Solo Performance
Old 02-09-2013, 02:00 PM   #1
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
SCT SF3 datalogging questions
when looking at a datalog from a SCT SF3 , what are the most monitored parameters and what to look for?
i dont have a screenshot yet, but if someone has one who can explain what they mean would help me understand this a little better.
eventually i will get to the point where i know what to look for, just need a nudge in the right direction.
Thanks.
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 02-10-2013, 03:21 PM   #2
dcoates18481
Anyone have a comment ? please???
I LIKE TO GO FAST!
Old 02-10-2013, 10:27 PM   #3
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
What do you plan to do if you scan the ECM? If you do not know tuning, it best left to the guys that do. Are you scanning to change some PID or are you giving that info to a tuner.
Tuning is not easy and you have to know what you are doing before you change anything.
You will need tuning SW and a wide band to do tuning right, or just buy a tune that is made for your car.
The most looked at items are Lambda, fuel trims, knock retard and many others. If you do not have a WB O2 then your are not doing much.
It take many hours of education to attempt a tune. It is not a easy thing to do.
Skylane765 is offline   Reply With Quote
Old 02-11-2013, 08:02 AM   #4
dcoates18481
i dont plan on tuning my own, just want to understand what to look for when things are changed.
i will be datalogging for my tuner, just thought someone here could point me in the right direction to see where the differences are in the tunes, and how to understand them.
Didn't happen...
I LIKE TO GO FAST!
Old 02-11-2013, 06:47 PM   #5
Skylane765
Skylane765's Avatar
It is all different for each car. WOT you want to be rich of lambda and cruse you want lambda 1. But you need a wide band hooked up to see it with HPtuners.
Old 02-11-2013, 06:48 PM   #6
Skylane765
Skylane765's Avatar
Your tuner will tell you what to log.
Old 02-12-2013, 08:27 AM   #7
dcoates18481
is there someone or something that can educate me what the readings are or mean??? a book, i just would like to know what they all mean..or is it secret???
I LIKE TO GO FAST!
Old 02-12-2013, 10:11 AM   #8
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Thanks.
Does this Help?
Engine RPM - RPM
MAP-Intkman abs prss
FUEL PRESSURE
ECT engine coolant temp – ecteng clt tmp
TPS throttle position or pedal position – acc pdl pos 1s
IAT intake air temp or Air intake temp – intk Airtmp
MAF Mass Air flow Hz – Maffre 125
TIMING spark cylinder 1 – ign Tim Adv4#1cyl
KNOCK RETARD – knk ret
Vehicle speed Kph–?
Long Term Fuel Trim bank 1 – ltf tri b1
Long Term Fuel Trim bank 2 – ltf tri b2
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 02-12-2013, 11:54 AM   #9
dcoates18481
Thanks
Originally Posted by JANNETTYRACING View Post
Does this Help?
Engine RPM - RPM
FUEL PRESSURE
Vehicle speed Kph–?
I know theres probably no cut and dried answer to this, i understand the above parameters are the ones most useful when Skilled tuners do their work, at what point do the readings become Detrimental to the engine is what i would like to know... as i said..probably no cut and dried answer.
i would like to be able to look at a log someday and understand what it is i'm looking at and any erroneous or detrimental readings.
I LIKE TO GO FAST!
Old 02-12-2013, 11:56 AM   #10
JANNETTYRACING
Your right I could write a book on it, best to let me look at the data.
There should be nothing even remotely close to hurting the engine If I tuned it.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 02-12-2013, 01:06 PM   #11
dcoates18481
It has nothing to do with your tune Ted!!!! Thats freakin awesome!
I'm just trying to understand how the process works.
my tune is fine,
i guess what i really need is some kind of literature that explains the process and what the sensors actually do and how they do it. highs lows etc.
not trying to tune my own vehicles by no means.....just trying to educate myself.
I LIKE TO GO FAST!
