HeadlightArmor
Old 02-04-2013, 11:27 AM   #15
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Originally Posted by 2011Camaro View Post
Be nice if someone did a exchange program, pumpkin for pumpkin. Most people with a little know how or a friend with know how could do a pumpkin swap and avoid the whole rebuild process.
We also perform full pumpkin exchanges too OR we can build yours if you want to keep your actual core.
You can PM me for more information.
Matt @ FSP is offline   Reply With Quote
Old 02-04-2013, 02:18 PM   #16
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Originally Posted by sycraft View Post
Lashway has an exchange program too.
For a second I thought I saw Backlash-away.
Old 02-07-2013, 12:52 PM   #17
jwendorf47
Drives: 2012 5.0 MT-82
From another 3.91 thread I posted in:
I installed these on my m6 LLT about 2,000 miles ago. The improvement is huge to say the least - the car feels 200 lbs lighter. My mileage actually increased in city driving (can use higher gears at city cruising speeds) by about 2-3 mpg but my highway mileage decreased by a similar amount. I used to get 22 combined with Vararam, Trifecta, LTs, and full exhaust but now I get about 20.5. I drive about 70% highway 30% city.
Drone decreased with the higher revs (I'm running a Flowmaster AMT) but YMMV.
I would definitely recommend this mod to anyone who's on the fence with it. Don't let the MPG "change" deter you - I assure you the gains are the most noticeable of any mods I've performed on my car thus far. First gear is an absolute animal now (this may be something v8 owners will not like - or you will, depending on your definition of fun haha). 6th gear is now perfectly acceptable for highway cruising/passing.
This is definitely how the car should have come from the factory.
The change for me is roughly 20% - similar to the L99.
On a side note, I can spin the rears at any point in 1st and 2nd now. Keep in mind I'm moderately modded, though.
jwendorf47 is offline   Reply With Quote
Old 02-07-2013, 01:03 PM   #18
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
Originally Posted by SBMARO'11 View Post
yes i have a manual...i would need the ring n pinion too huh
that's what a ring n pinion is. If you change the gear ratio, you ARE installing ring n pinion gears.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 02-17-2014, 01:39 PM   #19
Blu Ray
NO BOOST
Blu Ray's Avatar
Drives: 2015 Black 1SS/RS/1LE*NPP*RECAROS
Send a message via AIM to Blu Ray Send a message via Yahoo to Blu Ray
Originally Posted by h2oplay View Post
I have 3.73's, my opinion is 3.91 might be too much, if you're looking for a stump puller, might be OK.
+1 on the 3.73's.
Why you guys feel it might be to much??? When is more power ever to much
FOUNDER - NY/NJ/PA Domestic Car Club Est.2013
Custom Grind Comp Cam 110 Lobe * Brian Tooley Push Rods, Springs * Kooks 1 7/8 LT Headers * Comp Cam Trunion Bearings * NGK TR55 Spark Plugs * Rotofab CAI * Dyno Tune * CNC Ported Heads * LS7 Lifters & Tray * GM Performance Dual Mode Exhaust * GForce 1000 HP Axels* BMR 1" Lowering Springs, Trailing Arms, Toe Rods, Upper Control Arms* Full Rear Bushing Kit * 504/462
Blu Ray is offline   Reply With Quote
Old 02-17-2014, 03:46 PM   #20
banter
banter's Avatar
Drives: 2016 Camaro 2SS M6 Black
I have to disagree with everyone who says to do 3.73s instead. I had 4.10s in my '99 V6 camaro and (aside from the cam that I put in later), it was the best mod by far. It had way shorter gearing than the current V6 camaros do now too, so I scoff at those saying 3.91s would be too much for the current models.
banter is offline   Reply With Quote
Old 02-17-2014, 04:09 PM   #21
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
Well the old V6s had either a 5 speed manual or a 4 speed automatic, right? That would mean that your first gear was either a 2.48(auto) or a 3.75(manual) at best. The current Camaros have either a 4.03?(auto) or a 4.48(manual) first gear. You need a lot less rear end gear to have the same multiplication. Kinda apples to oranges. So it can be argued that 3.91 and 4.10 would be a bit too much for the current Camaro...
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Caliper Conversion, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, VIS Terminator Hood, Overkill Tuned
DSX_Camaro is offline   Reply With Quote
Old 02-17-2014, 04:16 PM   #22
banter
banter's Avatar
I was more referring to the final gear for gas mileage concerns. I damn near always second gear started my '99 even before the 4.10s (3.23s stock). What gear end gear does the new v6 have stock?
Old 02-17-2014, 04:27 PM   #23
DSX_Camaro
DSX_Camaro's Avatar
All V6's have 3.23 gears stock, except the 2LS which has 2.92s.
Old 02-17-2014, 10:34 PM   #24
hawkfe
hawkfe's Avatar
Drives: 2014 Stingray 3LT
I did the pumpkin swap almost a year ago, love it.
hawkfe is offline   Reply With Quote
Old 02-17-2014, 11:42 PM   #25
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
On the other hand the 3.91 gears are half the price of the 3.73 gears and if my math is right it is only a 5% lower gear. There is a C5 member that has had both 3.73 and 3.91 gears on his V6/A6 Camaro and he was much happier with the 3.91 gears.
Mark114 is offline   Reply With Quote
Old 02-18-2014, 06:16 AM   #26
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Do you remember who, or a link to a thread. I am interested in doing this swap, but am told same thing, our power band is not suited for the 3.91. Still doing more research on this one. If I am to do this it will be next winter.
Old 02-20-2014, 08:24 PM   #27
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
IneedaZ has had 3.73 and is now running the 3.91 setup.
etmx183 is offline   Reply With Quote
