Solo Performance
Old 02-04-2013, 09:34 AM   #1
Rob3D
Drives: Car
How do YOU shift? (manually)
Do you skip gears? Go thru all the gears no matter what? Sometimes, when entering a highway via on ramp, I'm up to higway speed by 2nd or 3rd gear and just go straight to 6th. Even in town I can skip gears (even when I'm not ordered to by the computer)
What are your shift habits and opinions on what's harmless or harmful?
Rob3D is offline   Reply With Quote
Old 02-04-2013, 09:38 AM   #2
06_warrior
06_warrior's Avatar
Drives: 2012 1SS LS3 M6 black on black :)
I usually go thru all the gears except when it's cold and hard to go from 1st to 2nd i'll go into 3rd until it warms up. I'm not much for skipping gears.
06_warrior is offline   Reply With Quote
Old 02-04-2013, 09:41 AM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
I do this too - though with the weather we've been having recently my 2nd gear probably thinks I put him in time-out or something
Click to view my build thread
Old 02-04-2013, 09:44 AM   #4
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
I'll skip when getting on the freeway ir the need arises.
Spirited i will use all of them, sometimes skipping first with nannies off.
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 02-04-2013, 09:45 AM   #5
jd10013
Drives: 2012 camaro
depends. If I have to speed up in a hurry, like getting on the freeway or having to cut into traffic from a side road I'll usually wined out 3rd and then drop down into 6th at about 70mph. other than that I'll usually go through all of them except maybe 5h.
jd10013 is offline   Reply With Quote
Old 02-04-2013, 09:47 AM   #6
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
If I wanted to skip gears I would have an automatic, I never skip gears.
Old 02-04-2013, 09:51 AM   #7
Rod Knock
Rod Knock's Avatar
Drives: 2003 Dodge Viper/2011 IOM SS vert
Very, very seldom skip gears when picking up speed but skip gears when decelerating. I like to use second gear a lot when slowing down and will grap it from fifth or fouth a lot.
Rod Knock is offline   Reply With Quote
Old 02-04-2013, 10:26 AM   #8
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I just put it in sport mode, and let the car figure it out.
Old 02-04-2013, 10:31 AM   #9
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
that makes no sense whatsoever.
as the power of the manual is what ALLOWS you the power to skip gears..
the auto is the opposite you cannot skip gears.
yes I will skip especially from 3rd to 5th or 6th when on the highway.
and will damn sure skip going down.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 02-04-2013, 10:45 AM   #10
ATX211
Custom User Title
ATX211's Avatar
Drives: 2012 Camaro 2SS/RS LS3
I don't typically skip, but mainly because I just kind of enjoy going through the motions. Skip on the way down, and usually do not go below third when downshifting. Again...No particular rhyme or reason.
ATX211 is offline   Reply With Quote
Old 02-04-2013, 11:13 AM   #11
mntgome1
mntgome1's Avatar
Drives: 2012 AGM 2SS/RS
I only start skipping gears when my D.I.C says 10 mpg or lower
mntgome1 is offline   Reply With Quote
Old 02-04-2013, 11:21 AM   #12
chaoscamaro
chaoscamaro's Avatar
Drives: 2011 camaro ss2 I.O. M6
I never skip gears upshifting, I don't see the point. I do skip while down shifting if I need to, or when coasting in neutral to whatever gear it should be at the speed without it engine braking.
Posted from Camaro5.com App for Android
chaoscamaro is offline   Reply With Quote
Old 02-04-2013, 11:44 AM   #13
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
I skip frequently. Doesn't harm anything.
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 02-04-2013, 11:48 AM   #14
Heaven_is_inferno_orange
GM Technician
Heaven_is_inferno_orange's Avatar
Drives: 16' 2SS, 12 ZL1, RIP Sasuke
Send a message via MSN to Heaven_is_inferno_orange Send a message via Yahoo to Heaven_is_inferno_orange
I don't hardly ever skip. I like the feeling of going through the gears. I even got rid of that annoying skip shift. Either way doesn't hurt anything. The biggest deal is how you clutch it. Burnt clutches and broken teeth on sychronizers are not fun to replace. However I would rather tear open a manual tranny than an auto anyday.
Heaven_is_inferno_orange is offline   Reply With Quote
