JDP Motorsports
Old 01-29-2013, 02:51 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Turbo questions
Ok so this has nothing to do with my car, but im building a turbo kit for another bike.
On a GT25 ball bearing turbo do you have to run coolant threw it or can I block off the ports?
Is there a place I can get a Garrett GT25 BB for under a grand or is there another company that makes a turbo that will compair to the GT25 BB that dont cost a grand? Ive been looking for sometime and not even able to find one used. Im not running over 6PSI and I would like to get one that has an interanl wastegate.
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Holley 12-1800 pump, DW2200cc injectors, Snow performance progressive meth kit, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 17x10 with M&H racemasters, AEM gauges, G-Force II boost controller
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 01-29-2013, 09:02 AM   #2
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
You don't need coolant for a BB but it is highly recommended. If you don't, make sure you let the turbo cool down before you shut off the bike.
Also, you can buy a t25, uses the same exhaust flange and then upgrade to a gt25 when one becomes available. T25s are everywhere used, cheap, and will make decent power at low boost on a bike and spool is not a huge issue since bikes can rev to the moon.
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
Pt_killa is offline   Reply With Quote
Old 01-29-2013, 09:46 PM   #3
2010_camaro
im going to stick with the GT25 but where can i get a 6 psi wastegate? i see they came with 14.5psi wastegates
