JUICEDMOTORSPORTS
Old 02-07-2013, 06:01 PM   #1
Zebracakes4you
Zebracakes4you's Avatar
Drives: 2SS Black W/Cyber Gray stripes
NIGHT FURY CAM VS JRE SMOOTH IDLE CAM
I have a L99 ss 2010 Camaro. I was contemplating converting it to an LS3 however I don't know if that's the best idea. I am going to do a can for my next mod if I dont do the conversion. However I am torn between the night fury cam and the smooth idle cam. Aside from personal preference on the sound which cam is better when it comes to performance? Anyone have these? Pros cons andynos would be appreciated so I can make an informed purchase.
Zebracakes4you is offline   Reply With Quote
Old 02-07-2013, 06:10 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If you go Ls3 the Nite Fury!!
If you stay VVT the MAST VVT cam, the bigger one I think it's the SS? Cam iirc
Old 02-07-2013, 08:27 PM   #3
Zebracakes4you
I was leaning towards the night fury do you know any specs on it such as torque and HP gains? Also i know cams are engine specific so if i did this conversion would i have to get the cam after the LS3 conversion. I mean a lot of the mechanics are the same its just different pulleys and gaskets and such
Old 02-07-2013, 08:35 PM   #4
flyer08
Drives: 2010 2SS/RS
You might as well do the cam now or you'll be spending a lot more money. Gotta pull the heads to change out lifters. Check my vvt thread Matt @fsp started and its similar to what you want but I kept vvt cam
flyer08 is offline   Reply With Quote
Old 02-07-2013, 08:42 PM   #5
1sikRS
Drives: chevy
Nite fury
1sikRS is offline   Reply With Quote
Old 02-07-2013, 08:46 PM   #6
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
I've seen nothing but good come from either one. But since I have the Night Fury, I'm a little biased lol.
Frid is offline   Reply With Quote
Old 02-07-2013, 09:15 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
http://www.camaro5.com/forums/showth...ghlight=Camper
Here is a link with videos
Lethal Racing "Night Fury" Cam 230/242 113 don't know the lift specs but I'm sure it's in the .600's.
Where in Illinois are you?
I was there for some pulls and it was impressive, especially with a slipping clutch and rear wheel alignment issues lol on a stingy mustang dyno 470 cam only is very respectable in my book.
Old 02-07-2013, 09:27 PM   #8
Zyklon-SS
Zyklon-SS's Avatar
Drives: 2010 2SS LS3
Zyklon-SS is offline   Reply With Quote
Old 02-08-2013, 01:15 AM   #9
Zebracakes4you
So basically night fury and if i do the LS3 conversion i should do it at the same time as the cam. Well thanks for the input
Old 02-08-2013, 01:16 AM   #10
Zebracakes4you
I live about 30 min away from chicago and thanks a lot for the input.
Old 02-08-2013, 01:36 AM   #11
StephenS_84
Drives: 2011 2SS/RS
Yes do the conversion at the same time.
StephenS_84 is offline   Reply With Quote
Old 02-08-2013, 07:22 AM   #12
Camper
Banned
Drives: 10' 2SS LS3 M6
I actually put down more than that now, had a vacuum leak on my fast 102 and put in a new clutch. Put down 507 on a dynojet.
although my dyno shake is due to my driveshaft and not an alignment :(
Camper is offline   Reply With Quote
Old 02-08-2013, 07:30 AM   #13
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Here's my smooth idle cam. Made 450rwhp and 420tq NA
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 02-08-2013, 07:50 AM   #14
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
Night Fury with LS3 conversion !! To each his own. But I love the radical sound and the smooth power this cam makes..Here's a taste..
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
