Gen5DIY
Old 01-24-2013, 09:33 AM   #1
snickerdoodle
Drives: 2013 1LE AGM 2SS RS M6
Wiring question
Hello, I am installing a cobra 29 ltd nightwatch cb radio in my car. It require a 12 vlt source. Is it possible to wire it to the passenger seat's electrics? Please no comments on why I am putting a cb in my car. I need one.
snickerdoodle is offline   Reply With Quote
Old 01-24-2013, 09:43 AM   #2
snickerdoodle
I just realized this should be in the DIY section
Old 01-24-2013, 10:07 AM   #3
SimpleGreen
Drives: 2013 1SS/1LE IOM
Why not tie into one of the power outlets? Or run an extra wire to the fuse panel on the driver side end of the dash.
2016 Jeep Wrangler Willys 2DR
2013 Camaro SS/1LE SOLD 4/27/16
SimpleGreen is offline   Reply With Quote
Old 01-24-2013, 02:40 PM   #4
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
DO NOT mess with the seats. You will set off an airbag, which is not only dangerous but expensive.
With the driver side door open, pop off the trim piece on the side of the dash, there are three tabs.
Fuses 17 and 18 are KEYED sources (power is only on when the key is in the ACC or ON position). Place an appropriately sized fuse in the back of a fuse tap. Wire the fuse tap to the HOT/power wire on the CB. Place the fuse tap in fuse 17 or 18. Wire the ground to the frame bolt. It is located in the same compartment near the fuse box toward the front of the car.
Hope this helps!
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
