Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V6 Bolt-Ons & Tunes
Old 01-29-2013, 08:00 PM   #1
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Talking Intakes Intakes INTAKES!!! V6 LLT| FREE SHIPPING | JDP Motorsports
Hello Camaro5!
JDP motorsports is proud to offer a wide range of intake system options for your 2010-2011 LLT
K&N
K&N - Aircharger Intake System - 2010 Camaro V6 - 63-3075
K&N intake system for a 2010 Camaro V6 includes a free-flowing composite intake tube, heat shield, and high flow K&N washable air filter. This system replaces the factory restrictive intake system and is designed to dramatically reduce intake restriction resulting in increased horsepower and performance.
Note: This air intake can't be sold in California and is not legal for use in California or other states adopting California emission standards.
Product Features
- Horsepower gains of 14.96 at 6200 RPM
- Guaranteed horsepower gain
- Designed to improve throttle response and engine sound
- Free-flowing high density polyethylene tube
- Replaces entire factory air intake system
- Lasts up to 100,000 miles before service is required (depending on driving conditions)
- Easy to install, usually in 90 minutes or less
- Includes K&N's Million Mile Limited Warranty!
- Includes Free Shipping to the Lower 48!
MSRP: $509.99
Sale $280.99
K&N - Typhoon Series Intake System - 2010-2011 Camaro V6 - 69-4520TP
K&N typhoon series intake system for a 2010-2011 Camaro V6 includes a free-flowing mandrel-bent chrome-like finish aluminum tube that accommodates the factory mass air sensor and crank case vent hose, heat shield, and an oversized cone shaped air filter. This system replaces the factory restrictive intake system and is designed to dramatically reduce intake restriction resulting in increased horsepower and performance.
Some Typhoon Air Intakes are not legal for use in California and other states adopting California emissions standards while others are CARB exempt and 50 state legal.
Product Features
- Horsepower gains of 13.45 at 6200 RPM
- Low restriction aluminum tube
- Washable and reusable lifetime air filter
MSRP: $565.99
Sale $311.99
Roto-Fab - Intake System - 2010-2011 Camaro V6 - RTF-10151015
Roto-Fab intake for the 2010-2011 Camaro V6 includes a modular intake tube, air box, and high flow washable air filter. Roto-Fab's air box is designed to keep engine/radiator heat away from the filter allowing cool air to go to the engine resulting in increased performance, horsepower, and torque. This system comes with everything you need for a complete installation. No tuning required.
This product is not for sale or use in California.
Product Features
- Easy to install with basic hand tools
- Air Box custom made to keep engine/radiator heat away from your filter
- Molded air box adapter tube incorporates the MAF (mass air flow) sensor
- Large 6" filter mounting flange
- Inlet elbow available in cross link poly (plastic), polished or painted stainless steel or with carbon fiber hydrographics finish
- High quality silicone hoses available in a variety of colors
- Air box available in a variety of colors
- Installs easily using factory mounting points
- Doesn't set any codes/ no tuning required
- Oil or dry filter available
- Free Shipping to the Lower 48!
- Made in the USA
Note: Roto-Fab's powder coat finish is durable and provides a close color match however varies slightly from run to run. Also the surface isn’t quite as smooth as their automotive finish. Please allow a 1-2 week lead time for automotive painted finishes.
Starting at $329.95
SLP
SLP - Blackwing Cold Air Induction Kit w/Blue Filter - 2010-2015 Camaro V6 - 620046
SLP - Blackwing Cold Air Induction Kit w/Black Filter - 2010-2015 Camaro V6 - 620045
SLP Blackwing cold air induction kit for the 2010-2015 Camaro V6 features an oversized air box assembly, OEM quality injection molded intake tube, and washable, reusable dry black air filter for maximum performance. This intake directly replaces the restrictive factory system and comes with all the necessary hardware for a complete bolt on installation. Back by SLP's 3 year or 36,000 mile limited parts warranty and require no custom computer calibration.
Note: Not available for sale or installation in the state of California.
Product Features
- Replaces restrictive power-robbing factory intake system
- OEM quality injection molded in black with “Blackwing” logo
- Washable, Reusable, Dry Blackwing Air Filter
- No calibration required
- Easy bolt-on installation Installation hardware and detailed instructions
MSRP: $349.95
Sale $335.95
Vararam - DZ-6 Ram Air Induction System - 2010-2011 Camaro V6 - VR-Camaro-V6
Features the latest Vararam Technology including Reverse venturi 85MM MAF, Integrated rear air-horn to boost flow through the throttle body, sound frequency cancellation, to remove that whomp, whomp sound from your intake, engineered with a mild built in tune and a quick easy installation (we did it in under 9 min!).
This is the most powerful induction system of any kind for the 2010-2011 Camaro. Every aspect of induction technology has been used in this system. The3.6L LLT Camaro unit is unique in that it is designed around the LLT engines cross ram intake manifold flow architecture and its need for maximum plenum volume. Unleash the power of your Camaro!
Product Features
- Reverse venturi 85MM MAF
- Integrated rear air-horn to boost flow through the throttle body
- Sound frequency cancelation, to remove that whomp, whomp sound from your intake
- Engineered / built in tune. (mild)
- Quick and easy installation (we did it in under 9 min!)
- Proudly Made in the USA
MSRP: $378.00
Sale $349.95
Injen
Injen - Polished Power-Flow Series Air Intake - 2010-2011 Camaro V6 - INJ-PF7011P
Injen - Black Power-Flow Series Air Intake - 2010-2011 Camaro V6 - INJ-PF7011WB
Injen high performance power-flow air intake system for the 2010-2011 Camaro V6 is made from lightweight 6061 T-6 aluminum alloy and includes a wrinkle black intake tube, enclosed air box, and nano-fiber dry filter. This system features MR Technology created by Injen for safe air/fuel ratio and extremely efficient tuning process. This system is dyno proven to add 13+ HP and 11+ ft/lbs of torque.
Product Features
- Lightweight aluminum alloy
- Enclosed air box
- Nano-fiber dry filter
- Bolt-on installation
- Manufacturer Limited Lifetime Warranty!
- Made in the USA!
Price $353.68
Injen - Black Cold Air Intake - 2010-2011 Camaro V6 - INJ-PF7010WB
Injen - Polished Cold Air Intake - 2010-2011 Camaro V6 - INJ-PF7010P
Injen high performance intake system for the 2010-2011 Camaro V6 is made from lightweight aluminum and features MR Technology created by Injen for safe air/fuel ratio and extremely efficient tuning process. This system is dyno proven to add 16+ HP and 16+ ft/lbs of torque.
Note: The intake pictured above is the polished version.
Product Features
- Made in the USA!
Price $374.74
Airaid
Airaid - Intake System - 2010-2011 Camaro V6 - AIR-251-242
Airaid MXP Series intake system for the 2011-2012 Camaro V6 is made from a new one piece roto-molded air box, cross-linked high-density Polyethylene air intake tube, and built-in velocity stack for greater airflow. This system is a direct bolt on and doesn't require a tune. Gains of 11 horsepower and 14 lb-ft of torque have been seen!
Note: Not legal for sale or use in California.
Product Features
- Horsepower increase guaranteed
- True OEM direct replacement
- Hand poured urethane body – won’t crack, shrink, or curl like rubber or plastisol
- AIRAID’s exclusive unique filtration technology – enables the AIRAID filter to filtrate far superior to the average cotton filter
- SynthaMax dry filter in red, black, and blue color options
- Proudly Made in the USA!
MSRP: $461.43
Sale $369.14
Airaid - Intake System - 2010-2011 Camaro V6 - AIR-250-242
The AIRAID MXP Series intake for the 2010-2011 Camaro V6 comes with a new one piece roto-molded air box that addresses all the shortcomings of the restrictive factory design. Then AIRAID® adds a new air intake tube constructed of cross-linked, high-density Polyethylene that is designed using extensive computer modeling to maintain proper mass air flow readings and calibration. They also frequently have a built-in velocity stack, which further promotes airflow. What this all means is a simple-to-install system that was designed using extremely sophisticated technology to increase airflow while maintaining proper air / fuel ratios, therefore eliminating the need for re-calibration once installation is complete. Just bolt it on and go! Like any other AIRAID® Intake System, the MXP includes an AIRAID® Premium Filter that is sized to maximize power and efficiency.
Product Features
MSRP: $451.23
Sale $360.98
Cold Air Inductions
Cold Air Inductions - Intake System - 2010-2011 Camaro V6 - 501-1036-10
Cold Air Inductions intake system for the 2010-2011 Camaro V6 features an aluminum insulated air box, air box lid with a filter inspection window, thermal coated intake tube, high performance air filter, and all necessary clamps, coupler, and hardware for a complete installation. This system is a direct replacement for the factory air box and retains the factory washer bottle in the stock location. No modification required.
The Cold Air Inductions sleek looking intake system offers gains of 16 RWHP without a tune required.
NOTE: This air intake can't be sold in California and is not legal for use in California or other states adopting California emission standards.
Product Features
- Powder coated near chrome finish or Black aluminum insulated air box
- Air box lid with filter inspection window
- 3.5" (89mm) ceramic coated intake tube
- High performance oiled air filter (CF-8350)
- Black silicone elbow/Stainless clamps
Black
MSRP: $399.95
Sale $379.95
Chrome Finish
MSRP: $419.95
Sale $398.95
We are also proud to offer VMAX CNC ported throttle bodies & VMAX ICE-olators to compliment your intake system!
VMAX - CNC Ported Throttle Body - 2010-2011 Camaro V6 - Part #: VMAXV6TB
VMAX Motorsports CNC ported throttle body for the 2010-2011 Camaro V6 LLT offers increased throttle response as well as HP/TQ gains through out the power band. We've seen 4-6 RWHP and peak numbers up to 12 with this simple and inexpensive mod; for the money they can't be beat! These TB's don't require any tuning and the install is 15-20 minutes taking your time. We offer NEW TB's only.
Price $350.00
Price includes new GM Camaro V6 LLT throttle body and porting services.
VMAX - ICE-olator - 2010-2011 Camaro V6 - Part #: 250-LP
VMAX CNC ICE-olator one piece 9.75mm high tech heat resistant plastic block designed to reduce the temperature of the intake manifold allowing a cooler air charge resulting in increased power. HP gains with the ICE-olator are about 18-20! Includes free shipping to the lower 48!
Installation takes about 15-20 min. You reuse your existing gasket on the bottom side of the ICE-olator and bolts. You will need to purchase Permatex Right Stuff from your local auto parts store to complete the install. Begin with putting your gasket in place and applying the right stuff around each port on the top side. Next begin snugly bolting the ICE-olator in by starting with the furthest rear and front bolts. Then work your way through the rest of the bolts evenly hand tightening each. Make sure you don't over tighten.
Note: The VMAX ICE-olator is recommended to be used with an aftermarket cold air intake for top end gains.
Price $159.95 Shipped!
WE INSTALL PARTS!!
If you are looking to have work performed or have one of our packages installed on your vehicle, we have a facility in Sandy, Utah where we perform everything from bolt-on installations, Dyno testing/tuning and complete race car builds. Our install shop fills up fast, so please call us to set up an appointment.
Best regards,
Kayla L.
801.545.4215
Old 02-11-2013, 06:54 PM   #2
JDP Sales
JDP Sales's Avatar
Thanks for the orders Camaro5!! Please feel free to call, PM or email us anytime with questions! We are always happy to help!
Best regards,
Tyler
888-308-6007
Old 02-23-2013, 03:22 AM   #3
Oneflyenyceguy
Hmm...Something Clever
Oneflyenyceguy's Avatar
Drives: Blac on Blaq on Blak 2012 Camaro LS
I'm ready to place an order for a polished cai for a lfx
Adjustments: 20% tint all around, Emblem Pros Dash plaque, Rockford Fosgate P-300/12
Oneflyenyceguy is offline   Reply With Quote
Old 02-25-2013, 01:34 PM   #4
JDP Sales
JDP Sales's Avatar
Feel free to give me a call! I will be in the shop all day today!
Best regards,
Tyler
888-308-6007
Old 03-08-2013, 05:15 PM   #5
JDP Sales
JDP Sales's Avatar
All PM's and emails have been replied to! We truly appreciate everyone's support! Please feel free to call, PM or email me anytime with questions or pricing. Have a great weekend!!
Best regards,
Tyler
888-308-6007
Old 03-08-2013, 11:05 PM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Got any LFX vmax throttle body in? PM price and lead time to ship to 92399
Mods:
Old 03-11-2013, 12:27 PM   #7
JDP Sales
JDP Sales's Avatar
In stock and ready to ship! Please feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 03-22-2013, 01:23 PM   #8
JDP Sales
JDP Sales's Avatar
Get your orders in before the weekend! We have these systems in stock and ready to go! Please feel free to call, PM or email me anytime with questions or pricing! I appreciate everyone's support! Have a great weekend everyone!
Best regards,
Tyler
888-308-6007
Old 04-18-2013, 06:49 PM   #9
JDP Sales
JDP Sales's Avatar
Remember to call, PM or email me for possible discount codes and promo's!
Best regards,
Tyler
888-308-6007
Old 05-03-2013, 01:14 PM   #10
JDP Sales
JDP Sales's Avatar
Intake systems are in stock and we still have plenty of LLT VMAX throttle bodies and ICE-olators as well! Please feel free to call, PM me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 06-19-2013, 06:49 PM   #11
JDP Sales
JDP Sales's Avatar
Specials are still on! Happen to find one of these intake systems at a better price? Let me know and we will match or beat it!
Best regards,
Tyler
888-308-6007
Old 07-08-2013, 02:45 PM   #12
JDP Sales
JDP Sales's Avatar
Plenty of intake systems and VMAX throttle bodies in stock! Bundle and save! Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 07-09-2013, 02:38 PM   #13
Kohdaa
Drives: 2011 Imperial Blue Metall RS Camaro
Would I save if I bundled a roto fab intake and a throttle body?
Kohdaa is offline   Reply With Quote
Old 07-09-2013, 02:45 PM   #14
JDP Sales
JDP Sales's Avatar
You bet! Give me a call or shoot me a PM and we'll see what we can work out!
Best regards,
Tyler
888-308-6007
filter, free shipping, intake, jdp motorsports, throttle body
