Gen5DIY
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 01-23-2013, 09:07 PM   #1
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Wheel hop solution needed
okay so installed my pfadt trainling arms and toe links. still have wheel hop.
trying to decide between the lg motorsports brace and the pfadt solid subframe bushings.
http://www.pfadtracing.com/catalog/p...roducts_id/188
http://www.lgmotorsports.com/product...oducts_id=2290
obviouly the LG solution is cheaper and easier to install. it is also heavier and will not elimnate all the bushing deflection.
main goal is whell hop elminated cost is not an issue.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 01-23-2013, 09:13 PM   #2
sycraft
COTW 5/06/2013
sycraft's Avatar
Go with the Pfadt solid cradle bushings, replace the diff bushings and possible driveshaft upgrade if that is not enough....
Old 01-23-2013, 09:15 PM   #3
STSL
Drives: 2010 ZR1 Camaro
Im not sure about solids but i do agree you need to work in that area.
STSL is offline   Reply With Quote
Old 01-23-2013, 09:53 PM   #4
hognutz
hognutz's Avatar
Drives: 2013 ZL1
why would I need driveshaft upgrade?
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 01-23-2013, 10:05 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
Trailing arms will make the biggest impact with wheel hop IMO
Click to view my build thread
Old 01-23-2013, 10:06 PM   #6
sycraft
COTW 5/06/2013
sycraft's Avatar
Takes the flex out of the coupler
Old 01-23-2013, 10:22 PM   #7
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
I would hesitate on the solid bushings unless you do not mind extra noise and harshness. But they are effective. To me a bushing upgrade is more effective than the LG brace. It will also help with rear step out. I also understand a wheel alignment change can help reduce the hop.
Even after all that you can still have hop in cold weather with TC off and if you overwhelm traction control. But in warm weather with TC off you should be good.
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 01-23-2013, 11:32 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
already on the car still have some.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 01-23-2013, 11:42 PM   #9
hognutz
hognutz's Avatar
Drives: 2013 ZL1
well I had an 07 Z06 and they are solid bushed and the ride was not bad so I am not sure I am that worried about that side of it. does pedders have a video like pfadt showing defelection? I would love to see the difference. very hard durometer tranmist as well.
every contact point is isolated again if you think about. diff, crontol arms, trainling arms, toe rods, etc are all bushed. it is obviouly going to ride a tad rougher in certian situations but I am not sure that is bad if the cusion is you rear subframe moving.
maybe I should wait for a warmer day. in my Z06 I had wheel hop and it pissed me off. in my last mustang I had MM spherical control arms and subframe connectors. zero hop under any condition. it was just erased.
if you think about a solid frame car the body is isollated but the front and rear are connected. that is why I was considering some solutions like that that connect the two.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 01-23-2013, 11:54 PM   #10
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1; '07 Ducati 1098
I did the pfadt trailing arms/toe rods & the lowering springs and I think both helped with wheel hop much more than stock. I think having the car lower helped with traction issues but YMMV
IcePick06 is offline   Reply With Quote
Old 01-24-2013, 09:28 AM   #11
hognutz
hognutz's Avatar
Drives: 2013 ZL1
there is a video of the hotchkis chassis max brace on youbube. You can see the pfadt solution is more effective but at the same time the solution minimized deflection quite a bit.
$690+harder install+$50 rear alingment. so $740 + 4-6hr install vs
$465 to my door 30-60min install no rear alingment.
I am torn. in my mind I think I should do the pfadt bushings but it is so much easier to do the LG or hotchkis brace.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
