch actuates the same no matter which gear range is selected. It would not act up for one gear and work fine for others. I know my 2010 will give a split second of a grind into third when cold but is gone as soon as it gets some heat to it. Honestly most GM's I have been in do this and I am in probably 3-5 a day. Very few standards anymore though. I recommend taking it to the dealer. But ask for there trans or driveability guy or the manager and take them for a ride to show them what you have going on.
Beaukz28 is offline   Reply With Quote
Old 01-29-2013, 10:26 PM   #4
quickdrraw
quickdrraw's Avatar
Thank you, I'll try and do a lil more research before I head in.
Old 01-29-2013, 11:06 PM   #5
Bucci
Bucci
Bucci's Avatar
Drives: 2010 2SS M6
I've got the same slight grind into third when the trans is cold, but no clunking sound.
Do you think it might be a bit of slack in the driveline you are hearing?
Bucci
Bucci is offline   Reply With Quote
Old 02-08-2013, 07:46 PM   #6
quickdrraw
quickdrraw's Avatar
that is what I thought, i'll have to throw it up on the lift and have someone shift around. see what I can see and hear.
Old 02-10-2013, 07:45 AM   #7
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
I had a grind going into 3rd gear on the track, but after doing some reading on the master cylinder, I purchased the Ideal Garage master cyl. and the problem went away with regular clutch fluid changes. Some people had that grind going into second. There's a theory of the compression rate the master cylinder has as it goes from 1st to 2nd to 3rd ect... There's a thread somewhere on here talking about it. good luck
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
