Cold Air Inductions
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 02-02-2013, 09:00 PM   #1
HIGGS85Z28
Drives: 1985 chevy camaro z28
overheating
k my 85z28 is over heating but the themostat is new any suggestions will help out greatly
Posted from Camaro5.com App for Android
HIGGS85Z28 is offline   Reply With Quote
Old 02-06-2013, 01:38 PM   #2
Ladon02
Drives: Saving for a 2SS 1LE RS
Had this problem with my 83 Z-28. Found that the waterpump was going bad and not pushing the needed volume of water to keep it cool. Took me a while to figure it out since it was not leaking. Hope this helps.
Ladon02 is offline   Reply With Quote
Old 02-06-2013, 05:31 PM   #3
lpar1969
lpar1969's Avatar
Drives: 2014 1SS NPP 1LE
overheating
Check that the fans are turning on.. in addition to water pump could be fan relay
lpar1969 is offline   Reply With Quote
Old 02-06-2013, 05:55 PM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
Also make sure there's no air trapped in the system (especially if you just replaced the t-stat).
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 02-09-2013, 06:15 PM   #5
one92rs
one92rs's Avatar
Drives: 1992 chevy camaro rs
if you just replaced the thermostat there could be air as mentioned above. loosen a sensor on the intake until coolant seeps out. this is the best way to get the air out of the system if there is any.
one92rs is offline   Reply With Quote
Old 03-27-2013, 08:10 AM   #6
Cadaver Puncher
Resident asshole
Cadaver Puncher's Avatar
Drives: 92 Camaro rs ( not stock) lol
• burp the system ( get the air out.)
• check that air dam is is place ( small black plastic piece that always scrapes going into driveways.)
• make sure leaves and/or debris isn't stuck between radiator and air conditioning radiator thing ( forgot the name)
• check fan operation.
• replace water pump if it's questionable.
That should get you heading in the right direction.
Legalize the right to knock the sh!t out of anyone that thinks day-glow paint and underbody neon adds HP or makes a car faster.
Cadaver Puncher is offline   Reply With Quote
Old 03-28-2013, 10:38 AM   #7
WMCC Gary
Camaro Addict
WMCC Gary's Avatar
Drives: 1987 IROC-Z
I think You covered it all. I was going to post those same Items. from what I have seen the air dam missing and debris between the radiator and condenser are the most common problems with a 3rd gen overheating
Western Michigan Camaro Club ~ President
1987 Camaro IROC-Z Pearl White & Black w/ Red Pearl, 355 TPI, A4, 3:42, AirRide,"GOMARO"
2004 Tahoe Z71 Sport Red Metallic, 5.3, Auto, 3:73, "SASYZ71"
WMCC Website www.wmcamaro.org
Michigan FBody Association www.mifbody.com
WMCC Gary is offline   Reply With Quote
Old 03-28-2013, 09:39 PM   #8
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
On my iroc, the main fan wasn't coming on. Only the secondary.
b4z is offline   Reply With Quote
Old 03-29-2013, 07:51 AM   #9
Cadaver Puncher
Resident asshole
Great minds think alike bro.
