JUICEDMOTORSPORTS
Old 04-15-2013, 01:34 PM   #15
Michael Rophone
Michael Rophone's Avatar
Drives: Yes
I was annoyed at the random, but constant, tapping noise at idle coming from the rear.
The first time I heard it was sitting idling in my driveway.
I thought someone was having roof-work done next door...but it was Midnight.
I don't know what the second owner ever did.
Michael Rophone is offline   Reply With Quote
Old 04-17-2013, 12:22 PM   #16
layzurguy
Ride On!!!!
layzurguy's Avatar
Drives: 2012 SS Ragtop
get some headers and exhaust....problem solved
layzurguy is offline   Reply With Quote
Old 04-17-2013, 10:40 PM   #17
steveintulsa
steveintulsa's Avatar
Drives: 2010 rs/ss
I just spot-welded mine open (after muffler delete), Much better full range sound at idle.
steveintulsa is offline   Reply With Quote
Old 04-17-2013, 10:55 PM   #18
layzurguy
Ride On!!!!
layzurguy's Avatar
Right on!
Old 05-30-2013, 11:28 AM   #19
ZL1DropTop
Drives: 2013 Camaro ZL1 Convertible
I believe I have experienced this problem. I brought mine to the dealer and they told me there was a programming update that they did. Service guy said that it may or may not resolve the problem entirely, and that if it didn't, there was no fix for it. It seems to have fixed the problem as of right now, but not sure if it's a permanent fix. Glad to have found this information though.
ZL1DropTop is offline   Reply With Quote
Old 05-30-2013, 11:57 AM   #20
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
This is for the L99 only. My LS3 vert does not have these.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 06-11-2013, 09:42 PM   #21
Pkrimmer
Pkrimmer's Avatar
Drives: 2011 Black 2SS Convertible
I have new borla ateck all the way back. New borla headers and tune. What a differance in sound. They know your coming but very quite on the expressway.
Pkrimmer is offline   Reply With Quote
Old 06-12-2013, 03:24 AM   #22
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Would the Range AFM disable unit help keep the butterfly valves open all the time? If not, what is the best way to keep them open without putting in a new exhaust system? Any disadvantages to getting rid of the valves or having them permanetly open? Thanks in advance.
SS PANTHER is offline   Reply With Quote
Old 06-12-2013, 01:56 PM   #23
sswiss3000
sswiss3000's Avatar
Drives: 2012 Camaro 2SS Vert, L99
No, the exhaust baffles are not computer controlled or anything. Those butterfly valves are only opened when there is enough exhaust pressure (ie. RPMs).
On the other hand, you can either cut them out or simply wire them open if you have the Range AFM disabler installed, as they are designed to reduce the coffee grinder noise you get when the L99 engine goes into 4 cylinder mode.
sswiss3000 is offline   Reply With Quote
Old 06-12-2013, 01:59 PM   #24
SS PANTHER
SS PANTHER's Avatar
Thanks for the info.
Old 06-12-2013, 05:20 PM   #25
cam62
Drives: 2012 IBM Vert 2SS/rs
Explain "wire them open". I was going to find some to weld them open. If I can "wire them open" myself I would rather go that route first.
rx catch can;vmax ported throttle body;bowtie delete;SLP SS emblem;CAI cold air intake
cam62 is offline   Reply With Quote
Old 06-12-2013, 05:40 PM   #26
whidobie
whidobie's Avatar
Drives: 2011 Camaro Convertible 2SS RS
Everything is normal just like the convertible tops.
whidobie is offline   Reply With Quote
Old 06-12-2013, 10:05 PM   #27
sswiss3000
sswiss3000's Avatar
Cam62,
As I just wanted to see what it would sound with the baffles open, I simply took a long wire and wrapped one end around one of the metal tabs on the out side of the Springs. Then I manually twisted the valve open and strapped the other end of the wire to the exhaust hook at the very back end of the car. This way the wire holds the valve at the open position
Admittingly, this method could be considered a "bit" low tech , but it works and can be easily reversed at any time.
Old 06-13-2013, 09:21 AM   #28
pannhead51
pannhead51's Avatar
Drives: 2SS convertible
Cam62,
So was the sound louder/better ?
pannhead51 is offline   Reply With Quote
