Old 02-05-2013, 02:39 PM   #1
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
tune competition mode
is it possible to tune competition mode? if so, how do you "activate" it so that HPTuners sees it?
do you have to be in comp mode prior to connecting?
and what about when re-flashing?
thanks
hapisok is offline   Reply With Quote
Old 02-05-2013, 02:57 PM   #2
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Not sure if anyone has asked this or gotten a reply. Isn't some or at least a good portion in the BCM?
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 02-05-2013, 02:58 PM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Never seen this done with HPT, Trifecta has this for LNF turbo Cobalts & GXP/Skys.
Maybe Vince can do it for the Camaros. vince@trifectaperformance.com
It was a switchable tune for the LNF, set up on cruise control button or comp mode.
Yes, it needs to comm with the BCM.
Iam Broke is offline   Reply With Quote
Old 02-05-2013, 03:11 PM   #4
hapisok
hapisok's Avatar
hmm...interesting.
if its a comms issue with the BCM...then shouldn't it be programmable via OBDII? is that just a feature/capability that HPT doesn't offer?
thanks for the responses
Old 02-05-2013, 03:41 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Yes. HPT only deals with the ECM afaik.
Vince is an ex Microsoft guru that delved off into his own world of zeros & ones. He rewrites the OS at the bit level to accomplish his needs. I've talked to him a lot developing E85 tunes for the LNF, very smart & nice guy.
Old 02-05-2013, 09:27 PM   #6
BNRacing
Drives: 2010 Cobalt SS, 1972 Nova
What would you want to do to competition mode? Make more power in competition mode vs regular?
BNRacing is offline   Reply With Quote
Old 02-05-2013, 11:13 PM   #7
hapisok
hapisok's Avatar
have the ability to fine tune the launch control. either through torque management, spark control, a combination of, or whatever other parameters are able to be manipulated to achieve minimal (or 0) wheel spin and maximum power output. not just during launch, but also when shifting between 1st & 2nd and 2nd to 3rd.
but still having the option to remove traction control and spin the tires at will.
hope that makes sense.
Old 02-06-2013, 05:56 AM   #8
Iam Broke
PHAT B33
Iam Broke's Avatar
You can change the launch control in HPTuners. I have mine at 3k rpm currently.
Also set it up with the 'Vette No Lift Shift settings at 6200 rpm.
No adjustments on the fly though.
On the Trifecta LNF's he had you set launch control when you loaded the tune as I recall. Biggest advantage to Vince's dual tune was to change the turbo boost & timing tables. NA I really don't see much need for a dual tune myself.
Old 02-06-2013, 07:23 AM   #9
hapisok
hapisok's Avatar
not so much a dual tune...just the ability to adjust the parameters already set in there as OEM.
Old 06-25-2014, 10:23 PM   #10
Sparkyz13Bee
Sparkyz13Bee's Avatar
Drives: 2013 Camaro 1LT
Ok I have a question. Is it possible to "tune in" competition mode and no lift shift on the LFX engines??
Sent from my Sparkyz iPhone using Tapatalk
Sparkyz13Bee is offline   Reply With Quote
Old 06-26-2014, 10:03 AM   #11
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Sure looks like it.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
