Rick@Livernois
Old 02-02-2013, 06:33 PM   #1
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
Traction issues was a bushing issue !
http://www.camaro5.com/forums/showth...=231268&page=3
My car would sway back and fourth at wide open throttle, the higher the boost the worse it would be. It was an unsettling feeling, actually scary . Also we found toe links to be loose which we think was from the movement in the rear cradle
The issue presented after my turbo install and the boost was turned up.
Three of my buddy's cars had the same issue.
All cars 450 rwhp or better all cars have the same BMR trailing arm bushings.
Wasted a lot of time and money plus alot of agita, between alignments etc... Nothing worked. people were very helpfull and had a lot of ideas but nothing panned out until today. Jordan at jdp performance had an idea to try different bushings. I ordered the bushings. Installed them today and the car is fixed. She still spins but with the power it's to be expected but she goes straight again and is much safer. I'm going to have it aligned hopefully the last time for a while.
We went with pfadt outer trailing arm bushings which we found to be stiffer and larger plus the sleeve inside was larger as well.
Not trying to bash BMR At all I have BMR trailing arms toe links and subframe full poly subframe bushings which are all great quality which im very happy with. For our applications the pfadt bushings worked. Hope this is a help to anyone having the same issue.
Special thanks the Ted jannetty Cisco at newgen Jordan jdp motor sports and anyone who had given advice
1969to2010 is offline   Reply With Quote
Old 02-02-2013, 08:59 PM   #2
mel1
Yeah buddy
mel1's Avatar
Drives: 2010 Camaro SS Inferno Orange
Glad things worked out for you....I hear nothing but good things about pfadt
2010 SS IOM L99,Heritage grille,Rear Bowtie Delete
mel1 is offline   Reply With Quote
Old 02-02-2013, 09:02 PM   #3
1969to2010
The Man in Black
1969to2010's Avatar
Thanks I'm hoping that's the end of the camaro mysterys
Now I can start saving for my cam !
Old 02-03-2013, 11:33 AM   #4
enyce0387
enyce0387's Avatar
Drives: 2011 camaro 2ss/rs ls3
oh no! just placed and order for bmr trailing arms and bushing, oh well only like $30 if its a problem ill just buy some pfadt
enyce0387 is offline   Reply With Quote
Old 02-03-2013, 02:51 PM   #5
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Same here...
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 02-03-2013, 02:57 PM   #6
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Which 1 did u replace?
Old 02-03-2013, 02:57 PM   #7
1969to2010
The Man in Black
1969to2010's Avatar
Call Jordan from jdp 1888 308 6007 he'll know exactly what to send you he's a site sponsor and a great person , it's a cheap enough fix.
Old 02-03-2013, 04:23 PM   #8
1969to2010
The Man in Black
1969to2010's Avatar
Damn sorry outside trailing arm bushings
Old 02-03-2013, 04:46 PM   #9
UF4LIFE102SS
Drives: 2010 2 SS
I got BMR also. If i have a problem first place to start. Thanks
Old 02-04-2013, 03:12 PM   #10
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
We went with pfadt bushings which we found to be stiffer and larger plus the sleeve inside was larger as well.
I'm glad we could help you out! We've been fighting the same issue with 1 of our drag Camaros and it happens to have the BMR trailing arms with the outer bushings part # BK006. We noticed the trailing arm would move at the spindle and once we replaced those bushings the issue was fixed much like your issue.
Please feel free to call, email or PM me anytime with questions. I appreciate your business and support! Have a great day and I'll talk to you soon.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 02-04-2013, 04:12 PM   #11
1969to2010
The Man in Black
1969to2010's Avatar
Thnx Jordan such a relief
Old 02-04-2013, 04:26 PM   #12
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Glad you got to the bottom of your issue. Jordan is a great source of Camaro knowledge, good idea to lean on him as often as possible!
Old 02-04-2013, 05:22 PM   #13
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Hope that doesn't happen to me. I just got through putting trailing arms and bushings in mine.
MODS:
Old 02-04-2013, 06:29 PM   #14
JDP Motorsports
No problem! I'm glad we could help get to the bottom of your issue! Thanks for your support and have a great evening!
Kind regards,
Jordan Priestley
888.308.6007
