JUICEDMOTORSPORTS
Old 01-31-2013, 10:29 AM   #1
DFWZ28
DFWZ28's Avatar
Drives: 2010 SS
Strut Tower Brace
how many of you guys have a strut tower brace? i have been thinking about getting one, really like the looks of the ZL1 brace.
what would you recommend, how difficult / easy was it to install?
pics if you can.
thanks in advance
Lupe
DFWZ28 is offline   Reply With Quote
Old 01-31-2013, 10:32 AM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
If you have a 2010, you will be stuck using the BMR because the Chevy one won't work.
Old 01-31-2013, 10:58 AM   #3
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Same is true for some early '11s....Couldn't tell you where they come from, but I think an adaptor kit of shims, spacers, what-not is out there so the factory brace can be used on the first version of the towers...
90503 is offline   Reply With Quote
Old 01-31-2013, 10:59 AM   #4
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
eeehhh WRONG lol. they will work with the 2010. but you have to purchase the bolt kit for $130-150 ish and the chevy strut bar will fit. i have a 2010 and it didnt come with the holes either.
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 01-31-2013, 11:05 AM   #5
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
There is an adapter kit out there which lets you use the convertible/ZL1 strut brace on 2010 or early 2011 Camaro's.
Old 01-31-2013, 11:06 AM   #6
wakespeak
wakespeak's Avatar
Drives: 2013 2SS LS3/NPP
I recommend it. It does make the car chassis stiffer, which is why you see it on the 1LEs and ZL1s. Creaking eliminated when turning into driveways and other off camber stuff.
You need to buy the tower brace and the bolts. The torque spec is: 22 N-m (16 ft-lbs). 10 minute install. Install on flat ground.
wakespeak is offline   Reply With Quote
Old 01-31-2013, 11:09 AM   #7
jpwickl
Drives: 2013 2LT Convertible
You could buy a convertible, and the brace will come standard
jpwickl is offline   Reply With Quote
Old 01-31-2013, 11:19 AM   #8
MrWray
SYBIL
MrWray's Avatar
Drives: 2013 2SS/RS, silver ice metallic
the 2013 has the holes pre-drilled for the brace, it only took me like 3 minutes to install it. its a noticable difference when cornering and taking curves. plus it looks badass
MrWray is offline   Reply With Quote
Old 01-31-2013, 11:22 AM   #9
DFWZ28
DFWZ28's Avatar
Drives: 2010 SS
that looks really nice wray. i have a 10 so probably will have to drill the holes.
Old 01-31-2013, 11:23 AM   #10
BMR Sales
BMR Sales's Avatar
Drives: Race Car
pics if you can.
thanks in advance
Lupe
Like everyone said, the factory GM strut tower brace won't work without buying the install kit so by the time you buy the GM strut tower brace itself and the install kit you end up with a strut tower brace that is close to $300. We have some more affordable strut tower brace options that will not only stiffen the chassis up but also help dress up the engine bay.
BMR two point strut tower brace (STB013)
BMR four point strut towe brace (STB014)
BMR four point strut tower brace (STB016)
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 01-31-2013, 12:31 PM   #11
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
^^ The BMR braces are awesome! Feel free to Call, PM or email me with questions.
Best regards,
Tyler
888-308-6007
Old 01-31-2013, 02:49 PM   #12
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
I bought a BMR strut brace and had it shipped to me unfinished. I had it chromed by a local chroming company. I like the way it turned out.
Russ
OHIOSS is offline   Reply With Quote
Old 01-31-2013, 03:29 PM   #13
JM20
JM20's Avatar
Drives: 2010 2SS/RS L99 IOM
Russ
That looks bad ass! How hard is it to install the BMR? How is it fastened to the towers?
JM20 is offline   Reply With Quote
Old 01-31-2013, 03:59 PM   #14
PAUL SS
PAUL SS's Avatar
You have to drop the struts and drill 4 holes on top of the tower and bolt it on.
