Anthony @ LG Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > 2016 Camaro: 6th Gen Camaro forum, news, rumors, discussions
Old 04-23-2013, 08:50 PM   #651
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '13 ATS 2.0T & '14 Chevrolet SS
Originally Posted by fielderLS3 View Post
I find it hard to believe you got a nearly 50% torque gain over stock with just minor bolt-ons and advanced timing. You must have upped the boost several psi as part of the tune.
I don't think a turbo-4 will get any better fuel economy than a NA V6 at all, not as long as you compare engines of similar power. You can't compare power vs efficiency between the ATS V6 and turbo-4. The V6 makes 50 more horsepower.
Shrink the V6 in displacement until it was down to 270hp, or grow/tune the turbo-4 up to 320hp, and I think their efficiencies would be identical. Only differences would be the cost, complexity, and long term expensive repair potential.
GM had a 3.0 L V6 that made the HP of the 2.0T in the Equinox/Terrain/CTS. None got significantly better FE than the 3.6 which is why it's gone.
But generally a smaller displacement turbo making equal HP will get better FE. Just look at the 1.4T in the Cruze or Sonic vs the base 1.8L NA. The Turbo is the FE choice. Both the 1.8 and 1.4T make the same HP.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 04-23-2013, 10:01 PM   #652
fielderLS3
fielderLS3's Avatar
Drives: 02 Alero, 2011 Mustang 5.0
Maybe on the EPA test, but not in the real world. Most real world results/tests suggest that downsized and turbo engines fall short of their EPA targets (much the way hybrids do). CR does real world fuel economy loops, and they did a 1.4T Cruze and 1.8 Cruze. Their real world result between the two engines was identical.
Ultimately, I believe that the EPA methodology (i.e. the assumptions/simulations build into their dyno runs) underestimates the efficiency of larger displacement engines, and overestimates smaller ones. This is just an observation from experience. I've driven a lot of different cars over the years. The V8 powered cars I've driven surpassed their EPA ratings much easier and by larger margins (one of them is EPA rated at 23, and consistently gets 30, a 30% difference to the plus side) than the 4-cyl cars I've driven.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 04-28-2013, 03:34 AM   #653
2012-1822
2012-1822's Avatar
Drives: Black ZL1
This is my Jeff Goldblum impersonation from Independence Day. "Wellllll..."a four cylinder is good for business. If it helps them with CAFE, export, whatever. Get the production numbers up. Yes, throw a turbo or two on it if you want. Let me say this, 4 cyl Camaros might help insure there would still be 8cyl Camaros. I mean the only way to phrase it is why would anyone want a 6cyl? Well they do, and they enjoy them, and they still have more hp than the 4th gen Z28's. So I have no issue with a full spread of engine options.
I'll preface my next part with yes some people would drag race a 4cyl Camaro, but where as they may not be great for drag racing, the next lighter generation with an even lighter 4cyl turbo engine might make for a good track or autocross car.
Whatever Chevy has to do to make sure the Camaro doesn't go away again is fine by me. I'm more concerned with styling and weight. No matter what, at least for the time being, whatever is offered beside the V8's there will still be V8's, and there will also be after market parts to give that engine 600 hp if that's what someone wants, which I do.
2012-1822 is offline   Reply With Quote
Old 04-30-2013, 11:03 PM   #654
Nessal
Drives: Lotus Exige
I associate American muscle as having minimum 8 cylinders and above. If I wanted a 4 banger, I would get a Evo or STI.
Nessal is offline   Reply With Quote
Old 05-01-2013, 02:36 PM   #655
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
This! I recall an article of one of the camaro engineers stating soemthing to the effect "over his dead body" that a camaro would have a 4 cyl. We'll see what happens here, but I think they'll stop camaro production before introducing a 4 cyl in them.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 05-01-2013, 03:00 PM   #656
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 06 Chevy Colorado
I wouldn't count on that.
It is basically all but confirmed the Mustang is getting one.
Custom Magnaflow Exhaust, Vararam intake, MACE Ported Manifold, RX Ported TB, "Black Ice" manifold insulator, Elite Catch Can, ZL1 repro wheels, ZL1 Springs, DRL Harness, Front GM GFX, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers and much more!
Old 05-01-2013, 03:07 PM   #657
90503
Drives: 2011 2SS/RS LS3
...Probably true if the case were that there would be no V-8...My guess is he meant no Camaros would have a 4-cyl as the only available engine...
90503 is offline   Reply With Quote
Old 05-01-2013, 03:35 PM   #658
Wizard1183
Wizard1183's Avatar
Maybe so... its quite possible they introduce it, but the camaro has til about 2020 and itll be put to death again. No redesign of 6th gen and def no 7th gen camaro. But then again? Will GM ride this pony til it dies? "it's better to burn out than to fade away" is what I see happening. GM rode it til its death in 2002. I dont see them wanting to do that again. I wish theyd have stopped with the 5th gen, then bring back the Chevelle SS.
Old 05-01-2013, 04:30 PM   #659
90503
I'd say they will go with the Camaro line for as long as they possibly can...at least for the 6thgen with the platform change....It's probably easier to morph an existing model line like this one than stop it altogether and introduce another different named car...
To me it's the only regular "Chevy"...(Can't count the Vette...lol) that has any affordable, sporty, sex-appeal...
I think they'll come out with as many variations of it as possible for as long as possible and see what sticks in the future....
Old 05-01-2013, 09:51 PM   #660
KMPrenger
KMPrenger's Avatar
What do you mean "No redesign of the 6th gen"?
Old 05-01-2013, 10:08 PM   #661
camaro-dreamer
camaro-dreamer's Avatar
Drives: 2008 Maxima/ 2011 Mustang GT
I wonder if you offended any former or current grand national owners .
camaro-dreamer is offline   Reply With Quote
Old 05-01-2013, 10:19 PM   #662
simon.w
simon.w's Avatar
Drives: 2011 2SS RS 6M Inferno Orange
I personally don't understand why anyone would want a 6 cyl camaro.
Actually ... I'll go one step further ... I don't understand why anyone would want a stock V8 camaro either!
Kidding!
Actually I remember seeing a beautiful 68 or 69 camaro on a website once that someone had done up ... and from memory it had a skyline engine in it. I know it's not a 4cyl ... but it challenged my thinking at the time.
Then there is this amazing piece of engineering: http://www.dieselpowermag.com/features/chevy/1102dp_1969_cummins_powered_chevy_camaro/
Next thing their will be a hybrid or ... dare I say it ... an electric.
Oh well ... it's all good ... more gas for me to burn!
732rwhp 644 rwtq 2011 Inferno Orange 2SS, STRUT 22" Icon5 Rims & Grille Kit, Mahle Pistons, Manley H-Beam Rods, Competition Valve Grind, Custom CMS Grind Comp Cam, Comp Cams Valve Springs, ARP Bolts, Melling HV Oil Pump, Whipple SC, 3.5" Pulley, 8 Rib Pulley Kit, Innovators West 10% Overdrive Balancer, 1" 7/8 Stainless LT Headers & 3" Exhaust, ADM Twin Fuel Pump Kit, 80lb/hr FIC Billet Tip Injectors, RX Monster Catch Can, Cold Air Inductions Intake, ADM Race Scoop, Mantic 9000 Series Clutch, Hurst Shifter, Eibach Springs. Motor built by PFAFF Engines. Fitted & tuned by Cunningham Motorsports.
simon.w is offline   Reply With Quote
Old 05-02-2013, 08:32 AM   #663
Wizard1183
Wizard1183's Avatar
I mean that they'll introduce a 6th gen camaro for a few yrs then discontinue it without redesign like they have done with the 2014 camaros to the 5th gen.
Theyre not going to capitalize on the camaro like they did in the past and run it into the ground. I see them discontinuing it all together before that happens again. It was a perfect time to bring them back, but how can you justify making a "muscle car" or pony car that will eventually lose its muscle again? You cant! Makes absolutely no sense to make a hybrid or electric or 4cyl camaro. That was never its intention. Its a high performance vehicle and high performance is on its way out again unless you will have the money to pay for it. I.e. Corvette, Porche, Audi.....
The LT1 will be installed as the primary engine of the 6th gen camaro V8. 450HP will be the maximum amount of HP the Camaro is likely to see and itll drop from there.
Old 05-02-2013, 08:52 AM   #664
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: `12 LFX/`11 EB F-150/`13 Sonic RS
Not sure I'm following your logic. For every Camaro sold GM sales 10+ Cruze. They don't have to hit FE targets for every model they sale, just a corp. average. Sales of things like the Cruze, Sonic and Spark will support the demand for Camaros and Corvettes for some time to come. Technology keeps improving so I won't be suprised to see 35+ MPG V8 Camaros in the future that produce as much or more power than the current 5th Gen. If they sale 2 T-4 Camaros for each V8, and those are getting close to 40 MPG 10 years from now, then GM won't have a problem keeping the model alive.
EFR Twin Turbo LFX-GPI Tune-ZL1 fuel pump-10:1 CR forged pistons-3.45 gear-Meth Injection-BMR Trailing Arms, Bushings & Sway Bars-CircleD 4000 Stall-GPI Fuel Enrichment System
647 RWHP & 726 RWTQ @18.5 psi on 93 Octane (locked converter)
1/8 mile -- 7.158 @ 102.10 (20psi); old build
Build Thread
GretchenGotGrowl is online now   Reply With Quote
Old 05-02-2013, 09:18 AM   #665
Wizard1183
Wizard1183's Avatar
Sorry, but if 450HP is the maximum HP on a 6th gen. You honestly think a 7th gen will start off with 500? Maybe.... just maybe, IF and a HUGE IF, they produce a 7th gen, it would NOT be NA. It would HAVE to be turbo/supercharged to get there. Id want the HP to be NA. Then if I choose, I can add boost. I just cant see the numbers getting higher when it will basically just be unrealistic for the average guy to go outand buy a high perfomance vehicle. Thats what its coming down to. The amount of SS Camaros on the road now? You wont see that in 10 yrs from now. High perfomance will be less and less. Inflation is making the prices of vehicles even more.You see the avg.salary keeping up with it? No it doesnt which is why youll see less and less of thoseon the road. A V8 camaro in 7 yrs regardless of whether or not it has a 6.2L or a 5.3L will cost MORE than it did today. Add a supercharger or turbo and the cost will go up. So then youll be paying $40k for a V8 camaro as the base price. Eventually itll be out of reach for the norm.
I just dont see the Camaro lasting very much longer. I could be wrong, but I dont want a "high performance" car thats 400HP unless you opt for the turbo or the S/C. Thats going back to how things used to be.
Old 05-02-2013, 09:32 AM   #666
GretchenGotGrowl
I just dont see the Camaro lasting very much longer. I could be wrong, but I dont want a "high performance" car thats 300HP unless you opt for the turbo or the S/C. Thats going back to how things used to be.
But if you go back and look at the price of the 1st Gen Camaros and correct for inflation, the 5th Gens with the same performance are just marginally more expensive. Yet, you get lot's of extras (i.e., air bags, a/c, sat. radio, etc...) for that extra money. Yes, we go through periods where costs go up faster than inflation, then times were they are less than inflation. It all comes out in the wash eventually.
As for the 500 HP, if GM actually develops a 10 speed transmission and reduces weight by 15%, then you may not need 500 HP to get the same performance out the same HP as the LT1 10-12 years from now.
If you don't like FI, then yes you will have a problem because all the car manufacturers are going that route. You can always go the crate engine route or just keep what you have. However, most people don't seem to be shying away from the smaller displacement, FI alternatives that are being offered now. Why would they shy away 10-12 years from now when the technology is more ubiquitous and reliable?
Build Thread
Old 05-02-2013, 09:41 AM   #667
Wizard1183
Wizard1183's Avatar
Good points and I agree with you. But I wont be amazed at the technology engineered in 10 yrs time. Eventually with smaller displacement and same or more power, what youre referring to, equates to a ricer in american form. Not my thing. I guess everyone then they'll will have large fart pipes on their camaros.
On a serious note, the "muscle" and roar will be lost. Which is what some of us enjoy.
Old 05-02-2013, 09:54 AM   #668
GretchenGotGrowl
I don't know about the sound thing. I love how the Coyote engines sound and they are just 5L. I think a 4.6 L V8 with a supercharger would probably sound bada$$, too. Even with turbos it would probably sound good. I really don't see V8s going away in the N. American market anytime soon. There will just be other options to choose from.
Build Thread
Old 05-07-2013, 06:43 AM   #669
revychevy
revychevy's Avatar
Drives: 2010 2SS RS LS3
[QUOTE=Wizard1183;6495569]Sorry, but if 450HP is the maximum HP on a 6th gen. You honestly think a 7th gen will start off with 500? Maybe.... just maybe, IF and a HUGE IF, they produce a 7th gen, it would NOT be NA. It would HAVE to be turbo/supercharged to get there. Id want the HP to be NA. Then if I choose, I can add boost. I just cant see the numbers getting higher when it will basically just be unrealistic for the average guy to go outand buy a high perfomance vehicle. Thats what its coming down to. The amount of SS Camaros on the road now? You wont see that in 10 yrs from now. High perfomance will be less and less. Inflation is making the prices of vehicles even more.You see the avg.salary keeping up with it? No it doesnt which is why youll see less and less of thoseon the road. A V8 camaro in 7 yrs regardless of whether or not it has a 6.2L or a 5.3L will cost MORE than it did today. Add a supercharger or turbo and the cost will go up. So then youll be paying $40k for a V8 camaro as the base price. Eventually itll be out of reach for the norm.
I just dont see the Camaro lasting very much longer. I could be wrong, but I dont want a "high performance" car thats 300HP unless you opt for the turbo or the S/C. Thats going back to how things used to be.[/QUOTE
? What do you mean? The Z/28 is 500 HP right now. The SS has been 426 HP since 2010. You don't want a high performance car thats 300 HP unless it has a turbo or SC??! Go buy a 2009 mustang GT. We'll drive the NA 400+HP Camaros!
2SS RS bone stock for now...
revychevy is offline   Reply With Quote
Old 05-07-2013, 09:40 AM   #670
Wizard1183
Wizard1183's Avatar
[/QUOTE]? What do you mean? The Z/28 is 500 HP right now. The SS has been 426 HP since 2010. You don't want a high performance car thats 300 HP unless it has a turbo or SC??! Go buy a 2009 mustang GT. We'll drive the NA 400+HP Camaros![/QUOTE]
What? Where'd you see that in my post? What Im saying is I dont see 400+HP in NA engines in 10 yrs. I think itll be HP made with boost to get the numbers where we're at today with NA engines. A smaller discplacement with boost to get the numbers means youre HP level decreases. Right? Thats what I was saying.
I am willing to bet in 10 yrs there wont be a 400+HP NA engine for any average guy to go and buy. We'll see but I'll stand by my thoughts until proven otherwise with the way things seem to be headed.
Old 05-07-2013, 11:12 PM   #671
revychevy
revychevy's Avatar
You said the part about not wanting a 300 HP NA engine in your previous post. It has been copied by me and Gretchen. You also said the Camaro was on its way out and that it would end with the 6th gen.
Do you want me to copy it and show you?
The Camaro is not going anywhere ( currently outselling Mustang and Challenger). The Next SS will have over 400 HP NA. The SS after that will also have 400+ HP -- and your 10 year doomsaying is pointless and based on nothing.
Old 05-08-2013, 07:16 AM   #672
Wizard1183
Wizard1183's Avatar
Sorry for the mistake bro. I meant 400 HP I fixed it. Well, its very possible GM does EXACTLY what they did in 1973 until 2002 which was milk the cow dry selling camaros as high perfomance when figuratively they were high performance for their time but NOWHERE near 1967-1972. And I can tell you that 400HP NA V8 engines are slowly going to go away. This is not speculation. Its naive NOT to think they wont.
Old 05-08-2013, 11:44 PM   #673
revychevy
revychevy's Avatar
I'm hoping they love these cars as much as us (I'm sure Fbodfather and the Camaro crew that just gave us a 500 HP Z/28 do). You feel that it will end relatively soon (6th gen) and I think it will continue. You may call me naive, but you are just guessing. One could say you are cynical. I will wait and see. Hopefully with a Z/28 in my driveway. Here's one for ya-- you probably never thought the Camaro would come back after 2002 did ya? With 426 HP no less.
Keep the faith.
Old 05-09-2013, 06:48 AM   #674
Wizard1183
Wizard1183's Avatar
Keep the faith.
I think AFTER the 6th gen, it'll end and may dwindle down during 3 yrs after 6th gen is in place.
But hey! I hope youre right and yes I am a little cynical. But realistically, in 2025, 400HP naturally aspirated will be unheard of. It will all come from boost. Wonder how many horses that LSA ZL-1 would have had it not had the S/C on top of it? Its not a bad thing using boost. Its getting small engines up to the performance of larger ones and unless you put your foot in them, they'll do excellent at the pump. THIS is where its going.
Gas guzzler taxes will end because they wont produce anything needing it. Many ppl WANT hundreds of HP in their cars getting 50-60mpg. They DONT CARE how its done. But mostly, some ppl dont care about HP vs mpgs. They're tired of handing money over at the pump. More and more are getting to this point. Car manufacturers produce for the masses. Sure, they offer a car for the small % to obtain but overall....
Old 05-10-2013, 03:05 PM   #675
mr02Z/28
Drives: 2002 Z/28,1968 Chevelle convert.
I know folks may think I'm crazy but I would love to see a very lite weight 6th Gen with a 2.0L turdbo pushing 320-340hp.... I like odd-ball combos which is why I had a 267ci dual carb set-up in my Chevelle for about 10 years... Most would laugh at a 267ci V-8 in a Chevelle but I thought it was cool..
mr02Z/28 is offline   Reply With Quote
2015 camaro, 2015 camaro forum, 2015 camaro forums, 2015 chevrolet camaro, 2015 chevy camaro, 2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
