Jason 98 TA
Old 02-24-2013, 11:26 AM   #57
Parabolica
Drives: 2011 2SS
Originally Posted by HammerheadRed View Post
Does the BMR STB016 strut tower brace fit 2010 Camaro 2SSRS with Magnusson Supercharger? I saw the Hotchkis on one above...is that the only choice out there? Thanks
The chevy brace works fine with the Magnuson.
Parabolica is offline   Reply With Quote
Old 02-25-2013, 01:55 AM   #58
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
If my research is correct this should be the correct bolt size, Bolt M8 x (1.25mm) x 40mm, input ?
Sapper12b is offline   Reply With Quote
Old 02-25-2013, 07:54 AM   #59
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
M8 X 1.25 X 35mm (6): PN:11589407
GM MSRP $4.48
Torque to 18 ft/lbs or 216 in/lbs
I just went to local hardware store for about a 1/3 less.
bannonm is offline   Reply With Quote
Old 02-26-2013, 01:04 AM   #60
Sapper12b
HTCC Member
Sapper12b's Avatar
Cool, Thanks
Old 02-26-2013, 01:26 AM   #61
SoCal Swagger
SoCal Swagger's Avatar
Drives: RS
strut brace mounting question..
Since i'am going to do sways i was considering a strut brace aswell. Can someone break it down for me. I posted pics to kinda of demonstrate what iam talking about.
I see how the BMR brace are bolted strait to the strut then i seen the oem 1LE brace and Hotchkis are bolted to what appears to be the car. Like the oem and Hotchkis brace how does that brace the strut if its not bolted to it.
SoCal Swagger is offline   Reply With Quote
Old 02-26-2013, 08:56 AM   #62
BMR Sales
BMR Sales's Avatar
Drives: Race Car
A strut tower brace does not brace the strut itself but atcually braces the strut tower and helps keep the towers from flexxing in any way. The silver Camaro with the BMR strut tower brace is a 2010 or early 2011 Camaro and the green Camaro is a late 2011 and newer Camaro that actually has different style strut towers which is why the strut tower braces mount up so differently.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 02-26-2013, 08:59 AM   #63
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The STB016 doesn't have the clearance to be able to work with a Magnuson Supercharger but we are working on one that will.
The GM strut tower brace will not work on a 2010 or early 2011 without buying a pretty expensive mounting kit in addition to the strut tower brace itself.
T.C. Davis
813-986-9302
Old 06-15-2013, 07:54 PM   #65
Sftshldr
Beast Rider
Sftshldr's Avatar
Drives: 2017 ZL1 BLK A10
1LE bar - yes with stock SS Hood.
ZL1 bar - no with stock SS Hood.
ZL1 is / has more bend height to clear the Supercharger and needs the ZL1 hood which has a taller center section.
My SS with 1LE bar.
"Just looking fast is sometimes all it takes!!!"
Sftshldr is offline   Reply With Quote
Old 06-25-2013, 03:22 AM   #66
teobilly
teobilly's Avatar
Drives: Camaro 2SS 2013 (EU Version)
My SS with 1LE bar.
Hennessey told me that I can!
just need to add a couple of holes very simple.
teobilly is offline   Reply With Quote
Old 07-01-2013, 07:27 PM   #67
rray
rray's Avatar
Drives: 2013 GAZ 2SS/RS
I'm almost there. Saturday I de-greased the 1LE brace for my SS, then applied adhesion promoter. Sunday I painted it black, and today masked it for Camaro lettering. I used a laser engraver to cut the lettering:
Then painted the lettering the same silver that's on my engine cover, and finished with matte clear coat.
I'm going to let it cure for a few days before installing, as i still have to mount my catch can first.
If you see it, get it, for tomorrow it may be gone!
rray is offline   Reply With Quote
Old 07-13-2013, 01:04 PM   #69
2Carats
2Carats's Avatar
Drives: '12 Camaro 2SS/RS LS3
Ordered the GM brace and had it painted white to match the car on my '12 2SS.
Mind controlled by Cerebro
I solve problems for a living. Either accept my advice or go figure it out on your own.
2Carats is offline   Reply With Quote
Old 07-18-2013, 04:26 AM   #70
MrWray
SYBIL
MrWray's Avatar
Drives: 2013 2SS/RS, silver ice metallic
You cant go wrong with the GM strut brace
MrWray is offline   Reply With Quote
