Cold Air Inductions
Old 06-14-2009, 09:23 AM   #15
Vash
Drives: 00 Blazer
That's so you don't open it on accident. Like the brand new 2010 Mustang.
On the Mustang forums people are complaining about the position of the button and that it opens while they are driving.
Old 06-14-2009, 09:41 AM   #16
BrianGriffin78
BrianGriffin78's Avatar
Drives: 2009 GMC Yukon
Make sure you give the Trunk a good closing. The Camaro can handle it. If you don't the lock mechanism will be off track.
BrianGriffin78 is offline   Reply With Quote
Old 06-14-2009, 08:56 PM   #17
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
Originally Posted by KJS View Post
About 3 weeks ago when I first go the car I was having the clicking sound and the trunk not opening using both the release on the door and the remote. I posted it here.
I sprayed silcone spray around the locking mechanism in the trunk and have not had any problems since then. VIN# 7085.
I've been trying it a couple of times a day since then, no problem....
i tried wd40 today and im 6 for 6 opening the trunk thanks .let see if this works for everybody that has this problem please let us know after you do it
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 06-14-2009, 11:57 PM   #18
Rockies4
Drives: PT Cruiser 02
Maybe the trunk monkey just needs more food.
Rockies4 is offline   Reply With Quote
Old 06-15-2009, 12:10 AM   #19
Vash
Drives: 00 Blazer
WD40 is probably to thin an oil for the latch. It should have a little heavy grease from the factory already.
Old 06-15-2009, 12:21 AM   #20
RonC
Drives: 2010 2SS - RS
Originally Posted by camarossrs2150 View Post
when i use the button on my door to open trunk i have to hold the button for a few seconds before it opens and alot of clicking going on . anybody have simular problem not sure if written about yet .but the guy that wrote the poem mentioned something that he hopes the trunk latch opens thanks
Same problem here too. Worked for the first 2 weeks and then started this.
RonC is offline   Reply With Quote
Old 06-15-2009, 12:25 AM   #21
Vash
Drives: 00 Blazer
Is there any adjusting screws for the latch loop or the hook mechanism? If so re-adjust.
Old 06-15-2009, 12:54 PM   #22
camarossrs2150
Drives: abm2ssrs
try wd40 or lithium greese then write back
[SIGPIC]
Old 06-15-2009, 01:08 PM   #23
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Originally Posted by 2010 SS!! View Post
I too have been having this problem.....I need to push down on the trunk lid to get it to open after it clicks...then you have to push the button again and then close the trunk to get it to latch shut....it is going back to dealer this week...paid too much money to have this problem.
Trunk pops but doesn't open. Have to push down on it hard and pop it again.... and I am closing hard everytime too. Kind of a crap shoot whether it opens or not.
I'll try the lube job this evening... sounds like that may work...
Old 06-15-2009, 06:17 PM   #24
camarossrs2150
Drives: abm2ssrs
12 for 12 after wd40ing
[SIGPIC]
Old 06-22-2009, 09:07 PM   #25
turleylox
turleylox's Avatar
Drives: 2010 Chevy Camaro
I'm having the same problem here too. My vin # is 7232
turleylox is offline   Reply With Quote
Old 06-24-2009, 07:24 PM   #26
SSCam15
SSCam15's Avatar
Drives: '83 Blk SC & '10 RYell 2SS/RS
Mine started doing that yesterday. Have had it for 1 weeks. VIN# 7108. Will try grease and let you guys know also.
SSCam15 is offline   Reply With Quote
Old 06-25-2009, 08:17 AM   #27
TomSlick
TomSlick's Avatar
Drives: 2014 RED HTO 2LT/RS
Seems to be a common problem... mine did the same thing too.
Once I got it open, I made it do some opening "aerobics" over and over to get it going.
Hasnt happened again... so far
TomSlick is offline   Reply With Quote
Old 06-25-2009, 08:31 AM   #28
1camaro70
1camaro70's Avatar
Drives: 2010 2SS RS L99
If someone plays with the emergency trunk release, glow in the dark, the trunk will not release, you have to crawl in through back seat, pull release and open, also have been having same problem as the others here, will try the lube.
1camaro70 is offline   Reply With Quote
Exterior foglights don't work? Might be missing the button? Camaro007 5th Gen Camaro SS LS LT General Discussions 62 05-23-2009 07:59 AM
push button start? Yeahyouknwit 5th Gen Camaro SS LS LT General Discussions 40 01-28-2009 05:33 PM
Gap below trunk lid scorpio 5th Gen Camaro SS LS LT General Discussions 8 09-24-2008 09:09 AM
Trunk or Hatchback? LSxcellent 5th Gen Camaro SS LS LT General Discussions 18 06-02-2007 04:40 AM
