BORLA
Old 02-05-2013, 08:59 PM   #1
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Was Raptor, Now MSD Shift light installed
Finished this up tonight.
Followed the DIY Thread.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 02-05-2013, 09:04 PM   #2
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
Cool. I have the same craftsman cabinet in my garage!
kevin1106 is offline   Reply With Quote
Old 02-05-2013, 09:47 PM   #3
Ciscokid
Drives: 2013 ZL1 Vert - BRM&2014 NRB Vette
From the picture, it looks like you have a bright flashlight in your face.
What exactly is the purpose of the Raptor shift light w/accessories?
Ciscokid is offline   Reply With Quote
Old 02-05-2013, 10:36 PM   #4
SamHouseIII
I Carry!
The HUD one does not allow for any other sighting position than straight forward, with the light I can see it in my peripheral sight no problem. This aids in shifting while looking to the sides for on coming traffic and other Apps.
Old 02-05-2013, 10:37 PM   #5
SamHouseIII
I Carry!
My Ammo Locker!!
Old 02-14-2013, 09:16 PM   #6
SamHouseIII
I Carry!
Thought I had this done, but my light would go out then come back on. Contacted Raptor and they updated the connections.
So do I try and re-install this or install the NEW one I just bought? MSD Shift light????
The MSD seems easy to install, the Raptor has the blue LEDs which I like so much better??
Old 02-14-2013, 10:49 PM   #7
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28, Challenger
What was the DYI thread?
Skylane765 is offline   Reply With Quote
Old 02-16-2013, 06:58 PM   #8
SamHouseIII
I Carry!
anyone installing a shift light, this is so easy!!!
here a few pic to help you out!
Old 02-16-2013, 07:00 PM   #9
SamHouseIII
I Carry!
Remove your strut tower brace and cover.
Old 02-16-2013, 07:08 PM   #10
SamHouseIII
I Carry!
Now for some prep work,
Locate you #1 Coil (drivers side one all they to front of engine) remove plug from coil, carefully peel back tape.
The MSD pick up goes on the large outer pink wire (test by using a test light, key off light off, key on, light on) DO NOT TURN KEY ALL THE WAY ON, JUST TO WHERE GAUGES LIGHT UP ON DASH, DO NOT START CAR.
Old 02-16-2013, 07:15 PM   #11
Scarrzz
No Fear-No Limits- Camaro
Scarrzz's Avatar
Drives: '13 ZL1 or Suzuki Hayabusa
You'll Git 'er done, and done right. I'm looking forward to your results.
__________________________________
................................................The Faithful are Watching.
Scarrzz is offline   Reply With Quote
Old 02-16-2013, 07:20 PM   #12
SamHouseIII
I Carry!
Place mount where you want it. I chose here.
Remove fuse panel, center door strip cover, and lower kick panel
Old 02-16-2013, 07:30 PM   #13
SamHouseIII
I Carry!
Remove plastic nut and fold back carpet towards the center console.
This is where I drill a hole to run wiring for an earlier project/under hood where it comes out.
Run your wire (PICK UP end) into the car.
Old 02-16-2013, 07:34 PM   #14
SamHouseIII
I Carry!
Loosely run the pick up wire and the inserted this into a wire loom.
Connected the pick up per the install instructions.
Plugged back in the coil wire.
