Emblempros
Old 02-06-2013, 08:22 AM   #57
atomicfusion
Drives: 07 Z06 11 L99 SS 16 c7 16 1SS
I know you would need to change the charge pipe, but I'd guess it would work with a ZL1 as well...
I know Jeff would be better to answer that question though.
atomicfusion is offline   Reply With Quote
Old 02-06-2013, 09:05 AM   #58
IPSjeff
Drives: 2009 ZR1
Originally Posted by atomicfusion View Post
I think it was 9 psi, but Jeff would know better than me. I haven't been up to the shop for a couple of days.
Correct. Boost peaked at 9.x and was in the 8.x - 9 range where it made peak-power.
Jeff
IPSjeff is offline   Reply With Quote
Old 02-06-2013, 09:08 AM   #59
IPSjeff
Drives: 2009 ZR1
Correct again. The kit wouldn't go on "As-is" obviously but could be made to work if you wanted to keep the blower in place. Since we just made 998rwhp on a TT GT500 that still had the stock blower I can tell you the blower proves to be a restriction pretty quickly but if you aren't shooting for 4-digit numbers at the wheels it can be worked-around.
Jeff
Old 02-06-2013, 10:31 AM   #60
BlakeH827
Drives: 2010 Camaro SS
How far below the frame do the turbos sit? Are there clearance issues, I wanted to lower my car but after looking at the pictures I think I would hit the turbos.
BlakeH827 is offline   Reply With Quote
Old 02-06-2013, 10:48 AM   #61
IPSjeff
Drives: 2009 ZR1
We have the original kit on quite a few lowered cars running around. Since the skid plate is the lowest point it will not change even though these turbos will have more room between them and the plate. In other words, actually driving over something and physically hurting the turbos is an extreme long-shot.
I will post up a few pics from underneath before we start taking this kit off for the GT35's.
Jeff
Old 02-06-2013, 12:10 PM   #62
BlakeH827
Jeff
Awesome, I just want to go 1 inch lower. It would be great if u could post pics before you take it apart.
Old 02-06-2013, 01:54 PM   #63
IPSjeff
Drives: 2009 ZR1
Video of the 646rwhp pull:
Old 02-06-2013, 04:58 PM   #64
TH SS Vert
TH SS Vert's Avatar
Drives: 2013 Camaro SS
Awesome! That thing looks like it wants to leap off the rollers when the turbos spool!
2013 Camaro 2SS coupe/6-sp manual/Inferno Orange Metallic/NPP exhaust.
IPS entry level twin turbo kit
681 rwhp/665 rwtq
10 lbs of boost
TH SS Vert is offline   Reply With Quote
Old 02-06-2013, 08:52 PM   #65
atomicfusion
That's a pretty bad a$$ ride right there...
Old 02-09-2013, 11:08 PM   #66
MileMAN402
RIP JoePa
MileMAN402's Avatar
Drives: 2010 2SS/RS & 2001 Audi S4
What's the efficiency range for these turbos? Is there a graph available?
MileMAN402 is offline   Reply With Quote
Old 02-10-2013, 08:03 AM   #67
roller
roller's Avatar
Drives: 72 nova 10.5 tire car
so how are you feeding the turbos engine oil and how are you returning the oil wioth these low mount turbo's.
also do you have any pics of the air intake area what keeps rocks,water you name it out of the turbos.
roller is offline   Reply With Quote
Old 02-10-2013, 08:39 AM   #68
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
glad u guys are makin something like this i see alot of ppl wanting it.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 02-11-2013, 08:23 PM   #69
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
How much weight does this TT setup add? Nice numbers and turbos are easier on the drive train.
Fraxum is online now   Reply With Quote
Old 02-13-2013, 11:54 AM   #70
IPSjeff
Drives: 2009 ZR1
I don't have a graph readily available on the turbos but for those considering this kit you most likely will have a ceiling in the 650-750rwhp range depending on all variables. This kit is for anyone wanting 600-700rwhp on a bone-stock or light bolt-on car since that is effectively the limit of the stock engine / drivetrain (Or slightly beyond )
If you plan on a built engine to really run some boost or want to make more than 800rwhp that is where the GT-based kit shines. The large 1.02 A/R and 3" downpipes will flow enough for 1200+rwhp.
Jeff
entry-level, ips, ips motorsports, turbo kit, twin-turbo
