SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 02-02-2013, 10:37 AM   #1
pgt
Drives: 2013 ZL1
Rear wheel ballast/sandbags in ZL1?
Is there any point in placing a ballast in the rear portion of the ZL1 to improve traction when accelerating? Or is ZL1 already balanced for the best possible traction?
pgt is offline   Reply With Quote
Old 02-02-2013, 01:34 PM   #2
ZL1ster
ZL1ster's Avatar
Drives: '13 ZL1 IOM M6
Have you gone WOT?
She squats and scats like a stuck 4K-lb SC-piggy
...well she does chirp thru several gears and if it's cold like NY, suggest waiting until it's a little warmer.
See threads about our tires...not good under 40 degree temps.
ZL1ster is offline   Reply With Quote
Old 02-02-2013, 03:19 PM   #3
FAIRNOT LZ1
It's in black & white
FAIRNOT LZ1's Avatar
Drives: 2012 ZL1 Summit White #1366
FAIRNOT ZL1
FAIRNOT LZ1 is offline   Reply With Quote
Old 02-03-2013, 09:37 AM   #4
pgt
Drives: 2013 ZL1
I was talking about dry asphalt in warm weather.
Old 02-03-2013, 10:12 AM   #5
FAIRNOT LZ1
FAIRNOT ZL1
Old 02-05-2013, 08:44 PM   #6
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The ZL1 already has pretty good weight distribution. I think 53/47 if not a touch better. So on a 4200 lb car, that gives you almost exactly 1 ton over the rear tires, which happen to be a foot wide. For all that adding weight will do to improve traction, it will probably hurt it just as much because its harder to get the added mass moving.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 02-05-2013, 08:59 PM   #7
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I'm thinking I read somewhere the balance was something closer to 51/49 ...
Old 02-06-2013, 08:13 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
It didn't change a whole ton compared to an SS, but iirc, actually improved a hair...due to that heavy differential out back (and LOW ).
Any traction you might gain would be counter-balanced with slower acceleration due to added weight.
The car is already nearly 50/50, and the MR lets it squat pretty good in the back....I don't see much gains likely by this.
Old 02-06-2013, 11:14 PM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
Now that you guys mention it, I remember hearing the same thing
