01-24-2013, 11:38 AM | #1 |
L99 1/4 mile track pointers for tonight??
I'm going to the track tonight. L99, cai and ported throttle body are the only mechanical mods.
Stock Pirelli pzeros Temps should be mid to low 60's. What should I drop the tire pressure to? What nannies should I leave on/turn off? The only times I've been to the track were when I owned my ZO6 and of course it was a manual so this will be my first time with an automatic. I suspect this will be a one and done. Track rules require convertibles that run better than 13.49 to have a roll cage or roll bar. I'm not going to mod my car with those so once they kick me off the track I'm done. Any pointers would be great! I want to be kicked out
rx catch can;vmax ported throttle body;bowtie delete;SLP SS emblem;CAI cold air intake
01-24-2013, 12:29 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2010
Turn both nannies off. You do this by holding down the button for 7-10 seconds. You will see both lights appear on the dash.
I'd try low 20's psi. I would start at 25 and drop from there. Put the car in "S"port mode but don't touch the paddles. Burnout long enough to see then smoke but don't be John Force. Bring the car up to 900/1000 rpm and leave from there. Gd luck and have fun!! |
01-24-2013, 12:55 PM | #3 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
He's got you covered, but I'd also watch coolant temps once the car gets too hot you'll see it run 1-2mph slower.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 Last edited by Pro Stock John; 01-24-2013 at 01:27 PM. |
01-24-2013, 01:27 PM | #4 |
Great! ThAnks guys. I'll post up time tomorrow
01-24-2013, 02:24 PM | #5 |
Drives: 2013 2SS/RS L99 Join Date: Oct 2012
I just ran last night , Tires at 26 psi , do a burnout just long enough to see smoke , Turn both nannies off , Put the car in "S"port mode , leave between 1000 and 1200rpm's if the track is hooking and pop the hood between runs to get a good cool down. Also some octane booster will help too!!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley 12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's! 12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best 10.72 @127.93 after heads and Cam and Yank SS3600 |
01-24-2013, 02:32 PM | #6 | |
Drives: 2013 1SS Join Date: Dec 2012
01-25-2013, 06:57 AM | #7 |
I guess they'll let me back.
Obviously I need work on the launches. Best time was 13.55
01-27-2013, 11:34 AM | #8 |
Writer
Post a whole slip, what was your mph and 60 foot?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
01-27-2013, 11:54 AM | #9 |
True on the cool down between runs, and there are a few reasons it will slow down related to the tune.
1: on the factory tune, it starts pulling timing out at 86* and above on intake air temps. 2: The factory tune pulls 2* of timing at 212*f and it gets worse above that. Now on the flipside, runs in the 176-195 range will have no timing pulled provided that the iats are lower than 86*, BUT 160 and below on the coolant temp and it will ADD timing at wot, and at 140* it will add 3* of timing because of the cool temp. At least thats the setting in my stock 2010 L99 ecm file. Looking back, my iats were always around 100* -120* at the start of the run because of the backup in the lanes in memphis. |
01-27-2013, 02:00 PM | #10 |
Drives: 2011 camaro 1ss Join Date: Dec 2012
Ok , is "S"port = shift mode? Newbie here, so we put it in shift mode but don't use the paddle shifters, just let it shift its self? Will it not hold the gear and bounce off rev limiter? Sorry for all the questions, can't wait till my track opens
2011 1SS/RS TSP headers, cat delete, vararam CAI,rhino79 tune.
01-27-2013, 03:22 PM | #11 |
Drives: 2012 Camaro SS 45th Join Date: Oct 2011
Key4 are you in d'burg tn.? Ever go to GRRR?
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh... |
01-27-2013, 05:43 PM | #12 |
Yes sir dyersburg tn. I live about 5 miles from grrr
