Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Members Area > General Automotive + Other Cars Discussion
Old 02-02-2008, 07:56 PM   #1
Truth Enforcer
CamaroSpike23's Avatar
big news for 4L60e/700r4 owners
"PATC has developed a 6-pinion planet gear set for 700R4 / 4L60E transmissions. This will be the biggest thing in 700R4 advancements in years. These will have a 2.66 to 1 first gear, 1.55 to 1 second gear, 1 to 1 third gear and .64 to 1 overdrive ratio. This is a 36% overdrive making this one of the best overdrive ratios around. The 1st to 2nd RPM drop between gears would be slightly less than the RPM drop on a 200-4R transmission. This is what people have been asking for, for years. These will work on any 4L60E type transmission without a gear ratio error code, if the PCM is modified. This gear set is used to reduce torque multiplication / rotating speed in the transmission in first gear. This improves track applications that overpower the rear tires upon launch. This is common with numerically high final drive ratios. (IE 3.06). Now you will have a choice between the wide ratio or the new close ratio gear sets. It has been reported that the 2.66 gear set could lower your quarter mile time as much as 4/10 of a second over the 3.06 gear set. Plus better mileage and lower RPM with the .64 to 1 overdrive. The first 50 are in production now and the approximate release date is 2-1-2008. "
I piss excellence
and fart awesomeness
Detroit News panel wants GM to build Camaro concept Tran 5th Gen Camaro SS LS LT General Discussions 12 03-15-2009 04:38 PM
LSX owners: AFR Cylinder Head Owners FTI-EDC General Automotive + Other Cars Discussion 0 11-10-2006 05:54 PM
news!!!!! jbynum69 5th Gen Camaro SS LS LT General Discussions 8 08-29-2006 08:13 AM
