Cold Air Inductions
Old 02-02-2013, 04:24 PM   #15
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Originally Posted by KMPrenger View Post
I agree with your setup, or really with using slicks on any car that TC should be off, but with something closer to stock, TC on at launch seems to work fine.
Oh definitely. With the Pzeros I had to leave TC on and launch right off of idle to get the best 60' once I got the tune and headers.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 02-02-2013, 05:17 PM   #16
SC2150
There is something in the tables that are causing the throttle to not open past a certain point until x amount of MPH is reached. LLT does not do it, only the LFX so it just needs a work around (I'm confidant you will solve it) and then watchout!.
Old 02-02-2013, 06:09 PM   #17
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Originally Posted by GretchenGotGrowl View Post
Yeah, the wide band worked perfectly from the time I got on the interstate until I stopped for gas in Conway. The whole time is was reading 13.4-13.8 so I'm pretty sure its fat on PT. Not too worried about it...how many 4000 lb 500 hp cars get 24 MPG at 75 MPH???
Damnnnn wish my afr's would read steady like that when cruising.
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
Old 02-02-2013, 07:03 PM   #18
CiscoBee
Drives: 2010 Camaro Rally Yellow 2LT
Congrats on the great ride and numbers!!!!
CiscoBee is offline   Reply With Quote
Old 02-02-2013, 08:05 PM   #19
camaro-21
camaro-21's Avatar
Drives: 2011 cyber grey metallic camaro v6
maybe for the throttle response you could try a sprint booster cuz i put one in my car and it definitely made a difference and opened the throttle body a lot faster.
2011 camaro v6- sts turbo w/ meth injection, barton short throw, spec stage 3+ clutch, forgestar f-14 rims, Nitto invo tires, pfadt sway bars drop springs and end links, rx catch can, goodridge stainless steel brake lines, aac halos afterburner taillights and sidemarkers, sebon carbon rear diffuser.
camaro-21 is offline   Reply With Quote
Old 02-02-2013, 08:14 PM   #20
GretchenGotGrowl
It isn't the response, it is probably some nanny GM built in. We command 100:% and it only gives us 40-50%. Don't think a sprint booster ca fool it that much.
Old 02-03-2013, 01:37 AM   #21
camaro-21
camaro-21's Avatar
Ok well update us when you get it figured out and when you try out the new fuel system cuz im putting new heads and pistons in my car and I just put in an efr turbo and new meth kit. Next on my list is the zl1 fuel pump.
Old 02-03-2013, 08:27 AM   #22
GretchenGotGrowl
Will do.
Old 02-03-2013, 08:47 AM   #23
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Awesome review and info man. Thanks for keeping us posted. Loving this build
CAMARO
Old 02-03-2013, 09:17 AM   #24
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Great review and can't wait for the 10second pass. Are you running the Autolite plugs with your new setup?
etmx183 is offline   Reply With Quote
Old 02-03-2013, 09:21 AM   #25
GretchenGotGrowl
Still running the stock plugs LOL! Just gapped them down a bit. We've pulled them several times and they still look good. Lower CR may be helping us there, too.
Old 02-03-2013, 09:50 AM   #26
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
Really nice good luck ,
1969to2010 is offline   Reply With Quote
Old 02-03-2013, 10:24 AM   #27
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Nice write up an sweet build
Sent from my iPhone 5 because I drop my iPad on space mountain.
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 02-03-2013, 02:33 PM   #28
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Hey Gretchen.. Little hint on the throttle stuff...
LESS is better on engine torque management tables.
You have my cell number, throw me a text I'll explain.
Matt @ FSP is offline   Reply With Quote
