JDP Motorsports
Old 01-26-2013, 01:43 AM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
V6 LFX oil pressure?
Do anyone else think these V6 LFX engines run a little high in oil pressure?
Seems my gauge is always pegged out to the right while driving?
Is this normal?
Old 01-26-2013, 08:28 AM   #2
sycraft
COTW 5/06/2013
sycraft's Avatar
yes, normal there is a gm bullitain somewhere I will look for
#PIP4690D: Normal Characteristic - High Oil Pressure Gauge Readings - (Oct 16, 2012)
Subject:Normal Characteristic - High Oil Pressure Gauge Readings
Models:2010 - 2013 Chevrolet Camaro
Equipped with 3.6L LLT or LFX Engines
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some owners may comment that the oil pressure gauge is indicating that the engine appears to be operating with very high oil pressure.
Recommendation/Instructions
Under various engine operating conditions 60 psi (413 kpa.) of oil pressure may be displayed on the oil pressure gauge. This should be considered as normal operation. In addition, during a cold engine start-up (especially during cold ambient temperatures) the oil pressure gauge may display at 70 psi (482 kpa.) or all the way to the right. This condition should also be considered as normal operation. As the engine and oil warm up, the gauge should begin to return to approximately 60 psi (413 kpa.).
Important: Because these operating pressures are considered normal operation, no repair attempts or parts should be replaced.
Customer Information
Please communicate to the customer this condition is a normal operating characteristic of their vehicle. This condition will not impact the designed performance or reliability of the vehicle.
Old 01-26-2013, 11:36 AM   #3
SC2150
These motors the timing chain tensioners are very dependant on oil pressure to keep the chain from jumping teeth so sycraft is correct.
This is also a reason it is so critical to keep an eye on your oil level!!!! Any low oil can allow the pump to suck air when stopping/starting/cornering abruptly and allow the chain to loose tension to the point it can junp teeth and cause piston to valve interference.
Old 01-26-2013, 09:14 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Ok. Thx for the info.
Old 01-27-2013, 01:29 AM   #5
Henry G.
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC
On a side note, I got a scangauge II and programmed it for trans oil temp on my manual trans. Boy it takes a while to heat up!! Driving for a few miles the oil was still only at 70 degrees after a cold night in the garage. Made my think twice about getting frisky until the tranny oil warmed up. CAI temps are damn close to outside air BTW, unwarmed they are the same, warmed 5-10 degrees different during winter, the CAI CAI is doing its job nicely. I figure warm turbulance air off the radiator is getting in but only slightly. For those thinking about getting the gauges, I will say for less than half the price ($140) you can get most of what the gauges do between your stock car info and the scangauge, plus a code scanner and reset, and manually set up display of (2) green and (3) blue matches the stock color of the cluster perfectly. A good and cheaper alternative.
From my cold dead hands......
Henry G. is offline   Reply With Quote
Old 05-07-2013, 02:47 PM   #6
Fourthrail
Drives: 2013 2LT RS
I know this is an older thread, but ...
I never really noticed the reading on this gauge before, but I had my 13 in for its first oil change morning at the dealership ... on the way home, I glanced at the gauge and noticed it was pegged to the right anytime I was accelerating. I went back, and they were very thorough in letting me know this was normal.
They pulled out the manual, the service bulletin, check the oil level, hooked it up to the computer, and even went so far as to pull a brand new one off the lot, and showed me it was the same behavior.
Fourthrail is offline   Reply With Quote
Old 04-11-2015, 11:40 AM   #7
zebber
Drives: 2014 Camaro 1LS
oil pressure
My 3.6 also does this. It does surprise me though that they didn't put a higher range on the gauges, as most gauges are designed to run at the normal at mid- range.
zebber is offline   Reply With Quote
Old 04-11-2015, 02:17 PM   #8
sycraft
COTW 5/06/2013
sycraft's Avatar
It is a universal Guage that was meant for the v8.
Old 04-22-2015, 06:27 PM   #9
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Using a dash logic, under hard accelerating, ive seen it get up to 100-102 psi...
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 04-23-2015, 08:59 AM   #10
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
Is this supposed to be normal ??
If I have the car under 2K RPM the oil pressure is not all the way to the right
but once I hit 2K RPM or higher it stays all the way to the right.
Is this normal at all ???
Current Car(s)
2015 Camaro 2SS 1LE 6.2L V8- Dream Car
2015 Equinox 2.4L I4- (Married Man with a kid ^__^)
Previous Cars
2013 Camaro 1LS 3.6L V6 - Traded
1995 Toyota Pickup 2.4L I4- Sold
1985 Mazda Rx-7 1.8L (Red) - Total Loss
1985 Mazda Rx-7 Turbo 1.8L Rotary ( White)- Sold
1996 Honda Accord 2.7L V6 - Wrecked
1998 Dodge Intrepid POS Engine- Lemon
rgrmoreira13 is offline   Reply With Quote
Old 04-23-2015, 09:05 AM   #11
sycraft
COTW 5/06/2013
sycraft's Avatar
Yes. Normal
Old 04-23-2015, 12:45 PM   #12
Drives: 2016 camaro
Originally Posted by sycraft View Post
Yes. Normal
Yahtzee!
So no need to panic... and you do realize the 4 pack gauges only go to 70psi, right?
In similar fashion, if a car has a 160 speedo, and the car goes above 160...it's gonna stay pegged at 160 no matter how much faster the car goes... the only time it will move back under 160 is when the car goes under 160.
So in the same sense the oil pressure gauge will work the same way.
Old 10-03-2016, 04:50 PM   #13
mcvaldez83
Drives: 2015 Chevrolet Camaro
Oil pressure
My 2015 is in the shop now. Oil pressure kept pegging out on acceleration at 2000 rpm. Wouldn't stop until I let off , then while idle it dropped down to around 10psi. Car only has 12,900 miles They are keeping it over night because they don't have a definitive answer for me. Making me worry
mcvaldez83 is offline   Reply With Quote
Old 10-05-2016, 08:54 PM   #14
redcoats1976
mine idles at 15 PSI when hot.between the very thin oil and low tension oil rings its pretty much normal and done to get better fuel mileage.if you didnt have a pressure guage,just an idiot light you would never know and not worry about it.you should have the same 6 year/100,000 mile powertrain warrantee i do.if it wasnt getting higher pressure as the rpms go up i would be concerned...
